sjm autoprod
Old 04-07-2013, 09:35 PM   #1
key4
Drives: 2011 camaro 1ss
Help need a tenth or two
Hi, I've been comparing my car to others on here. I know all are different and tracks but I think my car maybe off a little compared to others.
My car weighs 4040 with me in it but I do have some heavy 20 inch torque thrust wheels. I have long tubes, no cats, tune and a vararam. I have only had a chance to run eighth mile so far and first time was about three weeks ago. Ran with the street tires first time had a 1.91 60ft 8.15 @ 88.20. Fast forward to Friday night, put a set of 18 inch 26.5 tall Mickey Thompson dr on and ran a 1.86 60ft 8.14 @ 88.09.
Now I ran at two different tracks and both nights was nice and cool. Not sure what da was but it was in the negative on both nights. I checked the da but forgot them. My thing is I lost about 40 or so lbs by going to the drag radials and really thought the 26.5 tall tire would net me some better ets. Can't figure out why I slowed down in the mph too. Rest of the night was 87 mph.
I had a 98 z28 m6 z28 with bolt ons that would run 8.0s at 89mph and really like to see that out of my 5th gen. Also the guy that tuned it is kinda local and has been tuning for awhile but unsure how many 5th gen autos he has tuned. It seems real lazy when it shifts 3rd. It's never been on a dyno either just a wideband street tune. Just like to see if you guys have any ideas on why it slowed down on the drag radials and how can I get that 8.0
2011 1SS/RS TSP headers, cat delete, vararam CAI,rhino79 tune.
key4 is offline   Reply With Quote
Old 04-07-2013, 11:38 PM   #2
Quick
Quick's Avatar
Drives: 2012 Camaro SS 45th
Not sure if this is your problem but if my car spins any at all leaving it will mile per hour faster.If it hooks hard then i'll have a lower et but the mile per hour will be lower.
OBX 1 7/8 LT's w/high flow cats. Doug Thorley catback w/x pipe. Cold air intake by CAI w/apex scoop.V-max ported throttle body.DynoSpeed tuned by Forest.369 rwhp/385 rwtq
Something wicked this way cometh...
Quick is offline   Reply With Quote
Old 04-09-2013, 08:09 PM   #3
key4
Car was hooking every pass. My concerns are more in the trans tune. Just seems like its lazy in 3rd. Not sure if the shorter tire messed my shift points up or not.
Old 04-09-2013, 08:46 PM   #4
Rhino79
Rhino79's Avatar
Drives: 2010 Camaro SS L99/Auto
Different tire height will alter shift points.
Rhino79 is offline   Reply With Quote
Old 04-09-2013, 08:53 PM   #5
Bad70supreme
Bad70supreme's Avatar
Drives: 2010 aqua blue SS/RS M6
That short tire is why you slowed you mph down... but at 87-88mph is not bad at all with your mods man. I think your 60ft at 1.86 is soft and thats whats holding you back. Personally I think you should get a taller tire, at lest a 28" and work on that tune more.. possibly that short tire could have a negative effect! You should be in the lower 1.80-1.7s 60fts on drag radials easy and that would get your 8.0s
10.91 at 122 H/C stock block N/A
Bad70supreme is offline   Reply With Quote
Old 04-10-2013, 01:30 PM   #6
Pro Stock John
Writer
Pro Stock John's Avatar
Drives: 2010 SS / 1967 Camaro
Here is my best slip so far from last year.
I have a local friend who did cut a 1.83 with 20's up front and stock height 18's on back.
PROJECT HEAVY CHEVY
13.15@106 1.95 | 100% Stock
Old 04-10-2013, 02:43 PM   #7
Quick
Quick's Avatar
http://www.camaro5.com/forums/showthread.php?t=288267
Old 04-10-2013, 02:51 PM   #8
Pro Stock John
Writer
there you go
PROJECT HEAVY CHEVY
Old 04-10-2013, 08:38 PM   #9
key4
Thats the slip Im searching for. I need to figure the whole tune stuff out myself and break down and buy hp tuners. I just bought theses rims and like to stick with them. It actually launches pretty good
Old 04-10-2013, 11:29 PM   #10
Pro Stock John
Writer
pm sent
PROJECT HEAVY CHEVY
Old 04-11-2013, 07:42 AM   #11
Bad70supreme
The 18" wheel is not the problem, Its the tires! I just picked up a set of 18s myself and 305/45/18s nto5rs, they are basicly stock hight tires.
Old 04-11-2013, 10:14 AM   #12
KARBON
KARBON's Avatar
Drives: 2010 CAMARO 850 RWHP/733 RWTQ
I have the same set up, 18's stock height on rear and stock 20's up front. My car consistantly cuts 1.6 60' times.
*Night Fury
*Vortec YSI
*Alky Meth
*RPM TH400 with Brake
*Precision 3600 Converter
*850 RWHP/733 RWTQ
KARBON is offline   Reply With Quote
Old 04-11-2013, 01:56 PM   #13
Pro Stock John
Writer
Karbon I see you have heads and cam too, what does it run? My next move will be H/C or blower. I miss running in the 10's and quicker.
PROJECT HEAVY CHEVY
Old 04-12-2013, 12:45 PM   #14
Camarojt
Camarojt's Avatar
Drives: 2011camaro SS
You could be bumping the rev limiter on your shifts due to the shorter size of the tires throwing your shift points off. Those tires should help your 60 ft but seems like the tune is the culprit of your lagging mph and ET. The 26.5 height of the tire itself is not at fault, it's the tune in combination with that height if tire. This tire is on the Fastest Bolt on L99 car with stock internals, and he makes plenty of mph. Fix your tune and you will be fine.
Camarojt is offline   Reply With Quote
