10-16-2019, 10:28 AM | #1 |
Drives: 2013 camaro ZL1 M6 Join Date: Oct 2019
13 zl1 looking to add power
I'm sure there's a thread on here somewhere about this. Bought it used at 20,000 miles. I'm the third owner so I'm not sure about mods but it appears stock other than rotofab CAI and borla atak exhaust. What's the cheapest and most reliable (safe) way to make about 100-150 WHP? Took to a local speed shop (I've heard mixed reviews on this particular shop) and he basically said that it needed porting, lingenfelter pulleys, fuel, headers, and tune. Said it would be 700+ and about $6,000. Dont really know anything about these LSA's but I'm not trying to get crazy with the car. Just pep it up. I want to be able to run pump gas and I want it to be reliable. Any suggestions would be greatly appreciated.
Sent from my SM-N975U1 using Tapatalk |
10-16-2019, 02:09 PM | #2 |
Drives: 2012 Silver ZL1 M6 Join Date: May 2019
I would say upper/lower, headers, injectors, and a tune and you would be there.
2012 Chevy Camaro ZL1 M6 504whp/517tq
1997 Honda Accord AKA Beater with the heater. The daily 2015 RAM 1500 (sold) 2014 Mustang GT bolt ons and spray (sold) |
10-16-2019, 06:39 PM | #3 | |
Drives: ZL1, 2013, tri-coat-red, manual Join Date: Nov 2013
You don't need the upper, you can get those numbers with 18% lower, Headers, 1000 + injectors, some sort of fuel pressure assistance i.e (BAP) or alternate pump, CAI, good tune. Suggest Jannety JRE(125 package). You mention 700 plus that would be crank not RWHP, you will be about 630RWHP, and can run on 93. |
10-17-2019, 10:18 AM | #4 | |
No removal of the blower no porting no nonsense just solid reliable power These systems are DIY and include custom tuning for plug and play performance https://jannettyracing.com/collectio...015-camaro-zl1
www.jannettyracing.com
10-17-2019, 12:32 PM | #5 | |
10-17-2019, 02:10 PM | #6 |
fo'shizZL1
Drives: 2017 ZL1 Join Date: Aug 2017
Lower is easier in my opinion, plus you get more belt wrap / surface area that way.
2017 ZL1 M6 Black | Maggie 2650 // 103TB // Big Gulp
Past Rides- 2014 ZL1 M6 Red Hot | Tons of mods 2004 CTS-V M6 Silver | Many mods 1995 Corvette M6 Torch Red | A few more mods 1992 Camaro M5 White | A few mods |
10-17-2019, 02:49 PM | #7 | |
Ted.
11-01-2019, 11:26 AM | #8 |
Drives: 2013 Chevrolet Camaro ZL1 Join Date: Jul 2019
Got a 13 zl1 with 2.4 upper, 10% lower, tap headers, ls3 ported heads, port the stock snout and throttle body. Would be a good idea to get a 102mm throttle body and if so, would I gain any extra hp from it?
11-01-2019, 11:49 AM | #9 | |
fo'shizZL1
If you don't go the cam route, I'd shoot some meth in there, or go to flex fuel. I'm sure you'll get some other good opinions/options, too.
11-02-2019, 07:21 AM | #10 | |
The 102 could be worth 20 RWHP on your combo but you need a Cam package to really make some power and take stress off your engine. Ted.
11-02-2019, 08:07 AM | #11 |
Yes I did forget to mention that I do have a tsp stage 3 cam installed and fic 1000 injectors.
11-02-2019, 10:45 AM | #12 |
fo'shizZL1
Since you have the cam, then yeah, throw that 102 on there. Not sure what intake you have, but I'm assuming it's better than stock.
11-06-2019, 09:08 PM | #13 |
Hi Ted, I've been following this thread. kinda in the same boat. just bought a low mile zl1 and want get some more power. can you explain why having a cam will take stress off the engine. thanks.
2012 zl1 stock 7000 miles
2010 TVS2300, BTR cam PD stage 3, ID1050 injectors, CHE bronze trunnions, 7.400" pushrods,.660" lift platinum springs, Titanium ret, Zl1 fuel pump, Kooks LT headers, High flow cats, Roto Fab CAI, Corsa exh., Mellings oil pump, HD chain, ls2 damper, all synthetic, BMR control arms, zl1 toe link, BMR cradle mounts, W/bottle relocation, air scoop deflector, Hennessy wheels, two piece rotor, morimoto fogs, DRL harness, coilovers, Heads up install, mgw shifter, slps splitter, slp spoiler, zl1 side skirts, painted strips, debadged, tinted, 2018 emblems. Edit Signature |
11-07-2019, 07:21 AM | #14 | |
Boost is a product of restriction. Running a lot of boost (as in the pulley combo above) is a result of 2 things, Superchargers ability to move air VS. Engines ability to move air. We don't want to force feed an engine air it can't move. Boost makes Heat. Heat leads to detonation. Changing the a cam that moves more air, lowers parasitic drag on the blower, reduces heat, which reduces chance of detonation, and just make the engine overall happier. I hope this helps if not feel free to call for a clearer explanation 203-753-7223 Ted.
