07-16-2018, 03:12 PM | #1 |
Drives: 1993 z28/2010 2SS Join Date: Aug 2015
Cabin filter ?
I’m not sure where to put this, I didn’t even know we had a cabin filter on these cars. I found out it’s under the cowl which is a pain but has anyone ever changed it or how often are we supposed to ?
07-16-2018, 03:25 PM | #2 |
Drives: Camaro and Sierra Join Date: Jul 2012
Takes literally 5 minutes to do. I think there may even be a diy thread on here
07-16-2018, 03:54 PM | #3 |
Drives: 2010 Camaro SS/RS Join Date: Mar 2014
changing it is easy, i think its three push pins that hold the cowl in place. then after that there is a cover that pops off by hand, and then pull the filter out.
i replaced mine with a k&n reuseable filter. its been about a year and so far so good
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53 |
07-16-2018, 03:55 PM | #4 |
Drives: 2015 Z/28, 2015 1LE Join Date: Feb 2017
Does take 5 minutes. And here is from the manual on when to change it. Looks like between certain miles. I change mine every spring though as I don't drive mine in winter and I don't put that many miles on it.
