Old 07-29-2021, 02:26 PM   #1
LS3_JC
LS3_JC's Avatar
Drives: 12í Chevy camaro SS 6MT
MPG on a cam
My car is a 2012 camaro 1ss manual currently its stock (just an axleback) but Iím looking at a cam in the future, currently Iím getting around 29mpg on the highway and 14 in the city (beating on the throttle occasionally). How much would it tank if I put letís say a GPI SS3 in it? The car is my daily driver btw.
haul ass and burn rubber brotha
LS3_JC is offline   Reply With Quote
Old 07-29-2021, 03:31 PM   #2
morepowerjoe
morepowerjoe's Avatar
Drives: 2012 Chevrolet Camaro l99
This question has been answered numerous times. The search button at the top right is your friend. But I went from 23 mpg on the highway to 21-22 mpg at around 70 mph with the GPI SS1 camshaft. I don't know how you get 29 mpg.
GPI SS1 Camshaft with vvt, GM Performance lifters, Comp CAMS trunnion upgrade, TSP Chrome Molly pushrods, Pac Polished .660 valve springs, Melling 10355HV oil pump, Cold Air Inductions cai, TSP 1 7/8" longtubes with 3" exhaust, true cool 40k tranny cooler
morepowerjoe is offline   Reply With Quote
Old 07-29-2021, 11:22 PM   #3
sixty9fordkiller
Donkey Dick Cam Camaro
sixty9fordkiller's Avatar
Drives: 2010 2SS/RS LS3 M6
a lot will depend on the tune and the overall combination. All an aftermarket performancr cam does is open the valves higher and longer than a stock one.
The more air that goes through the motor, the more fuel it will consume
Sent from my SM-G975U using Tapatalk
Bone Stock
sixty9fordkiller is offline   Reply With Quote
Old 07-30-2021, 11:58 AM   #4
zz430camaro
zz430camaro's Avatar
Drives: 2015 1LE
If I drive mine normal without getting on it, its almost the same as stock, maybe a little lower but overall not too bad.
2015 1LE, TSP 225/236 113+3, VMAX Throttle Body, CAI with race scoop, GPI Ported Intake, Land Speed Stage 2 Heads, 1-7/8 headers, NPP exhaust, 25% Fluidampr, LT1-S Monster Clutch, 485 RWHP & 444 TQ
zz430camaro is offline   Reply With Quote
Old 07-30-2021, 03:41 PM   #5
SSFury
My Road Rage is Legendary
SSFury's Avatar
Drives: 2011 IOM 2SS/RS
I'm running a Night Fury cam. I went from 18 MPG to 15 MPG. I think that's more the Tune than just the mechanics of the Cam.
Every Time You Buckle Up In That Car, Tonight Might Be The Night That You Die.
SSFury is offline   Reply With Quote
Old 07-31-2021, 09:38 AM   #6
RupertPupkin
Drives: 2014 Camaro SS 1Le
I get an avg of 200 miles to the tank, sometimes way waaaaaaaaay less. I also use E85 and I’m cammed/boosted. If you’re worried about gas consumption… don’t do it.
2014 SS 1LE Money Pit
Was: 802Whp/662Trq
Current: Blown Engine :(
RupertPupkin is online now   Reply With Quote
Old 08-04-2021, 08:12 AM   #7
Inferno dogg
Inferno dogg's Avatar
Drives: 2010 Camaro 2SS
Originally Posted by RupertPupkin View Post
I get an avg of 200 miles to the tank, sometimes way waaaaaaaaay less. I also use E85 and Iím cammed/boosted. If youíre worried about gas consumptionÖ donít do it.
Well said!!! I get around 9.8 MPG and I don't care!!!
GPI SS3 cam with top end goodies,Circle D 4c 3800 w/Derale trans cooler kit sold by GPI,3.90 yukon gears,Kooks long tube headers,Roto fab cold air intake, Corsa extreme 3" cat back, Dyno tuned by Andrews Auto Georgetown MI, Heritage Grille, T4 splitter with under tray, Anvil spoiler,MRR 228 reps with Nitto NT555G2 tires 315 rear 275 fronts,BMR poly bushings,HD Diff cover from RDP,Raytech install kit
Inferno dogg is offline   Reply With Quote
Old 08-04-2021, 02:20 PM   #8
xc_SS/RS
Drives: 2010 Camaro SS/RS
Mpg on e85 gets shocking even on the stock cam
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53
xc_SS/RS is offline   Reply With Quote
Old 08-04-2021, 05:21 PM   #9
gunchamp
gunchamp's Avatar
Drives: 15 Camaro SS
You will lose significant fuel mileage witht that cam. Dont mod if losing that bothers you. With my setup now, i think im in the negatives somehow lol
15 Camaro SS- GPI max top end, ESS Vortech V3 10psi, ID 1050s, ZL1 pump, JMS bap, Long tubes, Corsa extreme, Circle D pro 5C, 391 rear, DSS carbon drive shaft, BMR toe rods, BMR trailing arms, poly cradle bushings, tuned by Ted Jannetty and much much more
gunchamp is offline   Reply With Quote
Old 08-04-2021, 09:00 PM   #10
RupertPupkin
Never experienced on a stock cam. I remember at 1 point I saw an avg of 3mpg on the DIC
Was: 802Whp/662Trq
Old 08-05-2021, 09:14 PM   #11
Modernmusclecar
Modernmusclecar's Avatar
Drives: 2011 Camaro SS
Fbo cammed geared and stalled here. Not enough of a difference to be concerned.
EPS CUSTOM GRIND BLOWER CAM....K@N CAI....VMAX PTB.....FRANKENSTEIN STAGE 2 HEADS ...1 7/8 STAINLESS POWER CATTED LONGTUBES HEADERS...CORSA XTREME 3 INCH CATBACK.....CIRCLE D 3200 STALL....391 GEARS ..NITTO 555R 305 35 20 DRAG RADIALS..AGP PERFORMANCE DYNO TUNED. 463 WHP 428 FTLBS TORQUE.
Modernmusclecar is offline   Reply With Quote
Old 08-05-2021, 11:35 PM   #12
wasthatacop?
wasthatacop?'s Avatar
Drives: 2010 2SS
I avg 16.3 mpg. If your worried about mpg don't do it.
2010 2SS living in Los Angeles
replaced engine @ 93,000 miles w/ crate engine, camshaft by Comp Cams installed by me, replaced valve train parts,
1.4" BMR lowering springs
ZL1 factory rims
misc: drilled and slotted rotors, fresh air brake cooling system, new speakers, installed reverse camera, muffler delete
wasthatacop? is offline   Reply With Quote
Old 08-06-2021, 04:38 AM   #13
Bigdumogre
Bigdumogre's Avatar
Drives: 2012 Camaro SS
Maybe buy a Honda ?
2012 Camaro 2SS/RS - K&N cai, Katech ported TB, GPI Ported/rod modded manifold, Texas speed 1 7/8 headers, HFC, Flowmaster 2 chambers with x pipe, Mishimoto CC, MSD wires, Roto fab washer relocation, DynoSteve tune, tru cool 40k trans cooler, apex scoop, heritage grill, jre dipstick mod
Complete street performance appointment booked - Cam, tsp CNC heads and converter.
Bigdumogre is offline   Reply With Quote
Old 08-06-2021, 10:16 AM   #14
Axe55
Every mod I've done has given me more smiles per gallon... just go for it!
2012 Camaro SS LS3, JRE Scoop, CAI intake, Whipple Supercharger, Fast 85lb injectors, ZL1 pump, McLeod RXT clutch, MGW shifter, Stainless Power 1 7/8 headers w/HFC, Ridetech coilovers, BMR sway bars, trailing arms, toe rods, cradle bushing inserts, 2020 Speed Tuned.
Axe55 is offline   Reply With Quote
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
