09-12-2018, 12:01 PM | #1 |
Engineer
Drives: 2014 Camaro 2SS RS 1LE Join Date: Jun 2015
Edit: 375 Shipped, 1LE Shocks + BMR Springs
Edit: $375 shipped
My setup has 30,000 miles on them, the majority of them coming from my highway commute to work. 1LE Front and Rear Shocks BMR V8 200 lb/in front springs (1" front drop) BMR V6 430 lb/in rear springs (1.2" rear drop) Same spring rates and the Detroit speed set with the perfect drop. Pictures of the stance Offer! Last edited by derieu; 01-20-2019 at 02:06 PM. |
09-12-2018, 09:55 PM | #2 |
Drives: 2010 2SS/RS Join Date: Dec 2009
I have a set of OEM springs for a SS/1LE that I replaced with 1 drop springs if interested.
Orange Krush II
09-13-2018, 10:23 AM | #3 |
Drives: ZL1 Convertible Auto Join Date: Apr 2015
I have a friend who is not on here looking for lowering springs. His trade would be 2012 SS strut/springs and I am not sure of the miles. I will PM you his facebook and phone number after I check with him. SE Michigan also
LS3 intake and throttle body, Huron Speed Products twin turbo with 6265 oil less turbos, and 3" header back, JRE smooth cam, ID1300, Fore dual 450lph pumps with MSD voltage booster, A6, 305/45/17 MT Street R
09-13-2018, 12:46 PM | #4 | ||
Engineer
I have my OEM springs, thank you though Quote:
Shoot me a PM, definitely interested! |
09-14-2018, 11:06 PM | #5 |
Engineer
bump
09-17-2018, 05:28 PM | #6 |
Engineer
bump
09-22-2018, 03:25 PM | #7 |
Engineer
bump
09-27-2018, 10:28 PM | #8 |
Engineer
bump
2014 Red Hot Camaro 2SS RS 1LE
-Sunroof Delete, Recaro, Nav, NPP -Pegasus Subframe Bushings, JPSS Radius Insert, Detroit Speed Caster Mod, PMAS Intake, Solo High Flow Cats, Ecsta PS91 Tires, MGW Shifter, Pegasus Offset Poly Diff Bushing |
09-27-2018, 11:12 PM | #9 |
how much for the rear set?
09-29-2018, 12:12 PM | #10 |
Engineer
12-13-2018, 03:10 PM | #11 |
Santos
Drives: 1SS Blk 6M ECS 1500 Join Date: Jul 2007
how much for the front and rear shocks? i have 1" bmr springs already
12-14-2018, 01:44 AM | #12 |
Drives: 2012 camaro ss Join Date: Apr 2016
How much for the full set?
12-17-2018, 02:01 PM | #13 |
Engineer
I'd have to check shipping out, but i'd probably say around $400 OBO before shipping
12-17-2018, 05:04 PM | #14 |
I might be interested. I'm looking to get rid of my coilovers
2012 zl1 stock 7000 miles
2010 TVS2300, BTR cam PD stage 3, ID1050 injectors, CHE bronze trunnions, 7.400" pushrods,.660" lift platinum springs, Titanium ret, Zl1 fuel pump, Kooks LT headers, High flow cats, Roto Fab CAI, Corsa exh., Mellings oil pump, HD chain, ls2 damper, all synthetic, BMR control arms, zl1 toe link, BMR cradle mounts, W/bottle relocation, air scoop deflector, Hennessy wheels, two piece rotor, morimoto fogs, DRL harness, coilovers, Heads up install, mgw shifter, slps splitter, slp spoiler, zl1 side skirts, painted strips, debadged, tinted, 2018 emblems. Edit Signature |
