Old 04-23-2018, 01:37 PM   #1
firehead
firehead's Avatar
Drives: 2014 Camaro SS 1LE
Mods
I'm currently working on installing some kooks headers, a FAST intake manifold, and a 102mm Throttle body from Nick Williams. Out of curiosity, will my stock transmission be able to handle the increase the new torque output? The only other mod that is on this vehicle is a Borla Atak exhaust and a cold air intake from CAI. I'm fairly new to modding so I don't want to screw it up.
firehead is offline   Reply With Quote
Old 04-23-2018, 02:57 PM   #2
2014white2ssrs1le
2014white2ssrs1le's Avatar
Drives: 2014 white 2ss rs 1le
Should be fine...some guys have said their stock clutch worked fine up to around 600rwtq
2014white2ssrs1le is offline   Reply With Quote
Old 04-24-2018, 05:44 AM   #3
firehead
firehead's Avatar
Awesome, I was just looking around on the chevy perfomance site and saw that the stock trans was technically only rated for 440 ft/lbs of torque. I don't exactly want to be replacing that yet!
Old 04-24-2018, 08:21 AM   #4
Olddudesrule
Resident nomad
Olddudesrule's Avatar
Drives: 2014 Summit White 1SS/1LE
Absolutely.....If you treat the trans/clutch right, it will last a long time. You can kill the clutch with stock power if you really wanted to.
Sold:
2007 Z06
2002 Viper GTS/ACR
2003 Z06
1965 FFR Cobra
2012 Nissan 370Z
ADM LSA Stage II, Roto-Fab CAI, Kooks LTH/HFC's, Phastek CC, ported TB, Mishimoto radiator and oil cooler, BC Racing ER Series CO's, JPSS 32mm Black Magic rear bar, JPSS front inserts, R1 Concepts Premier slotted rotors/Goodrich SS lines, Schroth ASM harness, MGW flatstick, Brey-Krause HB, Tuned by NicD, at Cordes Performance Racing.
Olddudesrule is offline   Reply With Quote
Old 04-25-2018, 05:47 AM   #5
firehead
firehead's Avatar
Very true
Old 04-25-2018, 07:21 AM   #6
Andoskyy
Drives: 2015 Summit White 2SS/RS 1LE
If you're not getting a tune, your mods are likely to decrease your HP anyway.
I have essentially all available bolt-ons and have 402hp at the wheels, about a 30-40hp gain over stock and no issues.
Andoskyy is offline   Reply With Quote
Old 04-26-2018, 01:06 AM   #7
PapaKlutch
PapaKlutch's Avatar
Drives: 2015 Camaro SS/1LE
I'm currently working on installing some Kooks headers, a FAST intake manifold, and a 102mm Throttle body from Nick Williams. Out of curiosity, will my stock transmission be able to handle the increase the new torque output? The only other mod that is on this vehicle is a Borla Atak exhaust and a cold air intake from CAI. I'm fairly new to modding so I don't want to screw it up.
Clutch n trans will handle that fine. The NW102 n FAST IM won't give you much rwhp on a stock displacement/compression LS3; especially with a stock cam. You'll gain far more power with a cam upgrade than the 102/IM pairing. As mentioned, you'll need a tune after the parts are installed to get the full benefit.
2015 2SS/1LE/RECARO/NPP/RS/NAV
PapaKlutch is offline   Reply With Quote
Old 05-21-2018, 07:16 AM   #8
firehead
firehead's Avatar
Well that's a given, I've done enough research to know that it needs to be tuned after putting the mods on.
Old 05-21-2018, 09:25 AM   #9
J Rod
J Rod's Avatar
Drives: '14 BRM 1LE 2SS/RS
I agree with this. LTs, CAI, catch can, ported stock TB, and a tune are all I plan to do until I can come with the money (and balls) to do heads/cam. Anything else is just not worth the money until then IMO.
592 HP/590 TQ
LSA Blower w/ 2.45 Griptec, Reinforced Brick, FIC 1000 injectors, JRE FPCM, LFP Dual Pass HX, ZL1 IC pump, RotoFab CAI, Bo White TB, Coated Stainless Power 1-7/8" LTs, NPP, NGK TR7IX, Mighty Mouse Wild CC, AEM X-Series WB, Aeroforce Interceptor, MGW Shifter, Z28 Grill, Gary's Custom ZL1 Rockers, Hero Tails, Tuned by IMC
J Rod is offline   Reply With Quote
Old 05-21-2018, 10:49 AM   #10
firehead
firehead's Avatar
I'm hoping to do the cam and heads next winter, I've heard the cam is pretty easy, but as a novice, that may not be the case.
