10-01-2015, 11:00 AM | #1 |
Live to Drive
Drives: 2010 IBM RS/SS, 2018 Toyota Tacoma Join Date: May 2010
Electrical Issue - I'll take any help I can get.
2010 SS M6
I am having electrical issues. The car will do one of two things – fire up and immediately quit, or not fire at all. When it does not fire at all, I remove the key and half of the dash stays lit – requiring that I disconnect the battery so it will not drain completely. Here is what I was doing. I was cleaning up my trunk area which has Dynamat installed. I removed my sub and amp enclosures to “tidy up” some wiring (led strips in the trunk) and make the compartment more usable with all my extra items. As I thought I was finishing my project, I keyed up to make sure everything was working like it should and discovered I had not connected my amp’s remote lead to the radio. I moved the amp rack, heard a pop; smelled some smoke and the radio went off. Figured I popped a fuse … when I went to fire the car, I experienced the issues above. I have had a former GM Service manager who is a friend of mine stop by with thousand of dollars of gear to scan. No blown fuses in any of the three fuse boxes, nor are the 60W or 100W fuses connected to the positive battery cable blown. Reground the stereo components, but still cannot get the car to run. Battery is fully charged, although it is not brand new. It was purchased in 2013. I searched the forum but have not been able to find anything quite like this. I’d really appreciate any help the good folks of Camaro 5 might have to offer. Thanks in advance |
10-01-2015, 11:26 AM | #2 |
Drives: 2010 Camaro 1LS 3.6 LLT V6 325 HP Join Date: May 2009
Did this start to happen after you messed with the wiring in the trunk?
10-01-2015, 11:28 AM | #3 |
Live to Drive
10-01-2015, 01:28 PM | #4 |
Drives: 2014 2ss/rs Join Date: May 2012
do you have an immobilizer bypass installed for a custom alarm? check the inline fuse on that.
10-01-2015, 01:39 PM | #5 | |
Live to Drive
Fingers crossed for something simple. |
10-01-2015, 01:40 PM | #6 |
Drives: 2013 Camaro 2SS/RS M6 Join Date: Feb 2013
The camaro is set up like a circuit breaker if it detects a problem with some wiring (faulty ground, etc) it trips and turns the car into a 3000+ pound paper weight. I am speaking from experience.
When you try and start the car do any electronics (dash, lights, chime, etc) work? If not, then I would start with disconnecting your amp(s), then try and start the car... if it works then you have a bad ground somewhere, if not then I would try to locate the source of the "smoke" smell.
2013 Black / Black Camaro 2SS/RS M6 w/Magnuson TVS2300, ZL1 Fuelpump / ADM FPCM, NPP Exhaust, Cold Air Inductions CAI w/ Scoop, Elite Engineering Catch Can, VMAX Ported TB, OEM 1LE Front Splitter, AAC Ghosted Side Markers, Dropped on BMR Split Drop Springs Build#24869 |
10-01-2015, 01:55 PM | #7 | |
Live to Drive
Thanks and I appreciate any/all the help from my brothers and sisters on Camaro 5! |
10-01-2015, 02:22 PM | #8 |
So when you heard the pop and smelled the smoke . Did you see where the smoke was coming from ? I would look for burned wires . You shorted something out . Where ever the magic smoke came from is where the issue is .
Mods, K&N CAI ,VTC , GM Perf Axleback Exhaust, Elite Eng CC and CSS, GM Strut Tower Brace,Carbon Fiber Anvil Spoiler,ASC T5 Splitter,Gen5diy Foglight kit.
10-01-2015, 02:31 PM | #9 |
Drives: 2SS/RS L99 BLACK Join Date: Apr 2010
Typically I would not think wiring for the radio would not cause a no start condition. If you were working in the trunk I would look at the wires and connector to the fuel pump. Just a thought
10-01-2015, 03:09 PM | #10 |
Drives: 2011 Black SS M6 Join Date: Oct 2010
If you car worked fine before the smoke and burning smell, I would certainly start at that place.
Do you know exactly where the smoke and burning smell came from? |
10-01-2015, 04:25 PM | #11 | ||
Live to Drive
Again thanks for the suggestions and please keep them coming. |
10-01-2015, 04:41 PM | #12 |
Can you hear the fuel pump run with the ignition on and do the engine lights come on fuel pump should run about 10 seconds on key on but don't try too start
10-02-2015, 11:30 PM | #13 |
Live to Drive
Problem solved. Found a burnt aftermarket radio module. Burnt so bad, I melted the connector pins. Once I disconnected it, the car fired right up and ran with no issues. Off to the stereo shop tomorrow for a complete check and reassembly with a new module from Metra. Thanks for all the suggestions and help!
