03-25-2020, 09:55 PM | #1 |
Factory pushrod length not 7.325in ?
Everywhere I've read states the factory LSA pushrods are 7.325in. So I ordered an aftermarket set that length. Upon removal and checking the two lengths, the factory pushrods are 7.400in. Has anyone else encountered this???
2012 BLK ZL1 M6: Rotofab CAI,20in Z28 Reps,5% tint,6K leds/hids,VMaxx TB,JLT CC,BTR Stage2PDSTQ Cam & Valvetrain,Holley VC, AFCO HX,BK Fab HX Tank,MGW Flatstick,Kooks 2in coated headers catless,BMR bushings & arms,160*,2.45 upper,ID1050s,Shane Hinds tuned, Pedders Xa Coilovers,DSX Aux pump & Flex Fuel,Corsa.
03-26-2020, 08:29 AM | #2 |
Factory pushrods are 7.4. It's something to keep an eye on. Most aftermarket companies use 7.4 as well but some cams require a different size. Also refer to the MFG of the cam and get a pushrod length checker. We check every car we build because you never know if someone had their heads decked, aftermarket head gaskets, lifters, or whatever.
03-26-2020, 11:00 AM | #3 |
Drives: 6th Gen NicKey Camaro & others. Join Date: Nov 2015
7.4 is stock for LSA/LS3. Not all cam companies use the same "core" to machine their cams and some have smaller base circles than stock. You should always measure.
03-26-2020, 01:56 PM | #4 |
Thanks! I haven't done a cam yet. If I do that'll be further down the road. I'm an ASE certified mechanic with 20+ years under my belt. Built quite a few small blocks. Just had me second guessing myself for a minute.
03-26-2020, 05:59 PM | #5 |
Drives: 2014 Summit White ZL1 Join Date: Oct 2018
Just a heads up, there is something called "Gauge Length" when measuring Pushrods, and how different companies measure/make Pushrods.
It is said that when checking with a regular caliper to measure pushrods, you need to subtract "0.017" to get "Gauge Length". I usually go "0.015-0.017".
2014 Summit White ZL1- Manual
03-26-2020, 08:01 PM | #6 |
fo'shizZL1
Drives: 2017 ZL1 Join Date: Aug 2017
Math check. I think that would be 7.340, right?
2017 ZL1 M6 Black | Maggie 2650 // 103TB // Big Gulp
Past Rides- 2014 ZL1 M6 Red Hot | Tons of mods 2004 CTS-V M6 Silver | Many mods 1995 Corvette M6 Torch Red | A few more mods 1992 Camaro M5 White | A few mods |
03-27-2020, 08:03 PM | #7 |
Indeed, hahaha.
I guess in my mind while doing the math, I moved the decible. Everything else is correct though.
03-28-2020, 01:38 PM | #8 |
Drives: 2013 Triple Black ZL1 / 2006 TB SS Join Date: Feb 2011
Best to always measure push rods (even stock ones) with a push rod checker when a new cam or heads are installed. Every aftermarket cam I've installed has a smaller base circle than stock. Incorrect push rod length can cause the dreaded "LS sewing machine sound". Also, every stock LS PR I've measured (going back to the LS1 days to now) has always been 7.37 to 7.38" when using a digital micrometer. The LS7 does have a longer length factory PR.
Thread Tools | |
