06-22-2021, 11:31 AM | #1 |
Drives: 1987 Camaro Join Date: Apr 2019
rear end brake question for a 87 Camao
Do you need a proportioning valve at all when you convert from drum to disk on the rear of a 87 Camaro, making it disk brakes front and back. Can you hard line the rear disks or should I put rubber hose at the end . I can use the existing line if I can use stainless all the way if I don't need a hose on the end.
06-22-2021, 01:37 PM | #2 |
You might want to ask in the 3rd gen forum. I'm sue some folks have done this and can answer for you. GL
https://www.camaro5.com/forums/forumdisplay.php?f=33
