Old 06-25-2018, 09:59 PM   #1
camaro_IND
Drives: 2018 M6 1SS
Question Welp.... Car won't Start
Hello All,
I just got don't replacing the complete headlight harness for my car. It is a 2013 LT Camaro w/o RS. After i replaced it the car would not turn on.
So when i insert the key and try to turn on the car it kind of dies. The instrument panel does not show fuel level, tire pressure and any of the stuff.
1.Checked all the wiring and connections to make sure everything was tight and in proper location.
2. Got the battery checked already and it is a healthy battery.
3. All the lights and horns work on the car.
The only thing it is not reading or connecting is the fuel gauges. It is not showing me the directions also i.e. SW/NW/NE etc.
Any help would be greatly appreciated and if nothing will get the car towed to the dealership and have them check it.
It was the aftermarket OEM harness for the headlight. Part number: 22915130
Thank you for any information again.
camaro_IND is offline   Reply With Quote
Old 06-26-2018, 12:34 AM   #2
quickdrraw
quickdrraw's Avatar
Drives: 2015 Z/28
Try reinstalling the old harness to see if the issue continues.
2015 Camaro Z/28 Black
Sold:
2010 Camaro 1SS/RS
quickdrraw is offline   Reply With Quote
