Old 10-13-2018, 11:16 AM   #183
ttshovel
ttshovel's Avatar
Drives: 12 camaro ss, 72 chevelle, 91camaro
got a ljms cam. he recommended the stage 3 twin turbo grind for my setup. got the 3/8 pushrods and dual springs as well. also picked up a melling stock pressure, high volume pump and a set of arp head studs(234-4317). just need head gaskets, flexplate, and the long block at this point to put the motor/ trans in.
ttshovel is offline   Reply With Quote
Old 10-16-2018, 05:46 PM   #184
ttshovel
ttshovel's Avatar
working on fitting the fiberglass dash. it's about 2 inches narrower than the stock dash. I ended up shoving it about 4 inches forward over stock. the plates are there to support the front until I weld in dzus plates for easy install/removal.
started putting hot/cold side parts on to get them off the floor in the shop.also a pic of my 8 month old baby showing stock camaros are good for something 😂
Old 10-21-2018, 02:10 PM   #185
ttshovel
ttshovel's Avatar
cided to back half the car. removed the back window last night. gonna cut floor pan from the rear seat back into the trunk area. we will see as we go! stay tuned.
removed headliner, complete wiring harness, center console, airbags, and a few other things. removing the headliner took forever since the cage obstructed the bolts for a lot of things
Old 10-26-2018, 07:56 PM   #186
ttshovel
ttshovel's Avatar
got the aerospace front drag kit in. will add pics after I install them this week.
ordered the gpi front hose kit for these brakes. along with some 6mm copper nickel line and fittings. going to redo all the factory lines and eliminate the abs module all together
Old 10-26-2018, 08:05 PM   #187
fif_gen_powa
fif_gen_powa's Avatar
Drives: 2013 Camaro SS Turbo
Those brakes are sexy af. What wheel/tire setup do you plan to run?
388ci 91/104 Turbo TH400
8.3@164
https://instagram.com/turbo_ls3/
fif_gen_powa is offline   Reply With Quote
Old 10-26-2018, 08:27 PM   #188
ttshovel
ttshovel's Avatar
I'm looking at the welds. down to a few wheels. full throttle, magnums, v series, or alumistars. can't decide yet. but it will be 15s for sure on all 4 corners.
tires in rear I'm looking at 32/33 by 14.5/16.5 slicks. we will see how wide I can get once i get the rear ordered
Old 10-28-2018, 08:53 PM   #189
ttshovel
ttshovel's Avatar
got the brakes installed. the instructions were something to be desired from aerospace so I'll break it down for those doing it themselves.
the rotor hat to rotor bolts i found through other manufacturers get torqued anywhere from 35-40 inch lbs to 16 foot lbs. I snugged them by hand with red loctite.
the brackets to factory spindle bolts get torqued to 50 foot lbs. the 9/16 thick spacers go between the bracket and spindle as shown.
the rotor then gets put on the hub
the caliper without pads gets installed as shown. swimming may be needed to center the rotor in the caliper. mine did not use any spacers for reference. the caliper bolts get torqued to 35 foot lbs. I did not use any loctite as the calipers are aluminum and might want to get them back off.
then you can drop the pads in and install the retaining bolt using red loctite, snug this by hand as well.
I hope this helps someone doing the install as I couldn't find anything useful for my questions
Old 10-31-2018, 10:02 AM   #190
ttshovel
ttshovel's Avatar
got the rear speaker tray cut out. and 5 of the 7 dzus fasteners for the dash on
Old 11-06-2018, 06:08 PM   #191
miller8907
miller8907's Avatar
Drives: 2014 1SS/RS LS3
Badass build man. Cant wait to rip into mine soon here. Not going that far tho!
2014 1SS/RS LS3 AGP TT, Custom TSP Cam, 4L80E Swap 1/4 mile- 9.53 @ 145mph
miller8907 is offline   Reply With Quote
Old 11-06-2018, 07:06 PM   #192
ttshovel
ttshovel's Avatar
Thanks man! appreciate it! looks like you've got a badass build going yourself!
Old 11-09-2018, 05:59 PM   #193
fif_gen_powa
Any benefit to the 15 up front. I just put the aerospace brake street kit up front and not sure if I’ll keep my 17x5 weld or drop down to a 15 up front
8.3@164
Old 11-09-2018, 07:24 PM   #194
ttshovel
ttshovel's Avatar
lighter wheel/ tire weights. and way more options for tires
Old 11-09-2018, 09:45 PM   #195
fif_gen_powa
Do you know the wheel specs for fitting a 15 up front? Weld only lists 15" wheel specs for the rear
8.3@164
Old 11-10-2018, 12:13 AM   #196
ttshovel
ttshovel's Avatar
champion has all their technical stuff listed on their website. the inside barrel diameter is 13.125 iirc
