Rick@Livernois
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Camaro ZL1 Forum - ZL1 Specific Topics > ZL1 Wheels/Tires
Old 12-20-2012, 02:47 PM   #127
Genob4c
Genob4c's Avatar
Drives: 2013 ZL1 Vert CRT
I think I'm going with the Contis and just leave them on all year. I'm not sure I'm up to swapping wheels and/or tires with the change of seasons. In KY we change seasons about 12 times per year.
Current:
2013 ZL1 Vert – Crystal Red
1978 Corvette Pace Car
Former:
1969 Pace Car
1969 Z/28 – Cortez Silver, 1974 LT/Z28 Blue
1974 Z28 Dark Green , 1976 Camaro Type LT – Black
1980 Z28 – Charcoal, 1981 Z28 – Dark Blue
1981 Z28 – Claret, 1982 Pace Car
1986 IROC – Red, 1993 Z28 – Red
1996 Z28 vert, 1998 Z28 Dk Blue
2002 B4C 2004 Vette – LeMans Blue
2008 Vette - CRT
2011 Camaro Pace Car
Genob4c is offline   Reply With Quote
Old 12-20-2012, 02:55 PM   #128
RatBoy
Drives: 2014 Fusion Hybrid... for now!
Friends:
Hi - my first post!
I had a 2011 GT500 SVTPP w/ the F1 G:2 tires. Also added the Ford Racing Super Pak (750hp/719tq at the crank). Live in the St. Louis area, and have no garage. Let it sit when it was 35 or below, drove it v-e-r-y carefully from about 35-45 degrees. Traction is hard to come by, but driving is manageable if you behave yourself.
Seemingly no adverse impact on the tires.
RatBoy is offline   Reply With Quote
Old 12-20-2012, 02:57 PM   #129
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2018 ZL1 1LE
Originally Posted by Lukeko View Post
For those less fortunate souls that don't have a garage, and are stuck with a carport, driveway, etc. That live in areas where the temps might hit around or below 40F. What do you do then? My initial thoughts were to just be easy on cold days or not drive it. When its a bit warmer out, take it for a spin, gradually let them warm up. But the days it since in cold or even possibly light snow, there isn't much you can do. So the best bet is to just avoid these tires?
I was considering getting these as I track the car in the spring/summer, but don't have the luxury of a garage. The car is driven in fair weather, but doesn't get "stored".
What do you experts say, stay away from the Supercar G2s?
They were designed specifically for the ZL1, and they're phenomenal!! If you have a choice...I would still choose these tires, unless you want to drive the car all year round. If you choose them, you'll have to take the good with the bad (as with all things) and learn when is appropriate to drive the car.
I regularly drove mine in temperatures between 32Ί - 45Ί during the end of the fall this year. A couple of the days were wet, too...but as long as you're smart, and conservative with the go-pedal until the tires are warmed up, they'll do absolutely fine!
But....once the temperature hits 20Ί or lower, I wouldn't drive it at all...and in any event, you'd need to wait for a full 24 hours of warmer temperatures before driving the car, or you might damage the rubber, per Goodyear.
I know there's a lot of hesitation with these tires, and even more sour grapes before the car was out because of the Previous generation Supercar tires' reputation on the Corvette. But I'm a huge proponent of the tires after living with them for 8000 miles, especially for ZL1s. They're awesome!!
Old 12-20-2012, 03:01 PM   #130
13 ZL1
13 ZL1's Avatar
Drives: 2013 IOM ZL1
The problem with that plan is you never know when things will go sideways and you need traction to avoid situations or make an abrupt stop. I do not see the logic in driving these cars like you are on eggshells. You are better off parking it in cold temps.
13 ZL1 is offline   Reply With Quote
Old 12-20-2012, 04:40 PM   #131
Tribute
Tribute's Avatar
Drives: 2012 SLP ZL770 #17 (Hugger Orange)
I do think I'm going to have to pull the trigger on these.
Tribute is offline   Reply With Quote
Old 12-20-2012, 05:11 PM   #132
Mr. Wyndham
Oh, I agree completely. That's why the car is safely parked for the season. :( Makes me sad not to be able to drive it...but there it is...as configured, I can't!
I didn't have to drive it on eggshells...just leave an extra car-length and it never skidded or shimmied on braking, even in stop-and-go...not once. There is no black-and-white: yes you can drive "now", but not "now"...and there comes a time in the gray area that the car can no longer be driven safely in the cold weather, with these tires. Until you get to that point...it's fine, and you just need to be a little more aware of what you're doing. That's all I was trying to say.
Old 12-20-2012, 05:21 PM   #133
c4maroboy
[HOONIGAN]
c4maroboy's Avatar
Drives: 2012 ZL1 #1848[The HOONIGAN MOBILE]
good think i didnt go driving tonight. its right around 40 where i am right now!
2012 ZL1 BLack M6 ECF
c4maroboy is offline   Reply With Quote
Old 12-20-2012, 05:31 PM   #134
Mr. Wyndham
You would have been okay if you're smart, which I'm sure you are.
Old 12-20-2012, 07:29 PM   #135
13 ZL1
13 ZL1's Avatar
I am planning to put these on mine as soon as it gets here. Why did you go with 275/40 instead of 275/35 on the front?
Originally Posted by Nine Ball View Post
I will list tire sizes that are similar to OEM diameter, as this should help tire shoppers. The heights shown below are approximate, based on calculations. Refer to tire manufacturer's specs for the most accurate tire diameters. We recommend you stay within 0.5" (plus or minus) of the factory tire height in order to maintain accurate vehicle systems. This gives you an acceptable range of 28.2-29.3" diameters. Wheel widths shown are recommended, and only serve as a suggestion for proper fitment/appearance/performance.
Factory 2010 Camaro SS tires and wheels
Front 245/45-20 = 28.7" tall, 8.0 wheel
Rear 275/40-20 = 28.7" tall, 9.0 wheel
Factory 2012 Camaro ZL1 tires and wheels
Front 285/35-20 = 27.9" tall, 10.0 wheel
Rear 305/35-20 = 28.4" tall, 11.0 wheel
Recommended 18" Tires for 2010 Camaro
245/55-18 = 28.6" tall, 8.0-8.5 wheel
255/55-18 = 29.0" tall, 8.0-8.5 wheel
265/50-18 = 28.4" tall, 8.5-9.0 wheel
275/50-18 = 28.8" tall, 9.0-9.5 wheel
285/45-18 = 28.1" tall, 9.5-10.0 wheel
295/45-18 = 28.5" tall, 10.0-10.5 wheel
305/45-18 = 28.8" tall, 10.0-11.0 wheel
315/45-18 = 29.2" tall, 10.5-11.0 wheel
Recommended 19" Tires for 2010 Camaro
245/50-19 = 28.7" tall, 8.0-8.5 wheel
255/50-19 = 29.0" tall, 8.0-8.5 wheel
265/45-19 = 28.4" tall, 8.5-9.0 wheel
275/45-19 = 28.7" tall, 9.0-9.5 wheel
285/45-19 = 29.1" tall, 9.5-10.0 wheel
295/40-19 = 28.3" tall, 10.0-10.5 wheel
305/40-19 = 28.6" tall, 10.0-10.5 wheel
315/40-19 = 29.0" tall, 10.5-11.0 wheel
Recommended 20" tires for 2010 Camaro
245/45-20 = 28.7" tall, 8.0-8.5 wheel
255/45-20 = 29.0" tall, 8.0-8.5 wheel
265/40-20 = 28.4" tall, 8.5-9.0 wheel
275/40-20 = 28.7" tall, 9.0-9.5 wheel
285/40-20 = 28.9" tall, 9.0-10.0 wheel
295/35-20 = 28.1" tall, 9.5-10.5 wheel
305/35-20 = 28.4" tall, 10.0-10.5 wheel
315/35-20 = 28.7" tall, 10.5-11.0 wheel
Recommended 21" tires for 2010 Camaro
245/40-21 = 28.7" tall, 8.0-8.5 wheel
255/40-21 = 29.0" tall, 8.0-8.5 wheel
265/35-21 = 28.3" tall, 8.5-9.0 wheel
275/35-21 = 28.6" tall, 9.0-9.5 wheel
285/35-21 = 28.9" tall, 9.5-10.0 wheel
295/35-21 = 29.1" tall, 10.0-10.5 wheel
305/30-21 = 28.2" tall, 10.0-11.0 wheel
315/30-21 = 28.4" tall, 10.5-11.0 wheel
Recommended 22" tires for 2010 Camaro
245/35-22 = 28.8" tall, 8.0-8.5 wheel
255/35-22 = 29.0" tall, 8.0-8.5 wheel
265/30-22 = 28.3" tall, 8.5-9.0 wheel
275/30-22 = 28.5" tall, 9.0-9.5 wheel
285/30-22 = 28.8" tall, 9.5-10.0 wheel
295/30-22 = 28.9" tall, 9.5-10.5 wheel
305/30-22 = 29.2" tall, 10.0-11.0 wheel
315/25-22 = 28.2" tall, 10.5-11.0 wheel
Recommended 24" tires for 2010 Camaro
245/25-24 = 28.8" tall, 8.0-8.5 wheel
255/25-24 = 29.0" tall, 8.0-8.5 wheel
265/20-24 = 28.2" tall, 8.5-9.0 wheel
275/20-24 = 28.3" tall, 9.0-9.5 wheel
285/20-24 = 28.5" tall, 9.5-10.0 wheel
295/20-24 = 28.7" tall, 10.0-10.5 wheel
305/20-24 = 28.8" tall, 10.0-10.5 wheel
315/20-24 = 29.0 tall, 10.5-11.0 wheel
Hope that helps!
Tony
The Conti ExtremeContact DWS tires that are closest to the factory sizes are 275/35/20 and 315/35/20. See the attachment. these are both within the +/-0.5in that Tony recommends.
Old 12-20-2012, 10:04 PM   #136
Genob4c
Genob4c's Avatar
Will these sizes affect the speedo accuracy? If so, how much? Thanks,
Geno
Current:
Former:
1969 Pace Car
2008 Vette - CRT
Old 12-20-2012, 10:54 PM   #137
13 ZL1
13 ZL1's Avatar
Geno
I don't know for sure but I wouldn't think so. They are only off by 0.3 out of 28in. I guess you could calculate the difference.
Old 12-22-2012, 07:25 AM   #138
Genob4c
Genob4c's Avatar
Aren't the factory sizes 285 and 305? They show available. Why wouldn't you stay with those? Please correct me if I'm wrong. I need to order these and don't want to get the wrong size. I'd like my speedo to be accurate also. Thanks.
Geno
Current:
Former:
1969 Pace Car
2008 Vette - CRT
Old 12-22-2012, 09:35 AM   #139
13 ZL1
13 ZL1's Avatar
Those sizes are not available in the ExtremeDWS. The only sizes that are appropriate are listed in the PDF file. See the thread below.
http://www.camaro5.com/forums/showthread.php?t=62838
Old 12-22-2012, 05:50 PM   #140
Genob4c
Genob4c's Avatar
Oh, yeah. Now I see that they aren't available. Sorry. Thanks,
Geno
Current:
Former:
1969 Pace Car
2008 Vette - CRT
Papa John's Giving Away Free Pizza To Any Camaro Owner Tomorrow! Blue Maro Demon 5th Gen Camaro SS LS LT General Discussions 332 02-13-2012 11:29 PM
SLP ZL1 TESTED!!!!! SVT_SRT 5th Gen Camaro SS LS LT General Discussions 5 08-03-2011 09:50 AM
Drivers Can't Rely on Summer and All-Season Tires, or Electronics for Control on Snow KILLER74Z28 General Automotive + Other Cars Discussion 25 07-22-2011 11:51 AM
Tire Monitoring System monevz28 Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 7 11-22-2009 04:42 PM
Any V8 Owners have to buy a new set of tires yet domano 68 Wheels and Tires Talk Sponsored by The Tire Rack 0 08-27-2009 06:43 PM
