10-31-2012, 01:30 PM | #1 |
3000 hp 648 ci beast
Drives: 86 Outlaw 10.5 Camaro, 2SS/RS LS3 Join Date: Jul 2009
47 lb bausch injectors
Brand new pink bausch injectors out of a Maggi 1900 blower kit I just installed on a Silverado. Went with a cam and smaller pulley and bigger injectors right from the start. They have never had fuel ran thru them. Bausch part number is 0280156030. Flow info I found says they flow 40.8 lbs at 3 bar and 47.1 lbs at 4 bar (58psi). They are 48.7mm oring to oring or about .5" longer than a stock LS3 injector. EV6 connector or same as LS3. Maggi just had a .5 spacer under the rails to make them fit.
$200 shipped in 48 states
2SS/RS, LS3, 6M, IOM w/black hockey, IO interior, sunroof
mods: ******** setup. Whipple supercharger....Need suspension upgrades now... 4" stroker kit, ARH, cam on my wish list. |
11-19-2012, 12:00 PM | #2 |
bump bump
