05-16-2018, 08:53 AM | #1 |
Drives: 2010 Camaro 2SS/RS ABM 6M Join Date: Jul 2017
Suspension newbie needing some help
So since I have gotten this car, my main focus has been getting some more power under my right foot. Now that that has been accomplished, I thought it was time to shift the focus elsewhere for a bit. I will preface by saying this is 99% a street car. I want to take it to the drag strip at some point, but it isn't going to live there. That said, I don't drive it often so when I do, it's pretty...ahem..."spirited" driving. And I would like it to stay in one piece when I do hit the strip. Especially after I get some meats on the rear.
I recently purchased a 3.91 rear end, and will be doing that swap relatively soon. What I want to know is, what should I be looking at to upgrade suspension-wise while I am back there to help keep from breaking parts? So far suspension is 100% stock. Everyone talks about wheel hop like it always happens but I haven't noticed anything hop-wise sitting in the driver's seat I have read that upgrading the rear cradle bushings is a must, so I thought about dropping the cradle down when I swap diffs and doing new bushings. Do I want to go with something like this that also has differential bushings while it is going in and out? https://www.phastekperformance.com/2...hing-bk030.htm Thanks in advance for any and all help! Just trying to narrow down what is best to do now to minimize double work going back in again later. Thanks for any and all input?
2010 ABM 2SS/RS LS3 6 Speed -- Rotofab CAI | Speed Engineering 1 7/8" Longtubes w/ cat Delete | Magnaflow competition catback | TSP 231/246 cam| TSP/PAC .660" Spring Kit | TSP CNC Ported Heads | Bo White PTB | GPI Ported/RM Intake | 3.91's | BC Catch Can | MGW Shifter | BMR 1" Drop Springs | BMR Trailing arms/Toe Rods/Rear UCA Bushings | Pegasus Subframe Mounts
05-16-2018, 10:47 AM | #2 |
Drives: 2015 Z/22 Join Date: Aug 2015
For spirited driving/light track use, the two best mods you can do for better stability/cornering are the newer style rear bar (also requires 2012+ rear lower control arms and drop-links) and the subframe bushings.
If you do the rear bar you may also want to consider replacing the front bar with a bigger one as well, to balance the front and rear; you could go with the factory SS bar up front and a ZL1 bar in the rear, or go aftermarket for both such as JPSS's 27mm front, 32mm rear bars. I went with Pegasus' solid subframe bushings and noticed a big difference in reduced roll/tire hop even after installing the JPSS bars. JPSS also has (or will soon have) solid bushings.
05-16-2018, 11:37 AM | #3 | |
I have seen solid bushings. Quite a bit more money though. Wasn't planning to buy rear end this soon so my funds are somewhat limited right now. Are they a worthy upgrade over the poly unit I linked for my style of driving? I also see for the diff bushings that there is the red "pro" version in that kit, or a black "street" version. Is either of these better for my use while I am in there? They both have a similar description other than the durometer ratings
05-16-2018, 12:28 PM | #4 |
Drives: 2010 2SS/RS Join Date: Dec 2009
Still do the cradle bushings and upgrade all your rear suspension links to ZL1/1LE/Z28 parts it will keep those all in check and if your not doing any crazy turns probably a smaller bar for the front to help weight transfer.
I would get a set of Z28 front control arms or JPSS inserts to keep your front end in check also helps keep the steering a little more precise. You might want to find a Tru Trac or a used Z28 LSD there was a few in the classifieds they are a helical design for better traction management. I run the 1LE axles and Ive done road course and Auto X not sure if the Z28 has bigger axles or not but OEM pieces are pretty good up through Z28 HP Levels, and depends how deep your wallet is. https://www.camaro5.com/forums/showthread.php?t=528164 https://www.camaro5.com/forums/showt...&highlight=Z28
Orange Krush II
05-16-2018, 05:06 PM | #5 |
Drives: 2010 SS 2SS M6 Join Date: Aug 2016
my sig...
peace
05-16-2018, 05:22 PM | #6 |
Even for drag racing the new, bigger rear bar and solid subframe bushings will help keep the rear tires planted. As mentioned, stiffer toe links and trailing arms, and stiffer upper control arm and trailing arm bushings will all help keep the rear tight and reduce dynamic toe/camber movement. I wouldn't bother with the differential bushings unless it's a strict racing car due to the extra noise and vibration
05-16-2018, 06:40 PM | #7 | ||
Well as much power as I plan on putting down in the future, I think I will need more than the subframe inserts on the rear, won't I? And I see the 1LE axles..are those an upgrade to the SS axle? And if so, are they a direct bolt in? Quote:
05-16-2018, 09:14 PM | #8 |
I went with solid and definitely can't complain , very little if any increased vibrations/noise, however, if this is a daily driver and you put on a lot of miles you may want to consider polyurethane as the subframe wasn't designed for solid bushings and, therefore, may eventually fail (the welds/joints) if pushed real hard (although in your case as you described, I don't think that'll be an issue).
The upper control arm bushings, if you choose to do them, will be considerably easier with the cradle lowered; with that said it is fairly easy to lower the cradle when needed - I did all of my suspension work in the driveway with jack stands. The rest of the arms/bushings can be done separately easy enough. I would leave the stock diff bushings in place.
05-16-2018, 11:01 PM | #9 |
A Z28 diff case is the same as the SS as are the axles the only difference in axles comes in are V6 and ZL1 cars.
But you can buy a Z28 or TruTrac helical diff and get away from 1 tire fire. I noticed when I swapped my cradle bushings it seemed like the car accelerated better since the cradle didn't have to wind up, and don't think you'll get cradle failure most of the vibes will be transmitted through the diff into the cradle not just the cradle into the car.
Orange Krush II
05-16-2018, 11:10 PM | #10 |
look again...BMR T/A's and bushing... And I see the 1LE axles..are those an upgrade to the SS axle? And if so, are they a direct bolt in? yup! and a lot of peeps don't give enough credit to the motor mounts....yeah, yeah..stock is fine...any way go ask Jannetty what they put on every F/I car the put on the street...prothane. peace
05-17-2018, 10:22 AM | #11 | ||
I guess if I start having issues with the 1 tire, I can always have the diff inside upgraded. So far, I'm not having any issues there. Though this new diff may be a different story Quote:
Right, I see that..but those can be done later can't they? You said check sig like that was the stuff I needed.. but I am thinking about cradle mounts that we are currently talking about, the inserts you have are probably not enough right? and a lot of peeps don't give enough credit to the motor mounts....yeah, yeah..stock is fine...any way go ask Jannetty what they put on every F/I car the put on the street...prothane.. I am curious how the motor mounts help the rear end stay together? It seems like it would be easiest to wait until I pull the motor, and then do the mounts then. Or can they be done semi-easily with engine in the car? Not that they aren't needed...but just because a shop puts something on every car doesn't mean its an end-all be-all thing. Usually that just means it's an easy sell to make a few more $$$ on the deal. Or a least a piece of mind over necessity kind of thing. Still something I can sure look into then.
05-17-2018, 11:57 AM | #12 | |
Drives: Race Car Join Date: Sep 2009
Those Cradle Bushings are Great, but I don't recommend the Diff Bushings for 99% of people. Cradle Bushings you can go as hard as you want with no problem, Diff Bushings anything harder than Stock and you will get some form of NVH, sometimes pretty severe. |
05-17-2018, 12:01 PM | #13 | |
Can they be done later? Sure, but you are right there and why would you want to double or triple your labor |
05-17-2018, 04:44 PM | #14 | |
And as to WHY I would want to do them later? Simple.. $$$$$, or lack thereof Wasn't even planning to buy rear end right now, and budget is still recouping from the cam swap lol. If it isn't imperative to do it while the cradle is down, I can go back and replace other parts as money allows me too. You are probably the person to ask. What kind of RWHP level would you recommend someone jumping from your poly cradle bushings to a solid metal unit? Bonus dumb question on my end....what is NVH?
