Old 10-28-2021, 12:29 PM   #1
eLeSthree
Drives: 2011 Camaro SS 6sp
Balancing weights on 15inch wheels, no clearance
I have Carlyle/Wilwood brake calipers in the rear that come in the Carlyle 15 inch conversion kits. Then I have BMRs lower control arms. The LCAs give more clearance than the carlyle lcas. I'm running Racestar 15x10 wheels with 7.5 inch backspacing.
When balancing my tires they use the low profile weights with the thin double sided tape, and they still hit my calipers. Within a mile they all flew off.
I'm sure there are guys running these wheels, so how do you balance your tires?
Can the weights be placed on the inside edge of the tire instead of near the brake caliper? I've never used a balancing machine before but id imagine it tells you where to place a certain amount of lead.
2011 Camaro SS---SOLD
TMS Dart 427 FED M311s, ESS Tuning G4 Blower, DSX Triple FP Assembly, DSX FF, FIC1300, Mcleod RXT 1200HD, Edlebrock Pro Flo XT
1158whp 1017wtq.
2010 CTS-V A6 - "Stock" SOLD
630whp 658wtq
2024 F-150 RCSB 5.0 4x4
waiting for tunes...
eLeSthree is offline   Reply With Quote
Old 10-29-2021, 02:55 PM   #2
Pro Stock John
Writer
Pro Stock John's Avatar
Drives: 2010 SS / 1967 Camaro
Been there. I have the tire shop put the weight towards the inside, you just have to explain why.
PROJECT HEAVY CHEVY
13.15@106 1.95 | 100% Stock
Old 10-30-2021, 08:29 AM   #3
Camaro2ss2010
Camaro2ss2010's Avatar
Drives: 2010 Camaro 2SSRS M6
I run balancing beads in my truck and am thinking about swapping my car to them. No weights to worry about when you do that and they don’t have to be rebalanced again. I have had good success with them in my truck tires(35x12.50x20).
ECS supercharger, custom ground cam, ported throttle body, long tube headers, aeromotive fuel pump, fic injectors, ATI super damper, Corsa Extreme exhaust, elite engineering catch can and many other things.
Camaro2ss2010 is offline   Reply With Quote
