01-03-2017, 12:38 AM | #1 |
"Lohla"
584 WHP 657 WTQ / now comes the Heads/Cam
Well my first winter with the car under a cover proved to be too much idle time for my mind so we went ahead and pulled the trigger on round 2 for the mods. JDP will be swapping out the heads and cam as well as addressing fuel needs and AFM deletion. I'm very curious to see what happens to compression and boost with these mods. We're at 10 lbs and stock compression so I wouldn't mind those numbers being a tad lower. We're adding HP Tuners nGauge and a wideband gauge to complete the data collection process as well.
Thanks for all the insight, my fellow forum friends. I'll keep you posted.
OG Trans and Diff but all else is upgraded. Twins bring wins ;-)
01-03-2017, 12:57 AM | #2 |
Drives: 2019 Dodge Challenger Scat Pack Join Date: Jun 2016
Looking forward to your results.
Sent from my SM-G920V using Tapatalk
"Submariners are a bunch of intelligent misfits that somehow seem to get along, understand each other and work well together." - overheard from a surface officer explaining to another sailor about Submariners
01-03-2017, 06:09 AM | #3 |
"Lohla"
I shouldn't have to leave you in suspense as long as the Supercharger portion of the build did. Goes in Feb sometime and I'm hoping for 1-2 weeks.
01-03-2017, 06:19 PM | #4 |
Drives: 2016 2SS Camaro Join Date: Sep 2016
Why is your compression going to change?
01-03-2017, 10:14 PM | #5 |
"Lohla"
Wishful thinking that head work could lower it if only slightly....
01-03-2017, 10:22 PM | #6 |
Only if the chambers are enlarged, and it wouldn't be much. It'll likely stay the same. I will be doing the "drop in" forged pistons and cam swap first. Then FI later. Fueling issues are my main concern.
01-03-2017, 10:29 PM | #7 |
"Lohla"
I don't blame you. Were addressing fuel for sure. We'll be using the LT4 high pressure pump and injectors.
01-05-2017, 08:38 AM | #8 |
Drives: 2016 2SS Join Date: Jul 2016
Your cam will effectively lower your compression as well. If your SCR stays the same your DCR could change as much as .5 depending on the size of your cam. It is all dictated by the closing point of your intake valve. But with VVT it is always moving. Better flowing heads will also lower your boost which will put less stress on your motor. You will have to pulley way down after your H/C to get back to 10lbs of boost.
2016 2SS. H/C SBE 1.37 60ft, 6.36@109.49, 9.97@136+. Nuff Said.
01-05-2017, 11:32 PM | #9 | |
"Lohla"
01-06-2017, 08:53 PM | #10 |
Drives: 2016 Camaro 2SS Join Date: Mar 2016
Stock rotater?
2016 Hyper Blue 2SS A8,NPP,Moonroof
Pray ported factory intake manifold Ported TB Rotofab ARH 1 7/8 longtubes hi flow cats AFM deleted E85 11.0@124.9 11.65@118.8 pump gas,stock tune/exhaust New combo: Pray Performance Heads/cam MSD intake manifold and Circle D 3C 554/491 on E85 all work & tuning done by Pray |
01-06-2017, 09:58 PM | #11 |
"Lohla"
02-16-2017, 12:08 AM | #12 |
"Lohla"
Dropped off my baby today. The anticipation is killing me and I haven't I even made it a day yet. I'm really looking forward to the end result after having seen the gameplan, otherwise known as a parts list. It was nice to see a bunch of late model GMs.
I'll keep this thread updated as we go along. Stay tuned!
02-16-2017, 06:47 AM | #13 |
FMPG
Drives: 2016 2SS Join Date: Dec 2015
Better start saving for some wider wheels and tires if you don't already have them lol. I saw meth injection in your description. This car should easily exceed 700.
Ordered 3/8/16- NFG/Ceramic White, M6, MRC, NPP, 6 pots, blk blade, no sunroof, blk splitter, blk bow ties, dark tails, nav.
ARH 1 7/8" ceramic coated full sys w/NPP; Maggie 9.2psi (85mm); Jannetty rough idle cam(TSP), tune and LT4 fuel system; Forgeline VX1 Black PVD (20x10,11); R88R 315's; ALPriority; BMR rear arms, bushings, DS loop; RF intake (red); nGauge 93 octane: 712rwhp, 654rwtq / E85 (E66 mix): 734rwhp, 674rwtq (SuperFlow Dyno) |
02-16-2017, 08:36 AM | #14 |
"Lohla"
I've got 315 Contis in back now but we're gonna yank them and put ET Streets on. They'll be 305/35/20. I'm worried they still won't hook though because of the sidewall. I'll let you know how good/bad they are. I'll have a similar set-up to you when I get it back. We are gonna try the stock injectors with all the other LT4 stuff. Jordan has made 780 Wheel on a 416 build with the same fuel set-up so we'll see what happens.
Tags |
6th gen, heads cam, lt1, magnuson heartbeat |
