06-27-2021, 12:48 AM | #1 |
Drives: zl1 5th gen Join Date: Oct 2020
I did something really dumb..
I was trying to do a DIY brake job because I wanted to save the $
andddd yea, pulled a "mekanik". I mistakenly disassembled my passenger side front caliper to the point where brake fluid dripped out of the bottom and the two halves were able to rotate independently because I took out the 4 screws that hold the caliper together. Do I need to put loctite on those bolts since I broke them free? What type of loctite should I use? Anything else I need to do? Brake bleed I know, but what about brake flush since contaminants could have gotten in? Should I anti-seize the two halves? |
06-27-2021, 12:50 AM | #2 |
The caliper housing bolts are what I took out by mistake. What torque value is it on a 2016 camaro 2ss?
06-27-2021, 01:02 AM | #3 |
........I need a whole new caliper, don't I
06-27-2021, 03:41 AM | #4 |
Banned
Drives: 2010 LS Join Date: Feb 2021
06-27-2021, 10:18 PM | #5 |
Drives: 2010 2SS/RS Join Date: Dec 2009
No you don’t need a new caliper an goto YouTube an look for Brembo videos either maintenance or powder coating.
Orange Krush II
07-01-2021, 05:58 PM | #6 |
Drives: 2011 2SS, 2006 GMC Sierra Join Date: Jul 2019
If you removed the four bolts the hold the two halves together you need a rebuilt kit or a new caliper. There's seals between the two halves. You show you drive a 5th gen ZL1 if I remember correctly the ZL1 had a 6 piston one piece caliper. What do u drive?
07-01-2021, 09:15 PM | #7 |
2002 Camaro V6 T-Top
Drives: 2002 Camaro Join Date: Jun 2021
If you have brake fluid out on the floor, just rebuild the caliper. I would start with youtube
