Old 06-23-2018, 10:53 AM   #1
Moreair1
Moreair1's Avatar
Drives: 2011 ss convertible
Caused by tire install
Like the title says,does this look like improper tire install was the cause of this?
Cai intake and a few other mods😎
Moreair1 is offline   Reply With Quote
Old 06-23-2018, 11:23 AM   #2
frankwjr
frankwjr's Avatar
Drives: 2010 SS 2SS M6
ummm..did you just get new tires installed? was this there before hand? did you do a complete walk around check before leavin?
lots of q's...good luck.
peace
2010 SS 2SS M6 - Tune by RDP dynoSteve!(Woot) - Daily Driver - 130K! - All work by me...
Old 06-23-2018, 11:26 AM   #3
Moreair1
Moreair1's Avatar
Yes, im at the tire shop as we speak, already had them take picture, never noticed it before and i just recently did a diff swap so looked them over pretty well
Old 06-23-2018, 11:26 AM   #4
KillboyPowerhead
Drives: 2014 1LT RS
Looks like it considering below the "DOT" text on the tire the mark goes to the inner rim and under the tire yet the outside of the wheel/lip and the tire above the mark is unscathed.
Did you just get new tires?
K&N Typhoon Cold Air Intake; Custom Cat-back Exhaust (w/ Magnaflow and Solo Performance); Vitesse Motorsports Throttle Controller; Elite Engineering E2 Catch Can; BC Racing BR Coilovers; JPSS Delrin Radius Rod Bushing Inserts, Camber/Caster Bolts, Sway Bars; Pegasus Aluminum Rear Cradle Bushings, Camber/Caster Plates; Z/28 Toe Links, Trailing Arms, Upper Control Arm Bushings, Rear Shock Mounts
KillboyPowerhead is offline   Reply With Quote
Old 06-23-2018, 11:28 AM   #5
Moreair1
Moreair1's Avatar
Yes at the tire shop as we speak getting an alignment as well on the car
Old 06-23-2018, 12:24 PM   #6
43Camaro
43Camaro's Avatar
Drives: [COTW 8/3/15] 2010 Camaro SS L99
Looks to be from install. Under lip of tire, ask to see the tire that was removed.
A Little bit of power. ALL WORK DONE BY ME!
43Camaro is offline   Reply With Quote
Old 06-23-2018, 12:59 PM   #7
Moreair1
Moreair1's Avatar
The shop took pictures and sent them to the main guy, he said a different shop(franchise shop) had an issue like this and they sent the rim off to be recoated, sucks ill be without the car for 3 to 4 days if they do it but if they do atleast there stepping up and taking care of the issue
Old 06-23-2018, 06:49 PM   #8
TWOFORTYZ
Drives: 2015 Camaro 1SS 6M
The teflon/plastic guide slipped off and the tire iron got your wheel. This looks like a simple accident, nothing major. It happens and it does suck...
I worked at a tire shop for several years of my youth. If it went halfway around the wheel, then they just didn't use the plastic guide piece. Atleast they didn't pound wheel weights onto the lip of the only set of your wheels known to exist in the US. I had that happen once on some mini lite style wheels on the 240Z, I was very upset.
TWOFORTYZ is offline   Reply With Quote
Old 06-23-2018, 06:54 PM   #9
TWOFORTYZ
To be clear, I see no evidence of an "improper" tire install. That would rip the bead and have no effect on your wheel. The guide just fell off and the mechanic didn't have the balls to communicate that an issue occured.
Old 06-24-2018, 06:24 PM   #10
Moreair1
Moreair1's Avatar
Thank you for all of your feed back, they sent it to there big guy so waiting on there decision, the manager said more than likely they will send it to be resurfaced which will take 3 to 4 days
Old 06-24-2018, 09:06 PM   #11
jc615
jc615's Avatar
Drives: Camaro and Sierra
If that’s the case no issue. Had mine done to correct a few dings from wife and came back same as new
jc615 is offline   Reply With Quote
Old 06-24-2018, 11:02 PM   #12
Moreair1
Moreair1's Avatar
Originally Posted by jc615 View Post
If thatís the case no issue. Had mine done to correct a few dings from wife and came back same as new
, I was still at the place when I posted this, I was making sure I had different perspectives in case they wanted to argue, which the manager was pretty cool so hoping that expierence continues
Old 06-25-2018, 10:24 AM   #13
Stock Boy
Stock Boy's Avatar
Drives: 2014 1LE
Hey JC615, your private message mailbox is full....was trying to send you a message but it's telling me I can't.....
Stock Boy is offline   Reply With Quote
Old 08-06-2018, 05:52 PM   #14
Moreair1
Moreair1's Avatar
So just an update on this, So a update on this issue,
Glenwood springs big o decided they would repair the rim, took about two week for that, then on July 13th I dropped off my rim and they said it should be done by the time I got home from vacation on the 1st, well now they are saying the paint (gun metal) is being difficult to match and is taking more time, is it me or is this a lot of bs, is this the way all big o shop are now or just mine?
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
