02-22-2012, 02:36 PM | #1 |
What is the Best 17" Tire for Drag Racing
I plan on getting me some 17" Weld or Bogarts soon and want to know what is the best Tire for drag racing? What size?
Hoosier? Nitto? MT? Thanks for your help !! |
02-22-2012, 03:18 PM | #2 |
Quit being a pu$$y
What gears? Stock rear end? What is your goal 1/4 mile trap? Do you want slicks or drag radials?
02-22-2012, 03:21 PM | #3 |
02-22-2012, 03:40 PM | #4 |
Quit being a pu$$y
No one will agree with me, but with your weight, gear and spraying it I would run a Mt drag radial (27.2" tall) 295/45 17 on a 17x10 wheel.
02-22-2012, 03:41 PM | #5 |
Drives: V10 BMW M5, Supercharged 2SS/RS Join Date: Jun 2010
Hoosier
MT ET streets Nitto In that order.
MAST 416 STROKER: STAGE 3 TVS 2300 CUSTOM CAM TPIS 102 TB IW 8 RIB PULLEY W/ OD COG REARS NX EXPRESS/NANO KIT KDI HEAT EXCHANGER/ROTOFAB RESERVOIR CIRCLE D 2800 TC/FLEX PLATE/ADM TRANS COOLER DSS DRIVESHAFT/1400 HP AXLES EATON TRUETRAC -LPE 3.27 GEARS DYNATECH HEADERS/MAGNAFLOW EXHAUST SQUASH RETURN STYLE FS ID 850's E85/ FLEXFUEL BMR/EIBACH SUSPENSION KILL MODE, ON. |
02-22-2012, 03:45 PM | #6 |
Which Specific Tire for a 10" wheel?
02-22-2012, 06:10 PM | #7 |
Hoosier 28x10-17 (True Drag Slick - Non-DOT) 28" tall
M/T ET Street 26x11.5-17 (DOT Drag Radial) 26.5" tall M/T ET Street Radial II 295/45R17 (DOT Drag Radial) 27.2" tall M&H RaceMaster 325/45R17 (DOT Drag Radial) 28" tall Nitto really doesn't have anything in a 17", unless you want to go down below 26". |
02-22-2012, 06:26 PM | #8 |
Drives: 2010 aqua blue SS/RS M6 Join Date: Feb 2010
The drag slick!
10.91 at 122 H/C stock block N/A
03-13-2012, 09:42 PM | #9 |
Boosted Moderator
K,
I'm most probably going with Welds and the Hoosier 28/10/17 Drag Slick... Without major rear end mods, you cant get a better tire for pure drag racing... (My Opinion) I'm waiting for a response right now from the company Blazzin got his from... I'm looking for four wheels and the tires but I'ld prefer not to go with a real slim "skinny" up front... These cars are too heavy.... (Again, My Opinion) They are fine as long as things are good, but what happens if you get bad sideways...
Horsepower is how fast you hit the wall. Torque is how far you take the wall with you. If everything seems under control, you're just not going fast enough. Mario Andretti If you can turn, you ain't going fast enough... |
03-13-2012, 10:16 PM | #10 |
Drives: SW 2SS/RS M6 Join Date: Jul 2009
03-13-2012, 11:28 PM | #11 |
I have some Weld RT-S's coming with Hoosier Slicks and some skinnies up front so I will see how they do!!
Sent from my PC36100 using Tapatalk |
03-14-2012, 12:48 AM | #12 |
Drives: 2010 2SS/RS RJT Join Date: Jun 2010
Hoosier slicks with M&H Skinny's on Bogarts. 682RWHP(whipple) with a M6. Car and set-up are better than me-for now:/
9.75 @ 139mph, 1.41 60ft, 2010SS, JRE Built!
03-14-2012, 10:28 AM | #13 | |
03-14-2012, 03:51 PM | #14 |
Drives: 2010 1SS Join Date: Jan 2010
Depending on how much power you are talking about, a drag radial will be just fine. Last year we ran consistent mid-1.50 60 ft/times (1.54, 1.55, 1.55, 1.56, 1.58) at 3 different tracks on 305/18" MT ET Street Drag Radials without a hint of tire spin. One benefit of radials is that you don't have to buy front wheels/tires (don't ever mix rear slicks with front radials) so you can save a little money. There are other benefits to running a front skinny too, I am just saying that if you are on a budget you can get away with running the factory front wheels/tires if you use a rear drag radial vs. a slick which requires you to run a bias ply front tire also.
There is nothing wrong with a set of slicks, just pointing out the perks of a drag radial. While there are cars running 7's on a small 275 drag radial, they don't work quite as well on an IRS platform so if the car is making 800+ hp and you plan on spending a lot of time at the track you might as well get a full set of wheels with front skinnies/rear slicks. This will be the absolute lightest setup and will provide the most traction potential. |
Similar Threads | ||||
Weld 17" Drag Wheel & Tire Combo! | Jason 98 TA | Wheels / Tires | 8 | 06-22-2011 11:50 AM |
PZero Repair Question | LADodgerBlueFan | Wheels and Tires Talk Sponsored by The Tire Rack | 11 | 06-01-2011 03:22 PM |
Bogart 17" racing wheels | TC | Wheels and Tires Talk Sponsored by The Tire Rack | 1 | 01-15-2010 08:42 AM |
