Old 09-29-2022, 06:27 PM   #1
FasNuf
FasNuf's Avatar
Drives: 2014 Camaro ZL1
What drag wheels work with factory Brembos on the ZL1?
So I know a guy that bought some wheels for when he drags and the inside of the wheel was so close to his stock Brembos that he had to remove the tape weights attached to the wheel. Crazy!
What are you guys running for wheel tire combos that still works with the factory Brembos on the ZL1?
I don't want to remove the calipers and go smaller because the car is mostly for the street and I enjoy the Brembos.
Thanks,
Mark
FasNuf is offline   Reply With Quote
Old 09-30-2022, 09:25 AM   #2
Risingson05
Risingson05's Avatar
Drives: 2015 zl1 m6
I have forgestar f-14 -17” rears , yes it fits real close to caliper brake line on the bottom but clears . Definitely tight , and is pretty close to the bottom
Bolt of bmr trailing arm . Tied e brake cable back too
Love my MT street et r’s
791whp 699 ft lbs torque on E30 - ported sc /heads by boost mode racing - PAT G cam /Tune
PB:10.7 @133.9
Risingson05 is offline   Reply With Quote
Old 10-01-2022, 12:59 AM   #3
SynergyGreenSS
SynergyGreenSS's Avatar
Drives: 2011 2SS
I’ve heard vms wheels clear the brakes, someone posted a video of them on their zl1 on here a while back. I know some people have to use a super small spacer (like 3mm) on some applications but that’s pretty negligible imo. If you have a bigger budget you could definitely get some high end wheels on there that would fit like welds
2011 SS L99
LSA Supercharger, BTR Stage 3 PDS Cam, Yank 3200SS, Weapon X Stage 2 intake, LSA Heads, Flex Fuel, Ported throttle body, Speed Engineering Headers, NOWEEDS, ZL1 fuel pump, DSX AUX Pump, ID-1050X injectors, 3” pipe to NPP mufflers, 3.91 gears
SynergyGreenSS is offline   Reply With Quote
Old 10-01-2022, 02:11 PM   #4
FasNuf
FasNuf's Avatar
thanks guys
Old 10-01-2022, 02:22 PM   #5
tartagliazl1
tartagliazl1's Avatar
Drives: 2013 zl1 vert
I run 18” dark stars. I know not a true drag setup, but looks good
22% lower/ 2.5 upper/ 2” headers/ cat delete/ x-pipe/ 2 gallon x tank/ 100-3 pump/ fic 1300/ dsx aux kit/ 103mm throttle body/ RPM 5” intake/ meth kit/ prometh lid injection/FI interchiller/ 160* stat/ ngk-7/ msd wires/ elite catch can/ tsp cam/ Che trunnions/ ported supercharger/ 1/2” lid spacer/ brick mod/BMR toe and trailing arms/ 751hp 757 tq SAE @17.3lb on a loaded dyno.
tartagliazl1 is offline   Reply With Quote
