07-29-2012, 03:17 PM | #1 |
Drives: 1997 30th Ann. Z28 & 2010 2LT RS Join Date: Jan 2010
RX Catch Can 3000 Mile Results
Just wanted to share a pic with the people that Still don't have a RX Catch Can .
This is what was drained while doing a oil change at 3000 miles . The Car has 13,000 miles on it . I'm using Mobil 1 Synthetic Oil . I still say these are a Must for keeping the oil out of our Manifolds !
07-30-2012, 10:16 AM | #2 |
I see the catch can kept oil out of the intake via the PVC line. Check that breather line coming from the drivers side valve cover going to the intake tube. That's where I have noticed oil is starting to enter mine at.
07-30-2012, 10:22 AM | #3 |
having FUN now 13.66@101
Nice to know that oil is NOT getting ingested into the engine. Remember folks this 3.6 L is not a two-stroke and does not require oil in the upper end thru the air intake.
07-30-2012, 10:48 AM | #4 |
Drives: '15 Z06, '01 NBM SS, '97 SS Join Date: May 2009
...who says Catch Cans aren't worth it. LOL
Yeah, like we want that in there. :/ Ivan |
07-30-2012, 11:40 AM | #5 |
I don't have that tube installed anymore .. Have the RX breather so that plastic line was Deleted .
07-30-2012, 11:52 AM | #6 |
Drives: 11 IBM n White 2SS/RS M6 Join Date: May 2011
My question is:
why is a bit of oil consumption bad thru the motor?? |
07-30-2012, 12:31 PM | #7 |
It accumulates on the valves. The direct injected motors cannot clean the valves and gunk since the gas with additives is injected directly.
07-30-2012, 03:57 PM | #8 |
Drives: 2012 Camaro RS, RX supercharged Join Date: Dec 2009
Also any oil in the intake air charge results in less power produced as oil does not burn well. You want onlu air and fuel. Take some motor oil (your brand you use) and pour it into a bowel and try to light it on fire. It wont. So it reduces the power released per explosive event, and thus poor fuel economy as well. That and it causes detonation (spark knock from the incomplete burn) so the ECU picks this up and pulls timing.
Unless it is specially formulated 2 stroke oil designed to burn clean. Here are pictures of what happens to your valves: |
07-30-2012, 06:18 PM | #9 |
Good enough answers! Thanx catch can on the list
Sent from my DROID X2 using Tapatalk 2
Black CIA -Powder Coated Red Air Scoop - Vmax Ported Throttle Body - Ceramic Coated Dynatek Headers - High Flow Cats out thru factory Cat Back - JRE rough idle cam package - Trunion Upgrade - Valve Springs - Hardened Push rods - 3 bolt timing gear - SLP Under drive pully- Washer bottle relo kit - Hurst Short Throw Shifter with updated pin bushing from C5 member NH-SS - IdealG's improved Master Cylinder - GTO Clutch reservoir - L99 Brake Reservoir - Stainless Braided clutch line - wrapped up with a JRE Tune My SS layed down 462 hp on JRE's Superflow Dyno
07-31-2012, 08:32 AM | #10 |
Ok so next ? on the docket is what can I use as a fuel additive to prevent / clean up any deposits there is??
RX Catch Can ordered Last edited by RogerBzSS; 07-31-2012 at 09:19 AM. |
07-31-2012, 09:01 PM | #11 |
Drives: 2012 2LS V6 Camaro Join Date: Jun 2012
Say I get a catch can. What do I use to clean my intake after I install it? I have the composite intake, LFX V6.
09-05-2012, 02:03 PM | #12 |
Drives: 2012 2LT/RS Join Date: May 2012
is it hard to install a catch can ? and why didn't this come from the manufacture with a catch can ? i dont see how chevy is ok with that much oil being sucked onto the manifolds
09-05-2012, 02:14 PM | #13 | |
You can probably use seafoam additive in the gas tank that works ok also Definately get a catch can when you can though
2010 Camaro SS Whipple SC, CAI Inc Intake, TSP 1 7/8" LT headers no cats, 3" magnaflow exhaust, HPT, RX Catch Can, LSR Toe Rods, LSR Trailing Arms, ALKY Control Meth, McLeod RXT Twin Disc, ZL1 fuel pump, 3.73 ZL1 Differential Kit, BTR PDS Stage 2 Cam, Tuned by SLOWHAWK Performance Bridgewater MA
09-05-2012, 02:16 PM | #14 |
Drives: Anything Blown Join Date: Aug 2010
Awesome thread! SCC offers RX too!
