02-01-2015, 09:42 AM | #1 |
Drives: '13 Hot Wheels SS Join Date: Aug 2012
More superchargered than turbocharged
It seems to me there are so many more supercharged camaros than there are turbocharged camaros. Is that just because of maintence/price?
02-01-2015, 09:46 AM | #2 |
USAF retired! Thank God!
Drives: 2011 1SS, 1LT red,1LT/RS SGM 98Z28 Join Date: Jul 2011
I'd say more a combination of intimidation and lack of knowlege
HKE LSX427(Mast blk lbl 305 6bolt LS7heads, PatG231/246 blower cam, RWHP/TQ: 1281/1133 SNL Performance Custom Twin PT6766 BB turbos 4 to 25psi selectable on the Boost Leash controller, Squash dual 400LPH/ID2000s, ALKY 4 gal meth, Autometer AFR/Bst/oilpres/oiltemp/fuelpress gauges, Pedders Justice road crs pkg: All HD bushes, supercar 12kg coil overs, supercar ZL1 sways, camber plates all setup by JusticePete! :Gforce 9" 35spline S-Trac, 1500hp Outlaw axles, 3.5"alum DS, Monster Triple disc; 4xForgeline 19x10.5 4xBridgestone 305/30R19 RE-11, CTS-v calipers/rotors/Cobalt friction XR1/3 pads
02-01-2015, 10:18 AM | #3 |
Served USN - Atomic Chimp
Drives: 13 Camaro LSX434 TT M6, 21 ZLE A10 Join Date: Jul 2012
In excess of 1,000WHP LSX434 | AGP 65/65 TT | BTR Equalizer Intake | Trickflow 245cc cathedral | BTR custom cam | Cortex EBC | n2mb WOT | ID-1700x | Brisk GR12S | RPM Lv 7 TR6060 | AGP's Triple 525LPH Fore Fuel | Monster LT1-S Triple | 4.11 DSS Proform 9", CF driveshaft, 1400hp axles | Hurst Line Lock | MGW Retro Short Throw w/old skool Hurst T-handle | ADM solid subframe mounts | Prothane Motor Mounts | Revshift Poly Trans insert | Moreno camber/caster plates |
02-01-2015, 10:28 AM | #4 |
Drives: 2011 Camaro SS/M6 Join Date: Dec 2013
I personally think it's because superchargers for the 5th gen have been out since day 1 for the most part. Legitimate twin turbo kits have been late to the party. I'm sure if the Agp kit was available back in 2010 almost everyone would have it.
2011 Ls3. Slp TSV2300. 8PSI. 3.4 Pulley. Livernois Twin Fuel Pump. Id850 Injectors. Slp 1 3/4 headers. CAI Cold Air Intake. 3inch exhaust. V-Maxx portted throttle body. Night Fury cam. Lpe 391 gears. Fj performence tune. 643rwhp 574rwtq
02-01-2015, 10:29 AM | #5 |
Drives: Maggie blown LS3 vette Join Date: Aug 2009
Some just really, sincerely, don't want to fool with a set of turbo's and all that goes with them. Plain and simple.
02-01-2015, 10:50 AM | #6 |
SC kits have been out since day one. SC manufacturers have huge marketing budgets, sales reps, distributors. Only AGP really has a sales network, but it isn't like they have paid sales people going out to shops taking them to lunch and offering incentives to sale their kits. Misconceptions are a big part of it, but that is slowly changing.
A set of turbos has no more maintenance, or stuff to fool with compared to any other FI system. A lot shops push what they make the most money off of, not what is best for the customer.
Nick
Corvette Z06 -1200ish rwhp |
02-01-2015, 11:07 AM | #7 |
Centri blowers are more common because of price.
02-01-2015, 01:01 PM | #8 |
Depends on what style of driving you're looking for out of your car. Positive displacement blowers give you that great low end grunt but suffer from heat-related efficiency issues. Centrifugal blowers come on in a fairly linear fashion throughout the power curve. They make a lot of sense for road-racing and drag racing. They're a bit easier to hook up coming back out of a corner or from a launch. Turbos don't give you much below 3000 rpm or so but once the boost spools up it's all in.
02-01-2015, 02:41 PM | #9 |
Ugh, no. Making generalization like that is silly.
Not all PD blower sugger heat issues. No all centris come on only top, and turbos can spool anywhere you design the system for. Want full boost at 1500rpm, just select the correct turbos for that.
Nick
02-01-2015, 02:49 PM | #10 |
LSX Bumblebee
Hard to find a good twin turbo kit that is C.A.R.B approved.
02-01-2015, 05:04 PM | #11 | |
A centrifugal, same as a PD, is a mechanically driven and is building boost from idle to redline relative to engine RPM. Yes, peak boost is at redline but they are spooling up throughout the curve. In situations where traction is at a premium the slower build of boost can be advantageous. Now, a centri like the Procharger i-1 with its CVT can give you a near-turbo like torque curve with instant, full boost at any RPM. I don't disagree that a turbo, or a pair of turbos, can be selected to obtain max boost at 1500 rpm. But being small enough to be brought up to speed at that RPM poses a risk of being restrictive at higher RPMs. This, of course, does not take into account variable vane turbos or running a pair of big/small turbos in sequence which could help mitigate that issue. But, again it is generally accepted that turbos will not give much help below the RPM required to get them spinning. |
02-01-2015, 07:04 PM | #12 |
Watch This!
Drives: Super Charged 1SS/RS, M6, CGM Join Date: Dec 2009
I chose the MagnaCharger, because I wanted to do my own install and from my research, it appeared to be the easiest install (less plumbing, etc.) and their install instructions were very good, and the Maggie appeared to give the best useable torq and HP across the powerband. That was 2010, now I'd probably consider the TT but I'd probably stay with the Magnuson.
K&N CAI, Wet Okole Seat Covers, MagnaFlow Street Perf. Ex. (Axle Back), MPD Hood, Gary's Customz ZL1 Fascia/Vented Fenders/Custom Stripes/Paint, AAC Afterburners/Fog Light Halos/Side Markers/Misc LEDs, Bee-Otch Air Freshener, Hurst Shifter and Line-Loc(APEX), RPI Splash Guards, MagnaCharger (Texas-Speed)(Installed by ME), Rx Catch Can and Breather, Billet Pulleys (SC2150), ARH Headers, LPE Twin Fuel Pump, Custom Blower Cam, Custom Tune TBArwhp, TBArwtorq, Boost Gauge and Single Pod (MTI)
02-01-2015, 08:03 PM | #13 |
Drives: 2011 Camaro SS Join Date: Jan 2015
It generally seems like there's more going wrong with the setups on turbo systems. Hot side leaks can be a disaster. Ton more heat and all the headaches associated with that. Oil lines and pressure needing to be right.
Supercharger you bolt on and hope the belts don't shred. But at least it's all on the front and top. I know, lots of generalizations in my post. |
02-01-2015, 09:17 PM | #14 |
Centri has a lot less belt slip issues compared to PD blowers too because of the mass.
