Rick@Livernois
Old 11-08-2018, 12:02 PM   #1
cmancha003
Drives: 2015 Z/28 #1097
Aftermarket intake tube?
I am looking to get a little more intake noise (without forced induction ). Do they make just the tube? No sense in getting a new CAI. I don't think the SS tubes would work. Might just be easier to find a welder and some tubing. Thanks!
cmancha003 is offline   Reply With Quote
Old 11-08-2018, 04:50 PM   #2
STALKER
STALKER's Avatar
Drives: 2014 Camaro SS Spring Edition
Even if you found one that worked or had one made, I don't see there being any difference in induction noise.
2014 Camaro SS Spring Edition 2SS
LSX440
LSX Block, PRC 285 LS7 Heads w/ Ti Intake Valves, Diamond Pistons, Callies Compstar Crank & H-Beam Rods, Custom Comp Cam, LS7 Lifters & Pushrods, Trunion Modified LS7 Rockers, FAST 102 Intake, NW 102 TB, Z28 CAI, FAST Fuel Rails & 65# Injectors, Kooks 1-7/8" Headers, Kooks Z28 3" Cat-Back, Z28/1LE Shifter, ZR1 Clutch w/ Katech Lightweight Flywheel, 1LE 3.91's, LPW Diff Cover, BMR 1.4" Springs, LCA's, Trailing Arms, Toe Rods, Sway Bars, Diff Bushings, and Tunnel Brace, Z28/1LE Strut Tower Brace, 20" Z28 Wheels with Nitto Rubber.
STALKER is offline   Reply With Quote
Old 11-08-2018, 05:34 PM   #3
joelster
Drives: '94 Z28+ '15 Z/28
Zero difference. The stock Z/28 tube doesn't have those resonator tubes that are on the regular SS. The resonator tubes tone down the sound.
'94 Z28, 414" LT1, 10.15 at 133.65 N/A pump gas
'15 Z/28 Red Hot, A/C
joelster is offline   Reply With Quote
Old 11-09-2018, 08:54 AM   #4
cmancha003
Dang. I was figuring the crinkles would deaden some of the sound. Oh well, time for a louder exhaust then ;-)
Old 11-09-2018, 09:03 AM   #5
Juiced1
Juiced1's Avatar
Drives: 2012 2SS CAMARO 45th
No silencer on the intake. A louder exhaust is probably the better option anyway. Give us a call and we can go over some options and get you good price.
GET MORE POWER PER DOLLAR!!!
We carry and install all the hottest brands for your Camaro! Get awesome deals on Corsa, Borla, Solo, ARH, SW, Whipple, Kooks, Procharger, Vararam, CAI, Roto-Fab, Texas Speed, ATI, ACS and much more! Call us for your CAMARO5/CAMARO6 Forum discount today! 224-63-JUICE
1820 PRODUCTION DR STE D ST CHARLES IL 60174
Juiced1 is offline   Reply With Quote
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
