01-31-2019, 10:50 AM | #1 |
Drives: 2010 Camaro 2SS/RS ABM 6M Join Date: Jul 2017
Offset diff bushings for 1" drop?
Hey guys,
Getting ready to pull the trigger on my suspension stuff that I am wanting to do this winter while I am not driving the car much. But, I have a question..at what point do you need offset diff bushings to correct dropping the car? Mods list for the moment - Pegasus solid subframe mounts BMR Rear trailing arms BMR Toe rods BMR Rear upper control arm bushings BMR 1" lowering springs Just wondering if the 1" drop is enough to need to change out the diff bushings? Or if the stock ones will be fine? Car is mostly a street car, but I plan to occasionally take it to the track as well (hence getting the rear end stiffened up). Sounds like a lot of the NVH comes from the diff bushings, so if stock will suffice, I would like to keep it that way (for now at least) Thanks!
2010 ABM 2SS/RS LS3 6 Speed -- Rotofab CAI | Speed Engineering 1 7/8" Longtubes w/ cat Delete | Magnaflow competition catback | TSP 231/246 cam| TSP/PAC .660" Spring Kit | TSP CNC Ported Heads | Bo White PTB | GPI Ported/RM Intake | 3.91's | BC Catch Can | MGW Shifter | BMR 1" Drop Springs | BMR Trailing arms/Toe Rods/Rear UCA Bushings | Pegasus Subframe Mounts
01-31-2019, 11:13 AM | #2 |
SoCal Camaro5 Race Team
Drives: 2021 Shadow Grey Camaro 2SS 1LE Join Date: Mar 2010
Not needed. Unless you want to stiffen it up, but that will be felt and heard. I have the parts you do by the way.
01-31-2019, 04:18 PM | #3 |
Drives: 2020 ZL1 1LE Join Date: Sep 2012
I didn't like the driveshaft angles myself with a 1" drop. If you can I would change the bushings. Yes, it is acceptable without the bushings change.
2020 ZL1 1LE [Moroso SC Expansion Tank, otherwise stock]
01-31-2019, 05:06 PM | #4 |
'It's an experiment'
I road race and my drivers axle popped out at NCM. I had offset diff bushings installed (delrin) afterwards...
Was lowered 1"... -Don
747 RWHP 794 RWTQ
01-31-2019, 11:01 PM | #5 |
Follow the advise here if you are doing road courses . Street and autocross 1” in the rear or 660mm overall height max drop is fine.
02-01-2019, 09:42 AM | #6 |
Definitely not doing road courses or anything! Mostly just ripping around on the street on the rare occasions it even leaves the garage. So, sounds like I will probably leave them alone, at least for now. One of these days I planned to get an LPW cover for the diff before she gets some boost, so that may be a good time to add the offset bushings down the road.
Thanks guys!
