02-28-2021, 12:38 PM | #1 |
Drives: Chevy camaro Join Date: Feb 2021
Lq4 in 2011 camaro v6
Recently purchased a 2011 camaro v6 from an auto auction, just blew up v6. Wonder what all is needed for a gen 3 block in a 5th gen car, 58x reluctor? 6l80 tranny? And ss wiring harness? Will gauges still work with gen 3 components? Figured going to be a bit of wiring involved. Cars already been upgraded with brembo brakes and ss rear swap.
02-28-2021, 12:50 PM | #2 |
Drives: 2013 Sparkly Red One Join Date: Dec 2018
There are other threads for v6 to v8 swaps.
03-01-2021, 09:51 AM | #3 |
Drives: 2010 Camaro SS2,L99, LSA SC Join Date: Aug 2017
From what I remember from the other threads, it's doable but not easy.
03-01-2021, 11:49 AM | #4 |
Drives: 15 Camaro SS Join Date: Oct 2018
Yup. I've read through those threads and its enough of a bitch I'd just buy a SS lol
15 Camaro SS- GPI max top end, ESS Vortech V3 9psi, ID 1050s, ZL1 pump, JMS bap, Long tubes, Corsa extreme, Circle D pro 5C, 391 rear, DSS carbon drive shaft, poly cradle bushings, tuned by Ted Jannetty and much much more
03-01-2021, 12:41 PM | #5 |
Agreed with the above comments, can be done BUT very time consuming and a PITA. Not your average back yard weekend swap.
03-28-2021, 07:56 AM | #6 |
Figured I’d let everyone know I went ahead with the swap. So far it hasnt been that bad, 6.0 and 6l80e are installed in the car, hoping to be done in the next month or so. Still have to get intake, front drive accessories like alternator and ps pump, headers and ss wiring harness
03-28-2021, 09:36 AM | #7 |
2&THEHIT
Drives: 5th Gen Camaro; 5th Gen Ram 3500 Join Date: Mar 2018
Awesome! Keep us posted. Another 5th gen saved is a win
03-28-2021, 11:18 AM | #8 | |
Drives: 2011 Camaro SS Join Date: Jul 2019
EPS CUSTOM GRIND CAM....K@N CAI....VMAX PTB.....FRANKENSTEIN STAGE 2 HEADS ...1 7/8 STAINLESS POWER CATTED LONGTUBE HEADERS...CORSA XTREME 3 INCH CATBACK.....CIRCLE D 3800 Pro Series stall...391 gears.....Ported/modded GPI intake .Forgestar drag pack with Mickey Thompson ET street drag radials AGP PERFORMANCE DYNO TUNED. 463 WHP 428 FTLBS TORQUE.
03-28-2021, 11:38 AM | #9 | |
Wiring harnesses are easy enough now to re-pin or have made custom if needed. Its the ECM and module reprogramming that usually stops progress, as most dealers will not go anywhere near these types of reflashes. You usually have to know someone that works at a dealership to get anything done. A couple years ago I bought a Chinese knock off Tech2/Candi device that has J2534 pass thru capabilities. This allows you to use the $100 knock off Tech2 device as a programmer for all GM CanBus modules. It only costs $40 per VIN for a 2 year subscription to GM's TDS programming service, which gives you access to the entire library of files for reflashing modules, ECMs, & TCMs. This would dramatically cut down on the headache and wall most people run into when the dealer inevitably refuses to help you flash any projects which are 'other than stock'. You just need a decent laptop to use as the interface. I bought mine mainly for using the GM GDS2 software to troubleshoot my car electrical system. It allows complete remote access and control of every single module in the car for testing purposes. You can basically activate and turn on/off every single electrical component in the car from your laptop with GDS2, monitor every single engine sensor, run scans and create graphs, hold rpm at very specific values to test sensors, etc...pretty much anything you can think of for troubleshooting. If have personally not yet needed to flash anything or subscribe, but I do plan on it in the future when I do my HUD upgrade. Here is where you would subscribe to the Vehicle Programming Software, which gives you full access to the GM library of files needed to flash modules and computers: https://www.acdelcotds.com/subscriptions# I have the Wifi version of this: https://www.amazon.com/VXDIAG-VCX-Na...6948951&sr=8-1 I highly recommend the more expensive versions as getting the software running perfectly was a couple of days worth of massive frustration. There are also others which are easier to install and get up and running, but cost a bit more. They look much more like the real deal, but are usually missing the 'GM' decal. Although some come with the sticker in the box lol: https://www.ebay.com/itm/For-GM-MDI-...MAAOSwDYJgPvPM https://www.ebay.com/itm/For-GM-MDI-....c101195.m1851 Anyone that buys any of these or similar devices, just make sure it comes with all the required software. *** I have absolutely zero relation or vested interest in any of these links I posted, and they were all selected randomly from the other hundreds of listings online - just trying to post info and help members.
03-28-2021, 11:58 AM | #10 |
Thanks everyone for the feedback, I’ll keep you al posted
03-28-2021, 10:10 PM | #11 |
Yes, please do. We need as much information on these type of builds that we can get. Once enough are done successfully a walkthrough or guide can be put together to help out others in the future.
I'm also hoping to hear an update from the guy doing the TR6060 swap on an automatic L99 SS. I know GPI has done one for a customer that came out great and nearly identical to stock manual setup, but there is no build info on it anywhere, but just a short video from the customer when he picked it up.
04-03-2021, 11:27 AM | #12 |
Angewendet Ingenieur
Drives: 14 Camaro ZL1 Join Date: Apr 2015
LQ4/LQ9 Excellent stable platform if done right it’s not out of the park to reach north of 1,000HP. Have you drilled for the alternator mounting bracket? Recommend you utilize case hardened mounting bolts as I have sheared mine twice till I drilled for larger diameter bolts.
LQ9, Iron Block, Forged internals, 408CI, Jannetty custom cam, TS short block, Whipple, Hardened Jackshaft, PRC 260, 2X3 Dynatech Full Competition, HF Cats, CAI, NW 103, Chee, ID 1300, COPO Breather, MSD, Fore Dual Pump, ultratorque, E85, dual Meth, True Trac, 3:45, 1500hp axle-shafts, DSS CF, BMR, custom Pearl/Candy paint by Jaidah. |
10-10-2021, 04:37 PM | #13 |
Car is done for the most part, daily drive it, I ended up going with a l99 6.2 in it, guages all work, car just isn't factory set up ignition/key wise, but doesn't bother me
Car has been done since July. |
Tags |
6.0 3rd gen, v6swap |
