08-08-2015, 05:50 PM | #1 |
Drives: 14 1Le --14 chevy ss sedan 07shelby Join Date: Sep 2014
who has 700 rwhp + stock bottom ?how long
who has been running 700+ on stock ls3 and for how long !!!
08-08-2015, 06:45 PM | #2 |
Drives: 2012 SS Join Date: Sep 2012
8 months
08-08-2015, 06:48 PM | #3 |
cool thanks
08-08-2015, 06:59 PM | #4 |
Drives: 2011 2SS Convertible Supercharged Join Date: Nov 2010
5 months still going strong
08-08-2015, 07:20 PM | #5 |
Sittin side ways
Drives: 2010 2SS/RS IOM Join Date: Nov 2012
20+ months here.
850+hp club member
Procharger F1-A |
08-08-2015, 07:47 PM | #6 |
Drives: 2013 1le Join Date: Nov 2012
Stock block and Pistons
08-08-2015, 08:08 PM | #7 |
Drives: 67RS Camaro ,Black 2013 ZL1 Join Date: Jun 2010
A better question might to ask how many miles on your stock bottom end To many Dyno queens on here don't get driven, only polished.
08-08-2015, 08:30 PM | #8 |
Watch This!
Drives: Super Charged 1SS/RS, M6, CGM Join Date: Dec 2009
I was at 45k in the 550-600 rwhp range, and now at 625+ for 5k more. No issues with motor, Clutches, I've toasted two.
K&N CAI, Wet Okole Seat Covers, MagnaFlow Street Perf. Ex. (Axle Back), MPD Hood, Gary's Customz ZL1 Fascia/Vented Fenders/Custom Stripes/Paint, AAC Afterburners/Fog Light Halos/Side Markers/Misc LEDs, Bee-Otch Air Freshener, Hurst Shifter and Line-Loc(APEX), RPI Splash Guards, MagnaCharger (Texas-Speed)(Installed by ME), Rx Catch Can and Breather, Billet Pulleys (SC2150), ARH Headers, LPE Twin Fuel Pump, Custom Blower Cam, Custom Tune TBArwhp, TBArwtorq, Boost Gauge and Single Pod (MTI)
08-09-2015, 04:38 PM | #9 |
Too much is never enough!
Im was close to 800 for just over ten thousand miles when I had my failure, still dont know if it was valve train or bottom end. I do not believe mine was a hp related failure.
08-09-2015, 05:52 PM | #10 |
Let us know what happened is it a total lose ?
08-09-2015, 07:53 PM | #11 |
The car started missing a little bit intermittently.Felt like a loaded plug, I got into it and then the noise started. Most likely when I put the car into boost, at the same time I was down a cylinder.
If you mean total loss as in bottom end. Then it will be till september till I know for sure. Wont have the car back to FSP till then. I am already planning on either doing an LSX or a forged sleeved LS3. So it really doesnt matter if its a bottom end issue or not.
08-09-2015, 09:28 PM | #12 |
Working on my 2nd one!
5,500 miles with 732rwhp on stock only reason I went to the 9" was the 800 - 1000 increase in HP. LS3 with Whipple to lsx with twins
[SIGPIC][/SIGPIC]
08-09-2015, 10:09 PM | #13 |
Drives: 2010 SS/RS LS3 M6 Join Date: Apr 2011
8,000 miles at 700, then another 3,000 so far 800+.
08-09-2015, 11:08 PM | #14 |
60k miles at 9psi or more.
