08-03-2019, 03:59 PM | #1 |
Drives: 2010 2SS/RS Join Date: Dec 2009
CTSV 2 Piece Rotor
Will the 2013 CTSV front 2 piece rotor work on our cars?
According to rock auto their 6 lug. 1771145/1146 they are significantly cheaper than ZL1's.
Orange Krush II
08-03-2019, 09:17 PM | #2 |
Drives: 14 Camaro SS 1LE Join Date: Feb 2019
I do not believe that the CTS-V rotor will fit our cars. I am not certain though. The calipers are the same as the ZL1, but the rotor may be different.
08-03-2019, 11:53 PM | #3 |
Rotors
But you could swap rings over to the ZL1 though right???
Orange Krush II
08-05-2019, 08:43 AM | #4 |
Drives: 2010 Camaro SS2,L99, LSA SC Join Date: Aug 2017
I got the front zl1 rotors from https://www.brembostoreusa.com/ for 281.95 each w/ free shipping. They seem to use the same part # for the zl1 and ctsv. And they shipped from Nashville same day the order was placed.
08-05-2019, 09:23 AM | #5 |
Morris Engineering rotors for SS and 1LE are the best and lightest 2 piece rotor designed for our cars with Brembo’s. Expensive yes but no monkeying around...bolts right on and zero issues. $300 ea rotor and 2 versions offered for street and full track. I have the street version which are the lightest ones and they do great street and track. The track version is geared towards a car seeing a lot of track days so your average user typically won’t need the full track version.
Car mods: never enough!
08-05-2019, 09:52 AM | #6 | |
08-05-2019, 10:01 AM | #7 |
'It's an experiment'
Rock auto is showing the 1 piece @ the cheap price - I didn’t see the 370 mm versions (still $277) just the 365 mm ones...
Wonder if something changed... -Don
747 RWHP 794 RWTQ
08-05-2019, 10:05 AM | #8 |
I'm currently running the dual cast with 6 piston calipers and was looking for a alternative. I was thinking Z06 rotor rings on ZL1 front hats and Z28 rear hats since the lug studs are larger, but their 360 bucks each.
Orange Krush II
