#Camaro6
Go Back   CAMARO6 > Specific Packages / Variants > 6th gen Camaro 1LE
Old 12-17-2017, 07:33 PM   #1
Web9
Web9's Avatar
Drives: 2018 Camaro ZL1 1LE
1LE Front Spoiler Fragile?
I have 2,200 miles and four track days on the 1LE so far. On the third track day, I took either a rock or a tire marble to the front spoiler and it punched a hole several inches wide.
Question - Has this happened to anyone else? Are the spoilers that fragile or did I just have bad luck?
They aren't cheap at $500 either.
Web9 is offline   Reply With Quote
Old 12-17-2017, 07:35 PM   #2
Glen e
Retired from Car mfrs....
Glen e's Avatar
Drives: 2LT RS/HR-V
Yup, hollow plastic....but That is some rock you hit
Glen e is offline   Reply With Quote
Old 12-17-2017, 07:39 PM   #3
MP3BOOSTED
MP3BOOSTED's Avatar
Drives: 2017 Camaro SS 1LE (F1A-94 FBO H/C)
I have a few rock chips on mine but wow, that’s one nasty hole. At this point I’d probably just go with a different front splitter from phastek.
MP3BOOSTED is offline   Reply With Quote
Old 12-17-2017, 08:09 PM   #4
FNxR3DNECK
FNxR3DNECK's Avatar
Drives: 2017 SS 1LE
Yea they are really flimsy, I'm considering the RPI replica GM splitter for a replacement. It's the exact same design but made of fiberglass, as long as their Satin black is a match for the stock splitter I will be getting it. And it's half the price of an OEM replacement.
IG: @NC_M1SS1LE
FNxR3DNECK is offline   Reply With Quote
Old 12-17-2017, 08:27 PM   #5
Web9
Web9's Avatar
This looks pretty good and the price is certainly better. Thanks.
Old 12-17-2017, 08:59 PM   #6
metros11
Drives: 2018 SS 1LE
How wide is the hole? It's a track car isn't it? Throw some black patch material over it and call it a day.
metros11 is offline   Reply With Quote
Old 12-17-2017, 10:13 PM   #7
7stringtheory
Drives: 2017 Camaro 1SS 1LE
I put a hole in the splitter just like yours on one of my off track excursions at MSR Cresson. No curb or anything just something in the grass / dirt it didnt like.. its definitely very fragile. I have a duct tape bandage over it right now lol
7stringtheory is offline   Reply With Quote
Old 12-17-2017, 11:16 PM   #8
sfzobie
Drives: -
I'm on my second splitter too, but it's so thin I am worried about it breaking again, I may look into that fiberglass one
sfzobie is offline   Reply With Quote
Old 12-18-2017, 06:25 AM   #9
Boost Creep
Boost Creep's Avatar
Drives: '18 1SS 1LE
Gorilla tape is black and probably stronger than the splitter.
How easy is it to swap out?
Might make sense to have a track/road splitter and keep a good one for shows/cars and coffee.
Boost Creep is offline   Reply With Quote
Old 12-18-2017, 08:16 AM   #10
ModdedSS
ModdedSS's Avatar
Mine got shattered, so I ordered the C7 carbon fiber ZL1 style splitter and side skirts to match. The factory splitter is a POS
Show: C7 Carbon ZL1 Front Splitter/C7 Carbon ZL1 Side Skirts/Diode Dynamics LED Sidemarkers/Tinted Headlights, Fog Lights, and Rear Reflectors/20" Forgestar F14's in Bronze Burst
Go: 17" Forgestar F14s in Bronze Burst with Hoosier Drag Radials/Rotofab Intake w/ Dry Filter/EFI Flex Fuel Kit/Kooks 2" Longtubes with Offroad Connections/PRAY Performance Ported Intake Manifold/PRAY Performance Ported Throttle Body/PRAY Performance Ported Heads/PRAY Performance Tune
Suspension: Phastek Lowering Springs/BMR Toe Rods/BMR Control Arms/BMR Trailing Arms/BMR Strut Tower Brace
ModdedSS is offline   Reply With Quote
Old 12-18-2017, 10:37 AM   #11
Web9
Web9's Avatar
Not easy - like 16 rivets.
Old 12-18-2017, 10:42 AM   #12
Glen e
Glen e's Avatar
Drives: 2LT RS/HR-V
Very easy to drill out the rivets and put in strong push poppers, I’ve done it to mine.....then it would be easy to swap them out.....
Old 12-18-2017, 10:49 AM   #13
Web9
Web9's Avatar
Really? That is a good idea if it is strong enough. I sure as heck don't want the splitter coming off on track at 140 mph.
Which push connectors did you use? Link?
Old 12-18-2017, 10:54 AM   #14
Glen e
Glen e's Avatar
Drives: 2LT RS/HR-V
Some track guy will come along here and say “I wouldn’t do that at all”… So you have to make your own decision…
If you’re worried, you could do some with bolts/Nylock s and some with push poppers, I’ve been 100 miles an hour in mine but not to the track. I just used 3/8 inch push pops from Lowe’s ...just go over to Lowe’s and look at the options available...
