07-02-2015, 12:48 PM | #1 |
Drives: 2015 Camaro SS 1LE Join Date: Aug 2014
"Door Open" when it's closed
So out of no where today I was driving down the road and on my DIC it shows "Door Open" (Passenger side).
I got out, opened and shut the door multiple times, etc. Before I take it to the dealer is there anything obvious to look for? It's only got 600 miles on the odometer. |
07-07-2015, 11:05 AM | #2 | |
Drives: 2015 1LE 2SS/RS CRT NPP AYZ NAV SUN Join Date: Aug 2014
1989 IROC Z L98. 2015 Silverado LT. 2015 2SS 1LE. |
07-07-2015, 11:38 AM | #3 |
Drives: 2013 2SS/RS/1LE Join Date: Apr 2010
Bad door switch/sensor most likely. Or the wiring in the door.
12-07-2015, 07:44 PM | #4 |
Drives: 2015 1LT Blck Join Date: Mar 2015
So did you get this fixed? I'm having the same problem. Dealer attempted to fix it by replacing my window motor but that didn't work so I get to go back tomorrow to try it again.
12-07-2015, 09:51 PM | #5 |
Drives: 2011 2SS/RS M6 Join Date: Oct 2015
A window motor won't fix the door ajar message lol. Most likely it's the door latch. Uncommon for the mileage but not unheard of. It could also be the door harness pass through connector. I've had a lacrosse on PDI with the last issue. The dealer should be able to find it fairly quickly.
12-09-2015, 05:07 PM | #6 | |
Drives: 2010 Camaro 1LS 3.6 LLT V6 325 HP Join Date: May 2009
12-11-2015, 10:21 AM | #7 |
Thanks for the input! Hopefully that works.
12-29-2015, 11:38 AM | #8 |
It ended up fixing itself by the way. Then 3 weeks later it randomly popped up for a second and has been away since. Sorry I forgot to reply!
2013 2SS RS
CAI Intake Air Scope BMR Strut Bar Tune |
12-29-2015, 12:29 PM | #9 |
So what did you end up doing? Any of the suggestions?
01-26-2016, 12:41 PM | #10 |
Drives: 63' chevy impalaSS , 12'Cam89'Cam Join Date: Feb 2013
anyone else find out why its doing this? mine started doing this today and also revved really high and wouldn't go over 30 mph..
01-26-2016, 01:10 PM | #11 |
Still have no idea what caused it. To this date I've still not had any issues.
2013 2SS RS
01-26-2016, 08:48 PM | #12 |
Wow I actually just figured out why mine was doing that and acting crazy . Dumb me had forgotten to tighten back down the jump off bolt under the hood that goes to the positive battery cable ! I have halos and have them wired directly to that bolt right now and didn't hook them up this morning thus leaving that bolt loose. But now somehow it shorted out my bright lights .. hopefully just a fuse bc I just bought the bulbs ..
