05-12-2021, 02:51 PM | #1 |
Drives: 2019 Red Hot 1SS "Scarlett" Join Date: Jul 2019
Are rotors a "wearable item"
So my rotors are warped at 21k miles. The dealer confirmed this and offered to turn them for me for $300, which is outrageous.
They say that rotors are a wearable item. To me, this seems like BS- you wouldn't reasonably expect the rotors to warp with this few miles on them when the pads are still good. Can anyone confirm one way or the other whether GM considers rotors to be wearable items and whether they would be covered under the 3yr/36000 mile warranty? Thanks! |
05-12-2021, 03:09 PM | #2 |
Banned
Drives: 2021 Camaro 1LE Join Date: Mar 2021
They are indeed. brake pads, rotors, wiperblades, fluids and filters and so on. Those types of items are usually only covered if defective, under the first 12/12.
05-12-2021, 03:25 PM | #3 | |
I've been looking at the Powerstops: https://www.amazon.com/dp/B07P9S572Y...v_ov_lig_dp_it These look to be original equipment, but I'm not sure I want to go with them considering they warped so easily: https://www.amazon.com/ACDelco-177-1...7NM2CLR5&psc=1 |
05-14-2021, 07:09 PM | #4 |
Drives: 2018 ZLE Join Date: Jul 2014
there is no way the OEM Brembo rotors warped on the street...or warped period for that matter
05-14-2021, 10:41 PM | #5 | |
Drives: 2023 CT5 Blackwing Join Date: Sep 2016
Hardly true. The rotors aren't Brembo. Just the caliper. The pad is stamped Brembo, but it's a Ferodo. It's easy to warp a rotor. Get it hot and drive through a puddle is the most common way. That being said, I'd be surprised if it was truly warped. Can you post pics? You might have some uneven pad transfer that pulses the pedal and feels like it's warped.
2017 HBM SS 1LE
Sold 2023 Wave Metallic CT5-V Blackwing M6 |
05-15-2021, 03:44 PM | #6 | |
If it turns out to be uneven pad transfer, what's the remedy for that? Remove the pads, clean pads and rotors, reinstall? |
05-15-2021, 05:39 PM | #7 |
Drives: '17 ZL1 Join Date: Jul 2016
No way the rotors warped. It's almost certainly uneven pad transfer. You have to be careful in situations where you brake hard and then come to a stop leaving your foot on the brake. That will cause the problem. After a hard brake, if you have to stop, use very light brake pressure. Letting the car creep forward slowly helps too.
Take some 220-400 grit sand paper, preferably on a small oscillating sander and buff the pad build-up off both sides of each front rotor. It'll be good as new.
05-15-2021, 06:06 PM | #8 |
Banned
This happened with my Challenger 392. I put on the powerstops and their Z26 pads. 10x better upgrade than stock and literally no brake dust.
05-15-2021, 06:15 PM | #9 |
Drives: 2024 Radiant Red 2SS, 1994 Z28, Join Date: Jan 2013
They do warp. My rotors were warped at 9,000 miles. I have never done anything other than highway driving.
05-15-2021, 10:16 PM | #10 |
Who Needs to KNOW?
Drives: 18 ZLE Join Date: May 2018
Most likely uneven pad deposit. Re-bed them and see if problem goes away.
3 or 4 60-10mph stops, back to back, if it smokes, you are doing it right, if there's fire, you went too far. Keep windows down and smell for it.
ing for grip.
Are you in the NY/NJ/PA/CT region? Join us for autox fun at MetLife Stadium. HUGE lots, tons of runs. http://www.motorsportsne.com/ |
05-15-2021, 11:01 PM | #11 | |
A minute or less on each surface with a small oscillating sander will remove the pad deposits and they'll feel like new again.
05-15-2021, 11:45 PM | #12 | |
Banned
05-16-2021, 08:11 AM | #13 |
I'm sorry you believe one of the biggest myths about brakes. I'm also sorry you think PowerStop brakes are even close to OEM quality. That comment erases any and all credibility. PowerStop brakes are garbage. If you're judging brake quality by the amount of dust from the pads, then you likely don't know anything about brakes.
I spend more time at the road course punishing brakes than just about anyone else on here. I've tried OEM, I've tried the 11K kit from AP Racing, I've been offered a sponsorship from other brake manufacturers. I could buy a new car every year or two from my brake budget alone. Before you say something smart ass, like "good try", you might want to consider who you are talking to. I hesitated posting to help the OP, because I knew this thread would fill with foolish comments from people who misdiagnose brake problems and continue to perpetuate bad information about rotors warping. Is it possible, sure, but it's very unlikely with OEM brakes. In nearly every case it's uneven pad deposits where people heat up their brakes coming to a stop and then hold the brakes in one spot (while waiting on a traffic light, etc.). Another common cause is washing a car without driving afterwards to dry the brakes. The metal in the pads will corrode and stick to the rotors, all in one spot of course.
05-16-2021, 08:57 AM | #14 |
Thank you Al Oppenheiser!
Drives: Red Hot A10 ZL1 Convertible Join Date: Jun 2017
