02-07-2020, 10:42 AM | #1 |
SEAHAWKS FOR LIFE!!
I Come Back From The Dealer And...
So i got my oil changed at the dealer with tire check and multipoint inspection and underhood clean and all that good stuff like fluid top off, and they come back saying they saw some spotting of oil on the cover of the engine (the plastic one on V6) and they are quoteing me for $1,300 for something i dont even know what it is so what do you guys think. P.S i will get picture asap of the multi point inspection so you all can see. Im sad for my camaro
02-07-2020, 10:49 AM | #2 |
Drives: 2010 Camaro SS2,L99, LSA SC Join Date: Aug 2017
Stop going to dealers for anything not warranty work.
02-07-2020, 10:50 AM | #3 |
SHKE BKE
Drives: 2013 Camaro Join Date: May 2014
They didn't give you the part name?
02-07-2020, 10:51 AM | #4 |
Drives: 2011 Camaro 2SS LS3 Whipple Join Date: May 2019
Front timing cover?? That is a fairly large job.
02-07-2020, 10:57 AM | #5 | |
376 cubic inches of fun
02-07-2020, 11:01 AM | #6 |
SEAHAWKS FOR LIFE!!
02-07-2020, 11:45 AM | #7 |
15 Year LS1Tech Member
Drives: 2010 ss 391ci LS3 Join Date: Apr 2017
Lol well did you learn your lesson at least?
GJDM |
02-07-2020, 12:05 PM | #8 |
Drives: 2012 Camaro 2LT & 2016 Camaro 2SS Join Date: Feb 2020
I rarely ever go to the dealer always do my own work, unless you have an warranty issue. Hard to say anything atm with the lack of info.
02-07-2020, 12:17 PM | #9 |
SEAHAWKS FOR LIFE!!
02-07-2020, 02:11 PM | #10 |
Drives: 2017 Mosaic Bk ZL1 M6 Join Date: Jul 2009
Dealer should be able to tell you if they gave you a quote to fix it.
02-07-2020, 02:31 PM | #11 |
Drives: 2014 2LT RS Summit White Join Date: Apr 2017
Didn’t you just post a week ago about your Camaro misfiring and chugging at a stop light? Are the two things possibly related?
02-07-2020, 04:37 PM | #12 |
Banned
Drives: 2015 Camaro Join Date: Aug 2018
If it's spotting on the cover, that means the oil leak is up top or being flung from somewhere down below.
02-07-2020, 04:39 PM | #13 |
Drives: 2012 Victory Red LFX Join Date: Dec 2012
I'm doubting the ability of your dealer and from what you said they have charged you for some hail mary guesses before. Might this not be another?
IIRC correctly they replaced both engine and motor mounts to fix the chugging which fixed nothing. BTW what exactly was causing that problem?
2018 SS wheels, red Heritage grille, actual driving lights, ZL1 strut tower brace, GM Performance billet aluminum fuel door, front grille Bowtie delete, painted red rotors and calipers, 1/4 window American Flags, splash guards, AEM dry panel air filter.
02-07-2020, 08:05 PM | #14 |
Repeat after me.. Stealership!
