Old 07-23-2021, 03:37 PM   #1
BlkCamaroVert
BlkCamaroVert's Avatar
Drives: '11 2SS/RS L99 Vert IO Interior
Should I Allow Towing on the Rear Wheels
I had to have my car towed. The guy tried to tow it from the front. I told him no! Also, it was stuck in park anyway so that wasn't going to happen. But since he didn't speak a word of English (happened in Miami) I had to let him figure it out for himself. He was going to tow it 30 miles on the rear wheels! Would that have done damage?
BlkCamaroVert is offline   Reply With Quote
Old 07-23-2021, 03:57 PM   #2
JamesMyBoy
Drives: 2014 2SS/RS
I believe that the owners manual specifically says not to tow the Camaro on it's wheels.
Flat tow (on a tow truck) only. I would guess that 30 miles of towing as you describe would totally trash the rear-end!
JamesMyBoy is offline   Reply With Quote
Old 07-23-2021, 05:41 PM   #3
SS Performance
SS Performance's Avatar
Drives: 02 Camaro B4C
NEVER tow a automatic trans car on its drive wheels!
It can burn up the transmission
A man's garage is his castle
1970 Camaro SS
2002 Camaro B4C
2015 Camaro 1SS 1LE
SS Performance is offline   Reply With Quote
Old 07-23-2021, 06:08 PM   #4
Rob3D
Rob3D's Avatar
Drives: Car
Tow hook and flat bed. Otherwise you’re rolling the dice.
Rob3D is online now   Reply With Quote
Old 07-23-2021, 07:50 PM   #5
G8One2
Drives: 2014 Camaro 2SS
100% Truth! Modern cars cannot be towed in that manner. Which is why MOST tow trucks, show up in a flatbed. Internal components of the transmission are still turning even in neutral. If the engine is not running, the pump is not lubricating = damaged transmission.
G8One2 is online now   Reply With Quote
Old 07-23-2021, 07:53 PM   #6
G8One2
If the driveshaft were removed, it would be a non issue. Big rig tow truck for semi's will actually remove the driveshaft prior to towing for this reason. Your average tow truck driver for the automotive world, wont do that.
Old 07-25-2021, 07:35 AM   #7
Pete G
Pete G's Avatar
Drives: 2015 SS 1LE
No harm would be done if it was a manual transmission though?????
Pete G is offline   Reply With Quote
Old 07-29-2021, 08:48 PM   #8
Rock-It Man
376 cubic inches of fun
Rock-It Man's Avatar
Drives: 2010 Camaro 2SS A6
Camaro should only go on a flatbed.
End of story.
Rock-It Man is offline   Reply With Quote
Old 07-30-2021, 05:07 PM   #9
BlkCamaroVert
They towed it on the front wheels. I now notice some studder when I brake. Like the front rotors are warped. Maybe it's coincindence.
Old 07-31-2021, 04:24 AM   #10
102SS
waiting at the tree
102SS's Avatar
Drives: SIM 2010 2SS/RS A6
My Camaro's and Firebirds were always flat bedded.
Tow from the rear the front valance will drag on the ground
Tow from the front and you damage the valance and your driveline.
2010 2SS/RS A6 ZL1 Rims
60ft 2.03 13.08 at 107.82 (4/28)
2009 Pontiac G8 3.6L the DD
102SS is offline   Reply With Quote
Old 08-09-2021, 05:18 AM   #11
PaulsSS
Drives: 15SS Camaro
Dollies or flat bed but to go a short distance there is enough trans fluid with it tilted up in the air engine not running to keep most everything lubed. I wouldn't go over 45mph or 50 miles though. Next time force them to get the dollies out.
PaulsSS is offline   Reply With Quote
Old 08-09-2021, 10:29 AM   #12
ElderJ
ElderJ's Avatar
Drives: 2014 Camaro 1LT
I'm surprised your boy didn't know this. It's pretty common knowledge, and for a tow truck driver, it's really kind of important to know...
ElderJ is offline   Reply With Quote
Old 08-09-2021, 06:23 PM   #13
BlkCamaroVert
So is speaking even a little English
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
