08-10-2024, 07:15 PM | #1 |
Drives: 2010 CamaroSS 1954Belair 28 Model A Join Date: Dec 2023
A/C question new install
2010 SS
I replaced the compressor, condenser, (AC Delco) shrader valves, cleaned out the lines etc. This is my 1st time doing a complete A/C job. I was surprised that there was only 1green o ring and the rest were the washer style. Anyway, the vacuum pump test failed, so I have a leak. I tried putting 35lbs of compressed air in and sprayed around with soapy water and found nothing. Should I just charge it some with R34 with dye to find the issue? |
08-10-2024, 07:50 PM | #2 |
Drives: 2013 Camaro 2SS AGM Join Date: Apr 2020
Did you buy the install kit & replace all the seals?
2013 2SS GPI built & tuned 415, spec'd by Andrew Cammer. GPI ported intake/tb/heads, Tooley springs, CHE trunnions, Callies rotating assembly, Diamond pistons, GPI SS3 VVT, ATI 10% ud damper, Circle D 3800, Kooks ceramic coated lt's with green cats, Mishimoto rad & oil cooler, Derale trans cooler, Holley efi rails.
08-10-2024, 08:09 PM | #3 |
....the vacuum pump test failed, so I have a leak.
How did you test this?
08-10-2024, 08:25 PM | #4 |
You pretty much answered your own question. You have a leak & compressed air is much different that vacuum. As FasNuf posted, how did check it?
08-11-2024, 11:06 AM | #5 |
08-11-2024, 11:08 AM | #6 |
08-11-2024, 09:09 PM | #7 |
So UV dye splatter near the compressor connection. Is it possible to over-tighten the single 10 mill bolt there? There's barely enough room to get a small wrench on it so I got it as tight as I could.
08-11-2024, 11:29 PM | #8 |
I had this same issue after I replaced my compressor - chasing leaks until I recently got it fixed, I think. I recommend replacing every single seal you have access to. They are all fairly easy to get to. Also, most of these compressors require you to hold the compressor up vertically oriented and spin the compressor wheel manually a few times to lube the front seal. If not done this can also cause a leak. I also changed my service port valves.
08-12-2024, 04:42 AM | #9 |
Glad you found the leak. I got this from Alldata regarding the compressor.
Air Conditioning Compressor Oil Balancing Draining Procedure Note: Drain and measure as much of the refrigerant oil as possible from the rear head ports of the REMOVED compressor. 1. Drain the refrigerant oil from the crankcase and rear head ports into a clean, graduated container. 2. Rotate the compressor shaft to assist in draining the compressor. 3. Measure and record the amount of oil drained from the removed compressor. This measurement will be used during installation of the replacement compressor. 4. Inspect oil drained from removed compressor. Refer to Air Conditioning Compressor Oil Diagnosis See: Heating and Air Conditioning > Component Tests and General Diagnostics > Air Conditioning Compressor Oil Diagnosis. 5. Properly discard the used refrigerant oil. 6. Clean the graduated cylinder. Note: Drain and measure as much of the refrigerant oil as possible from the rear head ports of the NEW compressor. 7. Drain bolt and drain the refrigerant oil from the crankcase and rear head ports into a clean, graduated container. 8. Rotate the compressor shaft to assist in draining the compressor. Balancing Procedure Note: The refrigerant oil in the A/C system must be balanced during compressor replacement. The replacement compressor is shipped with 75 ml (2.5 fl. oz) of refrigerant oil. 1. Refer to the amount of refrigerant oil recorded during the compressor removal. 2. If the amount of oil recorded from the removed compressor is less than or equal to 75 ml (2.5 fl. oz), add 75 ml of the new PAG oil back into the new compressor through the compressor suction port. 3. If the amount of oil recorded from the removed compressor is greater than 75 ml (2.5 fl. oz), add the equivalent amount of the new PAG oil back into the new compressor through the compressor suction port. 4. Rotate the clutch driver three times to lubricate the internal compressor components.
08-19-2024, 03:01 PM | #10 |
Update: Oddly, it turns out that the bolt that connects to the compressor lines had bottomed out. I made sure that the compressor had the same numbers so I am not sure why that happened. I added a spacer and all is well now, holding pressure and cold air!
Thread Tools | |
