Old 11-23-2018, 12:55 PM   #1
AustexaSS
Build Date - Dec 08, 2014
AustexaSS's Avatar
Drives: 2015 Z/28, #1007, Black A/C Stereo
OMP HTE-R race seats, Safecraft Harness, Tank Plates, RPM Roll Bar installation
Installation photos of OMP HTE-R (regular width) race seats, Safecraft harness, Tank Plates and a RPM 6 point chromoly roll bar with SCCA cross bar.
1.The race seats are welded onto factory seats sliders that were salvaged from a junk yard Camaro. Why seat sliders? Because I want the option of putting the factory seats back in with quick turnaround and wanted to limit the amount of cutting and drilling on the car. I also am not the only person to drive the car so this flexibility is needed.
2. Welded a connection point onto the tank plates to receive the factory seat belt receiver from the Recaro seats so the factory seat belts are still useable when needed / if desired.
3. A replacement passenger seat occupant sensor was sandwiched into essentially a custom made carpet pillow case lined with cut down yoga mats, top and bottom, and then placed under the passenger tank plate to create constant pressure. The passenger air bag is always on in this installation. I did not want to try to incorporate the occupant sensor into the race seat which would involve cutting the seat to route the ribbon wire loom and plug and compromise the integrity of the race seat.
4. The RPM cage, although very nice in quality, is not perfect to the 1/8” in fabrication which it needs to be because it is an extremely tight fit. The installation instructions could use some improvement. Custom shims were made to mate the cage floor mounting plates to the ever changing contours of the Camaro floor pan. The back of the cage is bolted in while the front plates were cut down on one side to move the mounting point to the outermost edge of the car and then welded in place. This was necessary to make the seat width work and provide ease of adjustment with the seat sliders. An additional plus with welding is that the front plates don’t bolt mount through to the underside of the car with what is essentially a sandwich panel up front, risking crushing of the panel as bolts are tightened.
5. Thanks to everyone who contributed to this thread as it made life much easier in accomplishing this install. https://www.camaro5.com/forums/showthread.php?t=434170
AustexaSS is offline   Reply With Quote
Old 11-23-2018, 04:11 PM   #2
s.hammer
Drives: 2015 Z/28
Nice work!
s.hammer is offline   Reply With Quote
Old 11-23-2018, 05:38 PM   #3
Shoupaloop
Drives: 2015 Z28
I threw my back out just looking at the pics.
Shoupaloop is offline   Reply With Quote
Old 11-24-2018, 06:34 AM   #4
Og Neon
Lover of Speed
Drives: 2018 ZLE
Do the seat rails still work? Meaning can you slide the seat back and fourth? This is the best aftermarket setup i have seen so far that I like.
*Edit...never-mind, I finished reading.
Killer Whale Racing
2021 One Lap of America Track Videos
2019 One Lap of America Track Videos
2017 One Lap of America Track Videos
2022 Ram TRX
2018 Camaro ZL1 1LE
2020 Range Rover Sport SVR (Sold)
2014 Grand Cherokee SRT (Sold)
2014 Camaro Z/28 (Sold)
Og Neon is offline   Reply With Quote
Old 11-24-2018, 08:15 AM   #5
AustexaSS
AustexaSS's Avatar
Seats have the full range of motion forward and backward, until the seats contact the RPM cage side bar connection point as this is where the cage starts to taper into the main hoop. If you got the RPM 4 point cage additional range towards the back of the car is possible. The OMP race seats are positioned onto the factory sliders in the same approximate location as the factory Recaro seat. The first photo shows the drivers seat in its furthest back position. I am 6’-2” and fit very comfortably in this set up. Here is a photo of the underside of the drivers seat.
Old 12-11-2018, 11:57 PM   #6
bkevind
bkevind's Avatar
Drives: 2013 2SS RS 1LE
Originally Posted by AustexaSS View Post
Installation photos of OMP HTE-R (regular widith) race seats, Safecraft harness, Tank Plates and a RPM 6 point chromoly roll bar with SCCA cross bar.
1.The race seats are welded onto factory seats sliders that were salvaged from the junk yard Camaro. Why seat sliders? Because I want the option of putting the factory seats back in with quick turnaround and wanted to limit the amount of cutting and drilling on the car. I also am not the only person to drive the car so this flexibility is needed.
Thank you for this thread. Gives me some ideas. Did you use a local shop to help with this?
468, Mishimoto rad + oil cooler, TSP LTH
MCS 2WNR
CTSV/ZL1 front calipers/rotors + G-Loc
Forgestar CF-5 19x11
bkevind is offline   Reply With Quote
Old 12-12-2018, 08:49 AM   #7
frenchsquared
frenchsquared's Avatar
Drives: 15 Z28, 01 Corvette, 96 Corvette
Thanks, I am still trying to decide if I want a cage and seats. This pushes me a little closer to doing it. I think I will hold out another year as my daughter is 15 and every once in a great while I take the family somewhere in the Z28
2018 Sierra RCSB | 2015 Z28 Camaro | 1989 B2200 with a 327 | 1996 LT4 Z51 Corvette | 1973 427 Nova
frenchsquared is offline   Reply With Quote
Old 12-13-2018, 02:46 AM   #8
GODZL1A
GODZL1A's Avatar
Drives: 2015 ZL1
How do the recaro seats fit with the roll cadge?
GODZL1A is offline   Reply With Quote
Old 12-13-2018, 04:34 PM   #9
AustexaSS
AustexaSS's Avatar
Yes, Winding Road Racing in Austin installed the cage and race seats. This is not a single person job and custom fabrication work occurred. They were excellent to work with especially on implementation of specific details needed for a successful install.
Old 12-13-2018, 04:50 PM   #10
AustexaSS
AustexaSS's Avatar
I have not reinstalled the Recaro seats due to future track events. I expect there to be zero issues. The race seats take up more realestate in total area because of the side bolsters and head protection. You can see many factory Camaro seats with the RPM roll cage installed on their web site and on this forum. The Recaro seats overall dimensions are not that different than an SS, RS etc.
Old 12-13-2018, 04:51 PM   #11
bkevind
bkevind's Avatar
Thanks! i like the idea of welding on factory sliders, assuming they feel solid. But I am wondering if the height dropped at all? It's really close with my stock (crappy!) power seats. I have to lean back a little more than I'd like for helmet clearance.
MCS 2WNR
Old 12-14-2018, 07:02 AM   #12
AustexaSS
AustexaSS's Avatar
Factory sliders are built very well, better than any aftermarket slider I was able to look at in person. The set up is very sturdy. Headroom clearance was gained plus you can swap out or remove race seat padding to gain even more head room. The whole point of this install is to be safer while on track to which the race harness when cinched down tight will keep you planted firmly in the seat preventing helmet contact with the roof of the car.
Old 12-14-2018, 08:53 AM   #13
bkevind
bkevind's Avatar
Awesome, thank you for the detail. That's exactly what I was hoping to hear. I'll have a chat with Winding Road to drum up something similar.
MCS 2WNR
Old 12-14-2018, 10:20 AM   #14
SS Performance
SS Performance's Avatar
Drives: 02 Camaro B4C
Are the sliders manual? I didn't know Camaros came with manual sliders.
A man's garage is his castle
1969 Camaro SS
1970 Camaro SS
2002 Camaro B4C
2014 Camaro SS Dedicated Track Car
2015 Camaro 1SS 1LE
2008 HHR SS
1996 Silverado Crew Cab Long Bed Dual Rear Wheel
SS Performance is offline   Reply With Quote
