#Camaro6
Go Back   CAMARO6 > CAMARO6.com General Forums > Z/28 Discussions
View Poll Results: What do you think will power the Z/28? (
Small (5 - 5.5L range) high revving engine 26 8.10%
LT1 with minor power bump (CAI, exhaust, etc) 10 3.12%
Heavily reworked LT1, similar to the LS6 from the C5 Z06; ~500 hp 65 20.25%
Large displacement sucessor to the LS7, ~550 hp 129 40.19%
LT4, same as from the ZL1, CTS-v, and Z06 50 15.58%
'super LT4' with a bigger blower or turbos making 700+ 31 9.66%
Other (please specify) 10 3.12%
Voters: 321. You may not vote on this poll
Old 05-20-2016, 02:21 PM   #1
DGthe3
Moderator.ca
DGthe3's Avatar
Drives: 05 Grand Am GT
Guessing Whats Under the Z/28's Hood
We've spend quite a lot of time guessing and speculating over whats going into the Z/28 (or whatever it is that has been recently spotted at the 'ring with that huge wing).
Early on there were some thoughts that GM might go with a V6 or turbo4 but the videos that we've seen pretty much kills that idea. We might not agree on whether there is any blower whine but it clearly has V8 rumble.
So here are all the general ideas that I can remember seeing:
  • Small (5.0-5.5L) but high revving NA engine, reminiscent of the old 302 from the original Z/28. Possibly with a flat plane crank
  • LT1 with slight power bump (~20 hp) via things like CAI, freer exhaust, etc.
  • Heavily reworked LT1, akin to the LS6 of the C5 Z06, producing around 500 hp
  • A new large displacement NA engine, serving as the successor to the LS7. Likely to put out something in the mid 500s
  • LT4, making the same 640-650 or so hp that it does in the Z06, CTS-V, and ZL1.
  • 'Super LT4': an even more powerful version of the force-fed 6.2L either through the use of a bigger blower or maybe turbochargers. Minimum of 700 hp
  • Other (please specify)
........and HE WOULD KNOW!!!!
Camaro Fest sub-forum
Old 05-20-2016, 02:25 PM   #2
Jeffro19
Jeffro19's Avatar
Drives: 2018 ZL1 6M, Silverado High Country
Im thinking a large displacement NA successor to the LS7 to be called LT7. I'm thinking about 540-550hp.
Previous Camaro's - 2002 Z28 6 spd manual, T tops, Sebring Silver - 2010 2SS 6 spd manual, Cyber Gray Metallic
Current Vehicles - 2018 ZL1 Red Hot 6 spd manual, Carbon Hood, Sunroof
2019 Silverado High Country, Daily Driver
Jeffro19 is offline   Reply With Quote
Old 05-20-2016, 02:27 PM   #3
oldman
Drives: SS 6 speed of course
I sure it is an engine... LOL.
7 liter direct inject with an intake very similar to the MSD intake which is phenomenal. You think GM would have figured this out, the LS 6 intake, a simple redesign with enlarged plenum was so much better. The MSD just has more plenum and larger / tapered runners and it is really the best thing since sliced bread.
Forged short block, large duration sub .600 lift Cam Motion cam, 7200 RPM fuel cut, Pray Ported Heads, 3.85 pulley D1X, stage II intercooler, DSX secondary low side, DSX E85 sensor, Lingenfelter big bore 2.0 pump, ported front cats, 60608 Borla, LT4 injectors, ZL1 1LE driveshaft and Katech ported TB, ported MSD intake, BTR valvetrain, ARP studs, ProFlow valves, PS4 tires.
oldman is offline   Reply With Quote
Old 05-20-2016, 02:29 PM   #4
kingbambino22
kingbambino22's Avatar
Drives: 2023Porsche Cayenne S
6.3 liter 550hp 7200-7500rpm redline
kingbambino22 is offline   Reply With Quote
Old 05-20-2016, 02:30 PM   #5
shaffe
Drives: 21 Bronco
I originally thought LT4 bc I thought I heard blower whine. The latest videos, not sure I hear it anymore.
So I am going with heavily reworked LT1. Ala LS1 to LS6
Originally Posted by 72MachOne99GT View Post
Lets keep it simple. ..
it has more power...its available power is like a set kof double Ds (no matter where your face is... theyre everywhere) it has the suspension to mame it matter...(
shaffe is offline   Reply With Quote
Old 05-20-2016, 02:32 PM   #6
Bhobbs
Bhobbs's Avatar
Drives: 2015 SS 1LE Red Hot, 1970 Chevelle
The most realistic is the LT4 but I'm not sure I hear blower whine
Second most realistic is a hot LT1, similar to the LS6, hopefully in the low 500 hp range.
What I'm hoping is an LTx 7.0 in the 540-550 hp and 500 tq range.
Bhobbs is offline   Reply With Quote
Old 05-20-2016, 02:33 PM   #7
oldman
your lips to the HP god's ear.
Old 05-20-2016, 02:41 PM   #8
Sidedraft
Drives: Jeep Wrangler
No idea what's going under the 6th gen Z/28 since I feel like it's quite awhile away. Hoping for a high-revving, NA answer to the Voodoo.
As far as the big wing car running around the 'Ring? I don't buy the premise that it's a Z/28. Everything about that car screams (literally) ZL1 variant to me, and as such, it means it must be powered by an LT4.
Sidedraft is offline   Reply With Quote
Old 05-20-2016, 02:46 PM   #9
Raven87
C'mon- really?
Raven87's Avatar
Drives: Looking for a ZL1
Ford threw down the gauntlet with the GT 350 and R versions. GM will most assuredly answer with a Z/28 and possibly a Z/28 R vs a ZL1 R IMO.
I cannot wait to see what it ends up being.
As far as an engine guess - I'm betting it will most likely be an N/A motor based on the 6.3 and north of 550 HP (with an LTx designation) but from there it could be anyone's guess.
Steve
2018 Camaro 2SS 1LE Black #3805 - SOLD
Raven87 is offline   Reply With Quote
Old 05-20-2016, 03:03 PM   #10
mkorgan
Drives: 1970-1/2 Z-28, 2017 ZL1
Direct Injection version of LS7 with reworked heads. 565HP
mkorgan is offline   Reply With Quote
Old 05-20-2016, 03:21 PM   #11
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
Lt1 blown out to 6.6+ spinning out to 7500RPM with 560 HP and 580 TQ i hope its 7.0 but think it may be less.
Old 05-20-2016, 03:37 PM   #12
Thor142
Thor142's Avatar
Drives: 2014 2LS (traded in) 2015 1SS 1LE
LT4 same as in the ZL1
Thor142 is offline   Reply With Quote
Old 05-20-2016, 03:39 PM   #13
OldJedi
Use the Force
OldJedi's Avatar
Drives: 2015 Corvette Z51, 2018 Porsche GTS
Send a message via AIM to OldJedi
All aluminum 454 LS6 with 12:1 CR, oval heads, domed forged pistons and all forged internals pushing 560HP with 610 pounds of torque and telling the bean counters and EPA types to put it where the sun does not shine. Just a thought.....
Walk softly, carry a light saber and drive a ZL1!
OldJedi is offline   Reply With Quote
Old 05-20-2016, 04:42 PM   #14
mkorgan
Love it.
