07-11-2023, 11:23 PM | #1 |
Drives: 2019 ZL1 Join Date: Mar 2019
Oil leak dilemma, 2nd motor.
Well, without going into too much detail I have an oil leak on my now 2nd motor.
I’ll sum it up: Last October , had a new build done. New shortblock, 377 by LME and the works. Well it lasted 800 miles or so, I cracked Cyl 6. Was other issues with it but that did the block in. In that time we were troubleshooting the rebuilt trans which was a mess and that rebuilt trans was a scrapped and a new rebuilt trans was put in. So the car stayed at the shop, LME warranteed the motor and I got a new short block and CSP was great and took care of installing. Now I’ve got the car back and 400 miles later it’s leaking oil which appears to be from the rear main seal. (Not 100% need to get back under it and trace the uv dye tomorrow.) It’s not a bad leak and I noticed it more when it’s shut off and sitting, it’s collecting bit barely if at all dripping. When we were on the first motor we pushed the front seal out. The MM wild can just didn’t seem like it was enough with only 1 an10 vent from The valve cover. So they redid the ventilation system and ran 2x an 10 from each valve cover and turned the mm can into a breather. No vacuum. I then added my elite engineering can and connected that the normal way under the blower dirty side and vacuum off brake booster. Fast forward to now that’s how the system is still setup. My build: LME 377 fully built , maggy 2650, too high psi plates, port injection w/Holley, fore triple in tank pump and the normal bolt ons. We are running an 80mm pulley which makes around 18psi. I run pretty much only ethanol 65%. Pump gas tune is very conservative and is only 17 degrees on 93. (25 on ethanol) I just can’t wrap my head around if it is indeed the rms .. how. (Again) So far everyone I’ve spoke too says the ventilation is adequate. No issue with front seal, dipstick doesn’t pop out. Remove the oil cap when running I have vacuum. I just don’t know how or why it would need more venting. It’s very hard to tell, because as you know oil leaks are deceiving. But it collects at the bottom rear of the pan, I also see it by the starter. But I was also able to see it tonight from the top of motor with the uv light down to where the dipstick tube goes. Tomorrow I’m putting it back on ramps and will trace the uv dye. This thing ran a 4.8s 60-130 spinning in 3rd. If anyone has any suggestions please chime in, because it looks like they are gonna have to pull the trans again. Unless by some miracle it’s something else leaking and running down.
928rwhp - 93 | 1040rwhp/898rwrq - E65 SAE
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90 |
07-11-2023, 11:28 PM | #2 |
Here’s the setup.
You can see the elite can bolted to the roto fab housing.
07-12-2023, 06:16 AM | #3 |
ZL1 Driver
Drives: Camaro ZL1 & BMW M3/E92 Join Date: May 2009
I wonder it may be from the engine/tran seal
07-12-2023, 07:28 AM | #4 |
Drives: 2022 Lt1 A10 Join Date: Nov 2015
If it was the trans seal the fluid would be red. I've never run a catch can, just larger hoses from the VCs to the GM crank case ventilation system. They are 5/8", I also 5/8" to the RotoFab elbow. On my 16ss I failed to run the larger hoses till it was too late and didn't have enough crank case ventilation, also running too much boost and finally broke a couple pistons ring lands and pushed the rear seal out. I run as much hose as possible as you can see running to the THPSI VCs on the drivers side from the GM Vent system.
2022 Lt1 6.2 A10, Maggie 2300, THPSI Port Inj/10 rib, Rotofab, E, Nickey, SCOL, Griptech, RC Bandits, Hoosiers/MT 9.80@142.96 1.44 60ft, 6.34@112 707/669 RWHP/TRQ. 16SS Maggie 2650 9.41@147 1.35 60ft, 5.99@119. 16 C7 A8 10.90@128 Bolt on stuff
07-12-2023, 07:51 AM | #5 |
Drives: 2016 1SS NFG A8 Join Date: Aug 2017
you might try a metco valve cover breather with check valve and see if the leak goes away.
2016 NFG 1SS A8
Options-2SS Leather/NPP Perf. mods-Whipple 2.9/Fuel System/Flex Fuel/103mm TB/Rotofab Big Gulp/Cat Deletes/Corsa NPP Per. times- 10.5 @ 137 w/ 1.8 60ft Full weight on 20's 1200DA |
07-12-2023, 08:54 AM | #6 | |
I’m going to put the breather on the drivers side rear vent. Only place it will fit. I just can’t see how it would need more venting since it’s already being vented on both covers into the can.
07-12-2023, 09:08 AM | #7 | |
My box both ports on either side of the clean air port are capped.
07-12-2023, 11:45 AM | #8 |
fo'shizZL1
Drives: 2017 ZL1 Join Date: Aug 2017
I'd say you're pulling air from the mightymouse into the crankcase, it's just not metered anymore (assuming the check function of the MM was removed). Then you are filtering the dirty side with the E2X. Under boost, those lines to the MM should be evacuating any pressure build up. I'm not an expert on pcv, but I think you've got it covered. I wouldn't think pressure build would be cause of a leak, since you have addressed the pressure build.
2017 ZL1 M6 Black | Maggie 2650 // 103TB // Big Gulp // CSP LT's & Ultra Cats
Past Rides- 2014 ZL1 M6 Red Hot | Tons of mods 2004 CTS-V M6 Silver | Many mods 1995 Corvette M6 Torch Red | A few more mods 1992 Camaro M5 White | A few mods |
07-12-2023, 11:50 AM | #9 |
fo'shizZL1
Are those simply straight hose couplers in the 5/8 lines? (as opposed to inline check valves or something)
Past Rides- 2014 ZL1 M6 Red Hot | Tons of mods 2004 CTS-V M6 Silver | Many mods 1995 Corvette M6 Torch Red | A few more mods 1992 Camaro M5 White | A few mods Last edited by RobZL1; 07-12-2023 at 02:27 PM. |
07-12-2023, 12:06 PM | #10 | |
However, I just found this when borascoping via top with uv light. I don’t know if there is 2 leaks but this would explain why I see it on passenger side running down near the starter and then to the bottom. I can’t tell but doesn’t even look like the oring is seated ?
07-12-2023, 01:08 PM | #11 |
fo'shizZL1
Assuming that's the dipstick housing, at least you should be able to check it out fairly easily...relatively speaking.
07-12-2023, 01:09 PM | #12 |
It looks like it’s leaking from the dipstick tube 100%. I guess from being pulled out so many times maybe the oring(s) are worn. Now how to get it out and back in with headers on ?
Any tricks?
07-12-2023, 01:12 PM | #13 |
Correct it’s leaking from the base of the dipstick tube.
07-12-2023, 02:25 PM | #14 |
fo'shizZL1
DUDE!!! I'm glad that's all it is. You've have enough bad juju with this car. You're due for a win, my man.
