06-21-2018, 07:08 AM | #1 |
MonstaBGP
390 40 17 tire
I have a 17x10 weld wheel. And I just wanted to confirm that 390 40 17 would fit without any modifications.
06-21-2018, 07:15 AM | #2 |
Drives: Camaro and Sierra Join Date: Jul 2012
Did you type that number correctly? If you did then No. that’s a 15” wide tire
06-21-2018, 08:02 AM | #3 |
Drives: 2013 2SS M6 Join Date: Mar 2018
No, a 390 will not fit on a 10" wheel.
2013 2SS M6 - Custom cam w/ miscellaneous valvetrain upgrades, ported heads, longtubes, CAI, CTS-VR lifters, Forza NPP exhaust controller - 500hp/460tq
06-21-2018, 08:18 AM | #4 |
MonstaBGP
This guy did it
06-21-2018, 08:35 AM | #5 |
Drives: 2010 Camaro SS/RS Join Date: Mar 2014
suggested rim width is 12"
not sure what you need to move or bend out of the way but it looks awesome
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53 |
06-21-2018, 10:05 AM | #6 |
MonstaBGP
He said he did nothing. He put it on a 10" wheel and had no problems. And he was lowered
06-21-2018, 12:01 PM | #7 |
Drives: 1999 Camaro SS Join Date: Apr 2016
You sure the size is correct??? that tire measure 29" tall x 15.4" wide. Pretty wide for these cars with no mods
06-21-2018, 12:10 PM | #8 | |
Captain Gingerbeard
Drives: 2012 IOM RS/SS 6MT Join Date: Feb 2013
390 is NOT the correct size. There is no physical way a 15" wide tire will fit in our wheel well.
Also, standard tire sizes end in 5 for the width - 295, 315, 305..... Pretty sure you were misled or you remembered the size wrong.
Custom ordered 2012 6MT RS/SS on 11/25/2011. Picked up 01/31/12.
Pedders Coilovers, BMR trailing arms and toe-links, Prothane solid poly subframe bushings, JDP Motorsports rear upper control arm bushings, Texas Speed long-tube headers with 2" primaries, modified fully 3" Magnaflow competition catback. CAI cold-air intake. DBA rotors, Hawk pads. Quote:
06-21-2018, 12:50 PM | #9 |
MonstaBGP
Just googled some pictures of the tire. It looks its true. There's a corvette, trans-am and his camaro who pulled it off. And Shibbs it's 17" tire
06-21-2018, 01:34 PM | #10 |
Drives: 13 Camaro Join Date: Oct 2016
That camaro picture is a photoshop job. Look at the front zoomed in. Especially around the point where the ss badge is. Then look around the edges of the hood.
06-21-2018, 01:46 PM | #11 |
345 is the widest tire, tire rack has in a 40 aspect 17" tire. That tire requires a minimum of a 11.5" rim. Plus like said width would be 375 then 395, there's no 390 tire. Someone is full of bologna.
06-21-2018, 01:48 PM | #12 |
MonstaBGP
The 390 tire is available on SummitRacing website
06-21-2018, 01:59 PM | #13 |
Yep 1, even there it says 11" minimum wheel width. Over 29" diameter on a lowered camaro. With a 12.5 inch wide tire , with no mods. All this equals up to no way no how. Go look at a z28 5th gen. Not even with the flares will it fit that. The z tires are two inches smaller in diameter.
06-21-2018, 02:01 PM | #14 |
STOCK ELIMINATOR
Drives: STOCKER Join Date: Aug 2015
The orange 13 ss was mine . Photoshop ? lol yeh okay . That tire fit great didn't rub a thing and the car went 10.14 at 138 and it was a 6 speed ! That's the only tire id put on a camaro !!! If you guys would get off the computer and actually try things you'd be amazed lol . No one said a stick could run what it did either , and it's still number one on the fastest list !
5664 AA/SA
1970 NOVA |
