Old 07-31-2019, 02:48 PM   #1
Tommy434
Tommy434's Avatar
Drives: 2014 SS 2010 SS 93 Camaro z28
ZL1 diff question
So been looking for a ZL1 diff along with 30 other people in the ZL1 section and there so expensive on eBay I think I’ll buy a new one found the 3.73 ZL1 for 2100. Brand new, the z28 is little cheaper and lighter same size ring gear I believe but aluminum case will these hold up as well? Anyone try testing 1 on 900 plus? Thanks Tommy
Tommy434 is offline   Reply With Quote
Old 07-31-2019, 02:56 PM   #2
Crash76
Team 913
Drives: '14 ZL1, '12 GMC Terrain
ZL1 at a minimum if you are drag racing at 900rwhp
Crash76 is offline   Reply With Quote
Old 07-31-2019, 03:05 PM   #3
Tommy434
Tommy434's Avatar
Yes drag racing may be 800 not sure single turbo but weight is killing me steel block and 4l80e turbo and piping I’ve added 300lbs to this pig
Old 07-31-2019, 08:22 PM   #4
Crash76
Team 913
Strange makes a rear end for the 5th gen ... 20lb heavier than stock
Old 07-31-2019, 08:51 PM   #5
Tommy434
Tommy434's Avatar
Yea I’ve seen most of the aftermarket stuff but they priced themselves out of the market in my opinion
Old 08-12-2019, 11:14 AM   #6
CamaroCracka
CamaroCracka's Avatar
Drives: 2010 Turbo LS3
Just to be clear, the Z28 is still the 218mm ring gear in an aluminum housing, but has a Torsen style carrier and cooler. The Zl1 is a 250mm ring gear with a clutch style carrier in a cast iron housing. Much stronger than the Z28 diff, but much heavier too.
IMO, ZL1 for drag racing, Z28 for road racing or just build a stock 10 bolt because Z28 rears are as much as a ZL1.
The 9 inch, S60 stuff is for guys running under 10 sec.
It also matters how you are getting to 900. If it's a PD blower, you need more rear. Turbos and centri blowers generally don't come off the line as hard. There are 900hp turbo guys running 10 bolts.
On3 kit with cutout and CTR 76/75, turbo cam and stuff.
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
