04-23-2018, 09:52 PM | #1 |
Drives: 2013 ZL1 Join Date: Dec 2017
KOOKS header question.
Looking for pros and cons between the locking bolts KOOKS supplies and reusing stock exhaust manifold bolts. Seems like I have read some guys prefer the stock manifold bolts and I am wondering why. The headers are just hanging by a couple of bolts for now and will be easy to do either setup.
04-26-2018, 01:42 AM | #2 |
weSS1LEy
Drives: 2015 camaro 2ss/rs/1le Join Date: Sep 2015
Are the bolts the same length? If the header flange is thicker you need the supplied bolts I would imagine
Rotofab, arh no cats, atak, elite cc, 94 octane tune, Mobil 1, phastek scoop, custom cam 230/243 .621 .604 114+4, related cam kit stuff. 470/435 rwhp/rwtq
04-26-2018, 06:01 AM | #3 |
Team 913
Drives: '14 ZL1, '15 Jeep GC, ‘22 Ram 2500 Join Date: Apr 2015
Ive reused stock manifold gaskets on the manifolds, bought new for the headers and when I take headers off I reuse those...
Not that it matters, i just figured if there is any seal or mating of the two surfaces reusing them in same setup is best. But also could be I just like new shiney things... Ive also reused the stock bolts on my ARH LTs ... never liked the locking bolts. |
04-26-2018, 06:41 AM | #4 |
Drives: 2015 Camaro 2SS Green Flash Edition Join Date: Dec 2015
I used the Stage8 locking fasteners that came with mine. I only used the locks in the beginning, but have had the headers off at least 3-4 times for other mods and haven’t used the locks since and haven’t had any bolts loosen.
I’ll second for using the factory exhaust gaskets. I’ve reused the same gaskets each time I’ve had to take the headers off and they’re still like new. You can see the diff when compared to what is sent with the headers.
Kooks stepped headers & Solo XL Cat-back
ADM CAI w/race scoop & Rotofab w/w relo GPI VVT SS1 cam and CNC ported heads milled .30 BTR .660 springs, Straub solid bushing trunions GPI rod-mod intake with I-M heat sheild Circle D 258mm Pro single disc 3700 rpm stall converter 169F thermostat & manual fan switch Tuned by Ryno at GPI - 455 RWHP / 416 lb-ft |
04-26-2018, 07:37 AM | #5 |
Drives: 2010 Camaro 2SS LS3 Join Date: May 2012
Just some info for you, I wonder if you saw the same thing. My LS3 header bolts had allot of resistance coming out, almost like there were slightly mushroomed threads at the end on purpose, a couple came out so hard that I lightly ground the end down just a bit and then they went in super easy. Now I'm wondering if these will come loose.
04-26-2018, 09:16 AM | #6 |
I haven’t had any resistance removing header bolts, mine have always come out clean. I did use a very light coating of antiseize when I installed the new header bolts.
04-27-2018, 10:02 PM | #7 |
Thanks for the info every one. dookie454 my exhaust manifold bolts had a little resistance when I took them out but I used a 3/8" drive air ratchet and that may have masked any extra resistance. I looked in the GM manual and saw they want thread locker used on the bolts when being reused. I called KOOKS today and their tech said the locking bolt setup is more reliable when used on road courses. Again thanks for the info.
04-27-2018, 11:38 PM | #8 |
Team 913
Ive run my stock bolts on more than a few 20min sessions...
