11-13-2010, 07:50 PM | #1 |
Drives: 2 door Join Date: Sep 2009
m6 clutch sucks..Wherere's the fluid reservior...??
Smelling burning clutch fluid when i back out of my driveway.
This forum covers many areas regarding this topic. Eventually I will replace stock clutch with ZR-1 clutch,,until then where is my clutch fluid reservior.??????? I was hoping to change fluid until Santa dellivers new clutch.....I would llike to examine the existing fluid to check for debris,,but i cannt find it. Any help would be appreciated!!!!! Thanks TED |
11-13-2010, 08:00 PM | #2 |
Drives: 2011 2SS/RS SGM Join Date: May 2010
i believe the clutch uses the brake reservior.
i.e. both clutch and brakes are on the same reservior
---2011 synergy green 2SS/RS---
09/27/2010 - (3800) 10/01/2010 - (4200) 10/09/2010 - (4800) Vehicle on final destination route 10/19/2010 - (5000) delivered to dealer 11/19/2010 - (6000) delivered to customer |
11-13-2010, 08:19 PM | #3 |
Drives: 2010 Camaro SS/RS 6spd Join Date: Sep 2009
11-13-2010, 08:20 PM | #4 |
Drives: 2014 Z/28 #82+#192, 18ZLE 66Nova Join Date: Oct 2008
11-13-2010, 08:29 PM | #5 |
Firefighter/Paramedic
Drives: RJT 2SS/RS M6 LS-3 Join Date: Aug 2009
I had the same problem. After talking with some people about the shared reservoir, I did a little research and found that the shared reservoir is bad on the brakes and clutch. It allows fluid to be contaminated turning it very dark almost black. I seperated the brakes/clutch by adding a seperate reservior for the clutch. The reservoir is out of a 2006 GTO. All the parts cost about $30.00. Too date, my brake fluid is still clear and my clutch fluid is darker. Also, changing the clutch fluid is easily done to make sure you don't destroy a slave cylander. I haven't had anymore problems since I seperated them over 3,000 miles.
FFPM73
11-13-2010, 09:02 PM | #6 | |
11-13-2010, 09:05 PM | #7 | |
Go Blue!!!!!
Drives: 2012 Cruze LT Join Date: Mar 2009
11-13-2010, 09:09 PM | #8 |
FFPM73
Similar Threads | ||||
Recommed all to do differential fluid change!!! | jnm2003 | V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) | 116 | 07-27-2016 06:08 AM |
Clutch fluid contamination problems on Vette fixed for Camaro??? | LDGn63 | V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) | 11 | 05-28-2012 09:17 PM |
Clutch issues. Anybody else seen this before? | H & E | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 47 | 05-21-2010 02:38 PM |
Vengeance Racing Introduces RPS Organic Street Twin Clutch for 2010 Camaro!!! | Ron@Vengeance | V8 Bolt-Ons & Tunes | 2 | 08-05-2009 01:03 PM |
Burned my clutch a bit with Launch Control.... Caution you guys... | Embalmer | 5th Gen Camaro SS LS LT General Discussions | 49 | 04-23-2009 08:49 PM |
