03-05-2014, 09:27 AM | #1 |
Drives: none Join Date: Oct 2012
GT9 Cam HP Gain
Using the Lingenfelter GT9 Cam over the stock cam what HP gains are you looking at in the low/middle/top versus the stock cam with stock boost and 18-30% over drive boost?
I've read it's worth about 20-30hp....if so thats nothing, seems not even worth it all the effort and money for very little. Anyone have a dyno comparison to the stock cam? Dyno's that say 700HP with the GT9 cam wont cut it thats not a comparison |
03-05-2014, 10:43 AM | #2 |
Drives: 2013 ZL1 Join Date: Oct 2011
I would pick a cam with different profile myself. why not just have one ground base on you mods???
cam is a mod IMO after you do many other things. to get to 700whp you will have to have one but the labor involved makes other mods make more sense first IMO. I have seen a couple cars hit 700hp with no headwork so in those combinations seem like cam is proabably bring 40-50hp. it is so dependant on other mods as well though. a pulley is way more ban for the buck than a cam if paying for labor, headers give good HP for ease of install. cai TB are just easy. cam IMO is all about goals. if you want 700hp you pretty much ahve to have it. if you want a bottom 10 second car you almost have to have it you can get there with porting options as well and no cam. if you just want a fast car you don't have to do it. fi you like a lopy idle you have to have one. now if you turn you own wrench and are willing to do then a cam is good HP for dollar. the minute you pay someone else to do it it only pencils out if you need over 640ish hp. IMO I keep goint back and forth but I am temped to just trying ported snout, upper pulley (have lower already), 102MMtb, headers. this gets you pretty good power with real minimal labor. I am not going for an all out build though focused on 700hp dyno sheet. at some point though porting and cam just become something you have to do to go farther.
shopping for 2017+1le or zl1
2009 CTS-V -sold 2015 Hellcat-sold 2013 ZL1 -sold 2007 Z06- sold 2014 Chrysler 300 2011 Duramax 8" lift, deleted tuned |
03-05-2014, 12:01 PM | #3 |
mods will be:
ported heads ported snout ported supercharger 102 throttle body lower pulley 18% 1" 7/8 headers exhaust really wondering on that combo what the difference a cam will make, yes im thinking hey the heads are off why not do the cam but if its only 30HP thats only 30HP which also includes all new head gear too + yes the labor which i can do myself to change the cam....however as you know it's now quick easy cam swap with the engine in the car, loads of stuff in the way. So when you are talking all new springs, locks, retainers, cam...may as well change the pushrods while you are there too $$$$ for what 30-50hp |
03-05-2014, 12:07 PM | #4 |
Drives: 13 ZL1 vert blac fastlane/LPE 750 Join Date: Jul 2011
One thing you have to understand about a cam,its not about the peak Hp numbers,which a lot of people throw around...Its about the Avg Hp numbers,and the curve...I would rather give up 10 rwhp peak with one cam and gain 50 rwhp over the whole band...
http://www.camaro5.com/forums/showthread.php?t=346589 CHECK OUT THE BUILDING OF MY RANCH FOR DISABLED VETS, COMPLETE WITH A GUN RANGE .
03-05-2014, 12:11 PM | #5 |
Drives: CTS-V Join Date: Jan 2013
the right cam easily gains 40-50 RWHP with ease
03-05-2014, 12:32 PM | #6 |
Drives: 02 Z06, 95 Trans Am, 2012 ZL1 Join Date: Mar 2012
BTR stg III will be worth 70 hp with those mods. Eric Holdener recently did a back to back test of the common blower cams. LS9 lost low end torque compared to stock LSA cam. BTR stage III gained power everywhere.
And a GT9 will tear up valve stems tips very quickly. Seen some guys on LS1tech pull GT9 cams out after only 3000 miles and damage was already done.
Bryan 2018 ZL1 M6
03-05-2014, 12:50 PM | #7 | |
it is a no brainer to me on that mod list. the amount of money porting a blower cost and portign heads cost why not do the cam. should net you more HP than either of those mods fro similar money.
03-05-2014, 01:07 PM | #8 |
I have access to a cnc so cost isn't the issue there
03-05-2014, 01:09 PM | #9 | |
Bryan 2018 ZL1 M6
03-05-2014, 02:31 PM | #10 |
even better take the 1k you saved and buy the cam ha ha.
03-05-2014, 02:48 PM | #11 |
Just having access to a CNC isn't enough. You need a properly developed digital port file for the LSA heads. Even then you still need a machine shop to do the valve job, finish hand blending and assembly. If you could do all that yourself I wouldn't think you would be in here asking questions about what cam to use.
Bryan 2018 ZL1 M6
03-05-2014, 07:31 PM | #12 | |
lol
03-06-2014, 08:26 AM | #13 | |||
Drives: '12 ZL1 #1609 Join Date: Feb 2010
Valve Springs Spring Seats Valve Seals Locks Retainers LS Trunion Upgrade Crankbolt Cam Sprocket Bolt Timing Cover Gasket Front Crank Seal Camshaft Timing Chain Gear Hardened Pushrods Here is the link: http://www.jreperformanceparts.com/2...m-package.html
Life is too short to drive cars that suck.
My build Thread |
03-06-2014, 01:31 PM | #14 | |
