05-28-2021, 01:30 PM | #1 |
Drives: 2015 Camaro SS Join Date: May 2021
Need help! With tuning input
Hello new here. I have a 2015 Camaro SS. Installed Stage 4 cam, headers with cat delete, e85 with 50lb injectors, cold air intakes s shirt shifter. So Installed components a year ago. When I had from part I replaced timing chain and gears, due to needed a 3 bolt cam sprocket. Original is single bolt. At the time I wasn’t aware but summit sent me the wrong timing set. Cam gear only had 1 lobe for 1x cam sensor. Car never started on first key cycle. Took to Tuner and he tuned it. Car had power and idle food and ran good except that always had cam sensor code and would never start on first cycle. Was having low oil pressure a few weeks ago, so I purchased and installed mellings high pressure stock volume oil pump. So I decided to replace timing set again and that’s when I found out I had the wrong one installed. Correct gear has 4x lobes for sensor. So now car starts on first key cycle no more check engine lights. It vehicle is sometimes smoking from exhaust and when I down shift and go WOT starts sputtering like to much fuel. Not sure. Has power but is lacking power. My question is it the tune? Now that has correct timing gear and getting correct sensor input. Throwing off tune that was set? Please help.
05-28-2021, 03:11 PM | #2 |
Drives: 2010 Camaro 2ss/rs, 2008 Avalanche Join Date: Jan 2019
Wow i can't believe it ran at all with that gear! While i'm no expert i would think it would defiantly need to be retuned now that it has the correct cam sprocket! I'm sure some tuners will chime in soon. Good luck with it!
2010 Rally Yellow 2ss/rs , M6 ,416ci , K1 rods & crank,weisco -3.0cc dome pistons,.040 head gasket, 11.5 compression,1 3/4" LT ,3" pipes w/x-pipe no cats, Cam Motion cam 239/247 113+3 .621"/604" lift , BTR .660 Platinum dual springs w/Titanium retainers, CAI . Stock ls3 heads,intake,injectors & TB. 515rwhp/500rwtq.
