Old 05-27-2021, 09:29 AM   #1
jokrz187
jokrz187's Avatar
Drives: 2015 1SS
Whipple vs ECS super charger
Looking on opinions between these two. I am looking at super chargers and the shop near me recommended either of these. I am not too familiar with ECS so I wanted to see if anybody has it and what they think. Also any others that have great knowledge of the two that can break down some differences and similarities. Thank you in advance
MODS: VARARAM CAI, Catch Can, 1 LE front/rear sway bars, engine cover/fuse box custom painted, strut tower brace, Texas Speed LT, Hi Flo Cats, Magnum Tru-X pipe, NGK Spark Plugs, PCM Spark Plug Wire, Painted Calipers, CF Spoiler w/wicker bill.
jokrz187 is offline   Reply With Quote
Old 05-27-2021, 09:38 AM   #2
Greenhornet2
Greenhornet2's Avatar
Drives: 2011 Camaro 2SS LS3 Whipple
End goals?
Whipple ton of low end grunt peaks at about 900WHP with all supporting mods, harder on drivetrain due to the instapower
Centri still makes a ton of torque just comes on easier and not quite as low rpm. some of them are very loud sounding like a jet engine (personally hate that). Typically have more peak HP potential, easy to swap head units if you need bigger.
My experience is with a whipple though, haven't driven a centri on these cars.
Greenhornet2 is offline   Reply With Quote
Old 05-27-2021, 11:08 AM   #3
gunchamp
gunchamp's Avatar
Drives: 15 Camaro SS
Centri here and am very happy. ESS is the system I went with and other than crap directions, the kit is top quality and the price is damn good compared to others. Greens post above nailed down the differences.
15 Camaro SS- GPI max top end, ESS Vortech V3 10psi, ID 1050s, ZL1 pump, JMS bap, Long tubes, Corsa extreme, Circle D pro 5C, 391 rear, DSS carbon drive shaft, BMR toe rods, BMR trailing arms, poly cradle bushings, tuned by Ted Jannetty and much much more
gunchamp is offline   Reply With Quote
Old 05-27-2021, 11:09 AM   #4
gunchamp
gunchamp's Avatar
Also, the ESS system allows the easy swap of many different head units. You could swap in heads that could support well north of 1k whp. Simply unbolt and bolt the new one on. Its a great system
Old 05-27-2021, 12:21 PM   #5
TheFlyingBananaSS
Evil Genius of Chevrolet
TheFlyingBananaSS's Avatar
Drives: 2013 2SS, 2015 LaCrosse, 2017 Z06
I have the ECS Novi 1500. Love it. The car is a beast. Very simple to increase boost. They also work really well with a nice cam. I'm at 710rwhp but could easily go 900 but then drive line would start to need upgrades too. Highly recommend ECS because their customer support is so good.
GPI SS2 VVT cam, ECS Novi 1500 supercharger, Corsa Extreme, Detroit Speed and BMR suspension, Circle D triple disc, Melling oil pump, LS2 chain tensioner, ATI 10% UD, DSX E85 kit, High Energy coils, BTR springs, LS2 Lifter trays, Titanium retainers, hardened push rods, FIC 1000 injectors, ZL1 pump, Mighty Mouse catch can, AEM gauges, Tial BOV, Richmond 3.91 gears, Custom gauge bezels, Speed Engineering headers, Stainless Works HF cats, DSX Aux pump, 710rwhp on E85.
TheFlyingBananaSS is offline   Reply With Quote
Old 05-27-2021, 01:11 PM   #6
Chris49066SS
Chris49066SS's Avatar
Drives: 2010 SS L99
I am going to do the driveline and all supporting mods first. A TH400, DSS driveshaft, and a ZL1 diff with a TrueTrac and DSS 1500hp axles looks like the way to go. Your thoughts?
11.079 @ 122.99mph
The 11.079 pass: https://youtu.be/pz27Zq54t_E
Build thread - www.camaro5.com/forums/showthread.php?t=555371
Chris49066SS is offline   Reply With Quote
Old 05-27-2021, 01:50 PM   #7
gtstorey
What's the car used for?
Old 05-27-2021, 02:00 PM   #8
ETWhite53
Drives: '2012 Camaro SS/RS 2SS Convertible
Well as soon as it comes in I'll let you know about my Whipple.
ETWhite53 is offline   Reply With Quote
Old 05-27-2021, 02:14 PM   #9
fz4k98
Drives: 2013 1ss
I have a whipple and it has been trouble free for 25k+. Great power and drives like stock car unless your on it. the torque is amazing throughout the power curve.
The driveline can handle it until you get tires that hook, then it is break and repair time.
fz4k98 is offline   Reply With Quote
Old 05-27-2021, 03:13 PM   #10
TheFlyingBananaSS
If you plan on more than 700whp you should definitely consider it. I may wind up doing them myself too.
Old 05-27-2021, 04:31 PM   #11
gm2376
gm2376's Avatar
Drives: 2010 Black 2ss Camaro SS
the ESC bracket is awesome...started with a 1500 and moved to a 2200 easily...I know some may fine the sound annoying.....but nothing beats that whooosh to me.
ZL1 10 spokes,Dart 388,ECS Supercharger 2200x, E85 Flex Fuel sensor, Dart 388 , B&M Tranny Cooler, Vigilante 4000 Triple Disc TC,Katech Ported Heads, Texas Speed Sheet Metal Intake, ECS Big Blower Cam,ID 1700s, Fore Triple Pumps, E85,ATI Super Dampner, KW V3 Coilovers, Pfadt front and rear sway bars,Pfadt Trailing arms and toe rods,ZL1 Rear Diff, RPM 6l90e level 10 Tranny, SW Long Tubes no cats,Nick Williams Boosted 102mm TB, Dr Phil Tune,Borla Atak
gm2376 is offline   Reply With Quote
Old 05-27-2021, 05:29 PM   #12
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Chris, the only thing I can chime in on is the DSS 1pc driveshaft, you're gonna love the "instant" response of the power to the rear with it! No rubber couplers to have that blah lag before she moves. Plus it being so light the engine will rev up pretty quickly, almost like a UDP, or a gear change but just a drive shaft. I really like it, plus I have the solid cradle mounts which helps too..
TSP STAGE 3 CAM,231/246 @112 LSA 614/641 LIFT, CIRCLE D 5C-4200-4500 CONVERTER,LOD INTAKE.CORSA EXHAUST. DSS 1 PC DS. PEGASUS SOLID CRADLE MOUNTS. 486RWTQ/475RWHP.LOTS MORE.
Old 05-27-2021, 06:33 PM   #13
gunchamp
gunchamp's Avatar
Everything you said there minus the th400 is what im doing. Ill invest the money in either building my 6l80 or going with a 6l90. I stuck a 3 speed in another car i had once amd swore id never do it again. I drive mine enough where i dont want to go too for towards the track only kind of setup. Another vote for the dss as well. I got the carbom fiber ome and it is super nice and very light
Old 05-27-2021, 06:45 PM   #14
jokrz187
jokrz187's Avatar
Drives: 2015 1SS
Thank you for all the input, to answer some questions thrown at me. My goal is to have about 750whp +-. Nothing too crazy and I don't plan to drag race it except for the occasional track day that a group of us put together. This car was a daily drive but with retirement from the air force and a new job. I now have the ability to have just a commuter car and this Camaro will be to go have fun when I want to. I don't plan to go E85 at all. It is hard to find in the NOVA area and I just plain don't want to.
I already have TSP headers, hi flow cats, I am currently Dyno tuned. And a CAI by Vavaram. Oh and catch can.
I saw an older thread about this but wanted a more up to date feedback from individuals today. I plan to upgrade the rear/front bushings and some other suspension parts.
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
