06-23-2020, 11:02 PM | #1 |
A/C Clutch is not engaging
My AC clutch recently stopped engaging. I switched the AC relay out with the headlight relay and the headlights worked with it, so I assume the relay is good. I jumped the AC relay with a piece of wire and the clutch DID engaged. Seems like the wiring is good and something is causing the relay to not fire. (It also doesn't make a click when I press the AC button) What would you guys troubleshoot after that?
Custom 2.5" catback exhaust, Solo High Flow Cats, Vitesse throttle controller, Phasetek rear blackout kit, 4" quad tips, 1le diffuser
06-24-2020, 08:00 AM | #2 |
Drives: 2012 2SS/RS, 1968 SS Join Date: Feb 2012
Check to make sure that your system has enough freon/pressure.
If not, please don't use a can, you might have a broken piece somewhere.
LS3 Crate Engine Swap | CSP Custom Cam 232/240 .615/.615 113 +3 | Stainless Power LT Headers | Z28 Intake | Borla S-Type Exhaust | FTI Triple-Disc Billet 3200 Stall
2012 Camaro 2SS/RS | 1968 Camaro SS | 2020 Cadillac CT5 Premium Luxury | 2021 Spark LS |
06-24-2020, 09:11 AM | #3 |
Drives: 2010 Camaro SS2,L99, LSA SC Join Date: Aug 2017
You can probably jump the pressure switch to see if it will engage the clutch (at least you can on older vehicles, I've not had to work on my Camaro AC system). If so it's likely low of Freon.
06-24-2020, 09:25 AM | #4 |
Thanks for the help guys! I was about to go to O'reillys to borrow a set of AC gauges. I also wanted to inspect the wire going into the compressor a little more so I was messing with it to get a good look at it. Fired up the car and the AC started blowing cold.
How could just messing with the wire going into the compressor get the relay to work when I was able to hotwire it and have it engage every time? I would think a bad wire would be a bad wire and either method wouldn't work to engage the clutch. Oh well, glad it was something simple, maybe that wire is just in bad shape
06-30-2020, 06:59 PM | #5 | |
waiting at the tree
Drives: SIM 2010 2SS/RS A6 Join Date: Apr 2013
Mine stopped working two days ago after blowing ice cold for years, I also noticed my high speed fans will not engage.
2010 2SS/RS A6 Just a few bolt-ons and appearance doo dads
