Old 07-15-2018, 08:54 AM   #1
P1100
Drives: 2013 Camaro 2SS
ZL1 catalytic converters on an LS3
I know they are different part numbers and ZL1 cats are more $’s. Likely because of stainless steel exterior. Are they different inside and is it ok to use them on an LS3?
P1100 is offline   Reply With Quote
Old 07-15-2018, 09:47 AM   #2
rontammy0
Drives: 2011 2SS/ RS INFERNO ORANGE L99
How much are they....are your stock ones shot?
rontammy0 is offline   Reply With Quote
Old 07-15-2018, 12:02 PM   #3
P1100
No issues with stock cats, cats came with ZL1 manifolds I bought. Thought I’d install them as well.
Old 07-15-2018, 09:31 PM   #4
rontammy0
I think they would be better built because of the supercharger. But Im guessing of course.
Old 07-15-2018, 11:49 PM   #5
P1100
I suspect so, installed them today. Seem fine.
Was an open day at the track so I gave it a try. Lots of corners but could open up on straight sections. Didn’t know 3rd is good to 100 mph. Maybe it’s the cats ��
Old 07-16-2018, 11:31 AM   #6
rontammy0
Lol don't say that next thing you know its a whole new craze. Could turn into the #1 mod .
Old 07-16-2018, 12:39 PM   #7
Taylortoons
Taylortoons's Avatar
Drives: 2011 2SS/RS LS3
I’ve had 3rd to 120 and 4th to 145 with 3.91 gears.
GPI Built Procharger D-1/13 PSI/Race Intercooler/SS3 Cam Kit/Kooks LTH/X- pipe/FIC 1050/E85/3.91 gears/Centerforce Dual Disc clutch/Flowmaster Outlaw/775whp/680tqSOLD
Taylortoons is offline   Reply With Quote
Old 07-19-2018, 12:04 AM   #8
P1100
I stopped around 6200 rpm.
What rpm is 120 in third with 3.91 gears?
Old 07-20-2018, 12:14 PM   #9
KW Baraka
KW Baraka's Avatar
Drives: 2014 Chevy SS
Put in your gear ratio (3.91), your target speed (120mph) and your tire diameter.
Then.....click the "Compute RPM" button. If you're running a 28" diameter tire, then it would be 5630 RPMs.
http://www.advanced-ev.com/Calculators/TireSize/
KW
1995 Impala SS -- Heads/Cam LS3
1996 Impala SS -- 398ci LL Solid Roller LT4
2014 Chevy SS --- 429ci Hydraulic Roller LS3
KW Baraka is offline   Reply With Quote
Old 07-23-2018, 07:16 PM   #10
Indyblue98
2012 RS 2ss
Drives: 2018 ZL1 2012 2SS WhippleCharged
KW
That Calculator is Assuming 1:1 Ratio in Transmission.
With the SS Manual Trans 3rd gear 1.43
RPM would be approx. 8050 with 28" Diameter tire
Indyblue98 is offline   Reply With Quote
