05-28-2021, 06:46 PM | #1 |
Drives: 2010 Camaro SS Join Date: Oct 2020
Any tips on replacing ac compressor coil?
Need to replace AC Compressor coil. I am trying to avoid removing the Compressor. Any tricks to lock the pulley? I'm out of ideas....
Sent from my SM-F916U using Tapatalk |
05-28-2021, 06:54 PM | #2 |
That sounds like a royal PITA to do in-car. Is it substantially cheaper than just replacing the compressor? The compressor removal is not bad at all really and would likely make this job a lot easier. But I have no idea what goes into swapping out the AC clutch itself, so I could also be talking out of me ass. I would be to worried that the clutch/coil failure left any metal in the rest of the system.
I swapped out with a brand new AC Delco compressor for like $200 and had the peace of mind knowing I had all new seals. Rented a vacuum pump from Advance auto, hooked up my HVAC manifold gauge set and charged that beotch ice cold. Edit: Sorry, I realize my post is pretty much useless to you. I just had no idea you could service the compressor in-car or even replace the clutch/coil.
05-28-2021, 07:19 PM | #3 | |
05-28-2021, 07:21 PM | #4 |
Ok, well that makes perfect sense now. I could swear someone posted about that exact issue a few months ago.
06-01-2021, 07:57 AM | #5 |
Drives: 2010 Camaro SS2,L99, LSA SC Join Date: Aug 2017
https://www.camaro5.com/forums/showp...9&postcount=16 has a quick how to.
