08-10-2020, 10:31 AM | #1 |
Valkyrie14
Drives: Chevrolet Camaro SS Join Date: Mar 2020
Black Plastic Exterior Trim What works to restore it???
As the title states my exterior trim is looking hazy. Especially my splitter. What works to restore it?
2014 SS LS3/LSA Supercharger, 10% Super Damper, 2.55 upper, AGP Dual Pump, ID 1050 injectors, Pegasus solid rear cradle bushings, LT Headers, Roto-Fab CAI, Elite E2 catch can, E85 corn fed, 160 Thermostat, Monster Twin Disk, MGW Short Throw shifter, Tick Clutch Master Cylinder, HP Tuners, JL Audio system.
08-10-2020, 10:57 AM | #2 |
Drives: 2012 M6 ZL1. 2019 Altima.07 FJR1300 Join Date: Nov 2011
I've used 'Back to Black' to help on those items..
08-10-2020, 01:22 PM | #3 |
Drives: 2011 Camaro 2LT/RS Join Date: May 2015
armorall outlast works well, too
08-10-2020, 01:30 PM | #4 |
Drives: 2013 Triple Black ZL1 Vert M6 ECF Join Date: Mar 2011
08-10-2020, 02:29 PM | #5 |
Drives: 2015 Camaro 2SS Green Flash Edition Join Date: May 2017
I highly recommend following "Detailing 101 by Autogeek" on Facebook. The previously mentioned suggestions are nice for short term dressing. I recommend using those options for maintenance. You can bring oxidized plastic back to life a bit with a dryer or heat gun, but the most recommended solution is Solution Finish. Then, I highly recommend using the other stuff for maintenance.
StarSaber Mk. II
IG: StarSaber85(https://www.instagram.com/starsaber85/) Performance Mods: CAI, Inc. Cold Air Intake; ADM Racing Scoop; Bo White Ported Throttle Body; GPI Ported Rod Mod Intake; Kooks 1-7/8" Headers with Catted Connections; Solo Mach XL Axle-Back Exhaust |
08-11-2020, 04:32 AM | #6 |
Drives: 2012 1LT Join Date: Nov 2015
Yhe products listed above; Back to Black, Armoral Outlast, and the link to Adam's VRT are all dressings that wash off. I've had great success on black plastic trim with Adam's Black Trim Restorer, gotta let it dry for 24 hours or longer, then topped with his 9H Ceramic Paint Coating, and with his Ceramic Black Trim Restorer. Both of these products are a dye, not a dressing and last for months, to a year for me.
The heat gun process is lightly melting the surface of the plastic trim. This method you'll have trouble getting in all the nooks and crannys evenly, and can melt the trim and surrounding plastic bumper easily if not careful, as well as burn the surrounding paint. I'd avoid this process until all lesser aggressive options are tried first, with you're only other option being replacement.
08-11-2020, 05:16 AM | #7 | |
StarSaber Mk. II
08-11-2020, 07:23 AM | #8 | |
Valkyrie14
08-11-2020, 07:45 AM | #9 | |
You don't need the 9H Ceramic Paint Coating Kit if you're just doing your trim, just the bottle of the Ceramic Coating. Clean the Trim thoroughly with a Tire & Rubber Cleaner, then wipe it all down with IPA. Buy the Ceramic Paint coating Kit if you plan on Ceramic Coating the entire vehicle.
08-11-2020, 10:43 AM | #10 | |
Drives: Still Waiting... Join Date: Oct 2015
I personally haven't used it, but I plan on trying Cerakote Ceramic Trim Coat. This stuff looks amazing and priced well: https://cerakoteceramics.com/product...-trim-coat-kit
I first learned about from Apex Detail: |
08-11-2020, 06:51 PM | #11 | |
Valkyrie14
08-12-2020, 03:17 PM | #12 |
Drives: 2012 RSLT,1979 Trans Am Join Date: Jul 2012
Trinova plastic and trim restorer , the ultimate plastic & trim solution I have had every good results on my camaro and pontiac firebird trans am , use very sparingly goes a long way
