Old 07-09-2018, 09:45 PM   #1
Zl1_kyle
Drives: 2014 zl1, triple black, M6, stock f
Slave cylinder problems.
Replace slave cylinder and clutch 700 miles ago due to space leaking. Raced one night on the new slave and clutch and it is leaking again has anyone else had this problem? Is there a good aftermarket slave?
Zl1_kyle is offline   Reply With Quote
Old 07-10-2018, 10:45 AM   #2
ZMEnow
Drives: ZL1, 2013, tri-coat-red, manual
Havent seen or heard that problem. I replaced mine myself when I did the Clutch and and Flywheel. It wasnt leaking, just did it as it had taken a lot of heat, and I wanted to add a one man Speed bleeder while in there. Sure the bleeder valve was closed?
ZMEnow is offline   Reply With Quote
Old 07-11-2018, 08:15 PM   #3
Zl1_kyle
It only leaks under hard shifts didn’t start leaking again until I did some hard shifts. I wonder if my slave cylinder is getting hot and leaking.
Old 07-11-2018, 10:04 PM   #4
ZMEnow
You can NLS all you want and it only wears the clutch disk and syncros, the slave cylinder works the same regardless how you shift, it’s only lifting the disc off the flywheel. It only becomes symptomatic if is overheated and the fluid is boiled, like slipping the clutch. It will stay extended and the pedal will stay on the floor
Did you inspect the feed line to make sure it’s not damaged since your new slave cylinder also leaks. Assumptions are based on stock clutch flywheel and slave cylinder.
slave cylinder, transmision, zl1
