Rick@Livernois
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Marketplace > Sponsors Classifieds Marketplace > Forced Induction
Old 12-16-2014, 03:44 PM   #1
JDP Sales
JDP Sales's Avatar
Drives: Chevys at the limit
Arrow AGP Twin turbo systems now available at JDP Motorsports!
Hi Everyone,
JDP Motorsports is proud to offer, use and install AGP Turbo systems!
AGP is all about fit and finish. This system is OEM quality, heat managed, endurance tested, bolt on twin turbo kit that is engineered to produce more than triple factory power and it is 100% daily drive-able. The hot parts (ie turbo adapters, turbine housings) are 2000 degree black ceramic coated, all of the intercooler tubing is 6061 aluminum and powdercoated with a wrinkle black finish. The exhaust pipes and dump tubes are stainless steel. This system utilizes cast iron (Silicon Moly) turbo adapters, cast aluminum “Y” compressor plenum, mandrel bent aluminum tubing and a large bar-and-plate intercooler. This system has raised the bar in the aftermarket V8 performance industry and it is capable of 700-1500hp depending on your HP goals.
AGP Turbo - Twin Turbo System - 2010-2015 Camaro SS - AGP-CAM-TTKIT
Features a 54/57 Journal or ball bearing turbos with options to go bigger, driver and passenger cast turbo adapters, Tial MV-S 38mm V-band external wastegates (x2) and dump tubes, exhaust mid pipes with ending locations to clamp to your factory or aftermarket exhaust, cast aluminum air plenum that Y’s the compressor outlets, 12" wide x 18" high x 4.5" core or 20" wide x 18" high x 4.5" core bar and plate intercooler with an optional black coating, aluminum intercooler tubing powdercoated wrinkle black with silicone couplers and clamps, Tial Sport Q 50mm blow off valve, oil feed and drain hoses along with filtered electric pump and delay shutoff timer, windshield washer bottle and a 3-bar MAP sensor.
This system comes as a tuner kit with optional fuel system components including 850cc injectors, a ZL1 fuel pump and/or an MSD boost-a-pump along with a base HP Tuners file. There are also options including an integrated methanol as well as a cold air intake system. The HP Tuner kit is sold separately by JDP Motorsports and the tune is provided by AGP Turbo. JDP also offers fuel system components that will allow you to effectively produce 1000+ WHP.
Base Tuner Kit Features
  • Includes 54/57 Journal bearing turbo with options to go bigger
  • Driver and passenger cast turbo adapters
  • Tial MV-S 38mm V-band external wastegates (x2) and dump tubes and Tial Sport Q 50mm blow off valve
  • Exhaust mid pipes with ending locations to clamp to your factory or aftermarket exhaust
  • Cast aluminum air plenum that Y’s the compressor outlets
  • 12" wide x 18" high x 4.5" core or 20" wide x 18" high x 4.5" core bar and plate intercooler with an optional black coating
  • Aluminum intercooler tubing powdercoated wrinkle black with silicone couplers and clamps
  • Oil feed and drain hoses along with filtered electric pump and delay shutoff timer
  • windshield washer bottle and a 3-bar MAP sensor
  • Made in the USA!
  • Free Shipping to the Lower 48!
Starting at $5950 shipped! | Shop Here
If you have any questions or would like some tips and/or advice, feel free to call, PM or email us anytime!!
Installation and Tuning
Please call us 801-545-4215 to Inquire about Installation and Tuning. JDP Motorsports also offers Transport Services for customers in the lower 48.
Best Regards,
JDP Sales
801-545-4215
Click HERE to send me a PM | sales@jdpmotorsports.com | www.jdpmotorsports.com | 801-545-4215
Old 12-20-2014, 03:47 PM   #2
Dent RS
Axes Kivster
Dent RS's Avatar
Drives: Camaro '12 2SS/RS
Im so glad that you guys are offering this product , the best product offered by the best motorsports company , will keep saving around for this kit this summer hopefully
Dent RS is offline   Reply With Quote
Old 12-22-2014, 07:57 PM   #3
JDP Sales
JDP Sales's Avatar
Absolutely! We are very excited to offer this kit! Now we just need to get someone in for an install! Free tune anyone??
Best regards,
Tyler
888-308-6007
Old 12-31-2014, 10:37 PM   #4
Green Machine
Always Workin
Green Machine's Avatar
Drives: 2014 1SS 1LE
Best regards,
Tyler
888-308-6007
If only you weren't so far away... lol! I'll probably end up installing myself when the time comes in the spring.
Green Machine is offline   Reply With Quote
Old 01-15-2015, 04:18 PM   #5
JDP Sales
JDP Sales's Avatar
We're going to be offering a FREE tune to the first person who brings their car in for an install! Feel free to call, PM or email me anytime with questions!
Best regards,
Tyler
888-308-6007
Old 01-15-2015, 07:39 PM   #6
sick13ss1le
sick13ss1le's Avatar
Drives: 2013 2ss/rs 1le
Someone needs to do a group buy on these kits
sick13ss1le is offline   Reply With Quote
Old 01-19-2015, 08:25 PM   #7
forklord
forklord's Avatar
Drives: 2010 2SS
im in for group buy
2010 2SS- 562whp/634wtq 12 psi on3 turbo 78mm magnum /w aem truboost, pat g cam, Kooks 3" catback, Factory Rep 41s with 285/315 20" michelin PSS, Snow Meth, Hex Hood Vents, ZL1 FP & ADM FPCM /w JMS BAP, ID 850s, DSS lvl 4 axles & aluminum 1 piece D/S, Total Pro BMR bushings, fe4 sways, toe rods & trailing arms, Prothane engine mounts, MGW shifter, eaton true trac, mantic 9000 clutch, idealg master cylinder, JDP clutch oil reservoir, ram clutch pedal adjust, Tick clutch & bleed lines, Dewitts Rad
forklord is offline   Reply With Quote
Old 01-20-2015, 12:42 AM   #8
ColoradoSS
Drives: 2010 camaro SS/RS
+1 for a group buy!
ColoradoSS is offline   Reply With Quote
Old 01-20-2015, 12:51 AM   #9
45thCAMARO 2SS/RS
xquest91x
45thCAMARO 2SS/RS's Avatar
Drives: 2012 45th Anniversary 2SS/RS
+1 in group buy...needs to be a really good deal tho
2012 45th Camaro 2SS/RS LS3
Driver Mod: Stage 5
Full Bolt-ons + Tune 418RWHP/420RWTQ
H/C + Bolt-ons + Tune 485RWHP/435RWTQ
Full BMR Stage 2&3 Suspension
3.91 1LE Gear Diff Swap
MGW Short Throw Shifter
45thCAMARO 2SS/RS is offline   Reply With Quote
Old 01-21-2015, 12:23 AM   #10
forklord
forklord's Avatar
Drives: 2010 2SS
thats 4. need 6 more
Old 01-21-2015, 12:42 AM   #11
Anythingfast954
Drives: Camaro ss rs/m6
If the price is right,I'm in.
Anythingfast954 is offline   Reply With Quote
Old 01-30-2015, 01:40 PM   #12
JDP Sales
JDP Sales's Avatar
We probably won't be doing a group buy at this time, but I can hook you guys up. Shoot me a PM/email with what options you would like and I will let you know our best price!
Best regards,
Tyler
888-308-6007
Old 03-17-2015, 12:59 PM   #13
JDP Sales
JDP Sales's Avatar
Call, PM or email me for tax time specials!!
Best regards,
Tyler
888-308-6007
Old 03-17-2015, 01:11 PM   #14
Firefighter
Firefighter's Avatar
Drives: Black '13 2SS/RS/1LE w/NPP/NAV
If I was going to go FI this is the way I would go and who I would buy from.
Never say never though...
Sent from my SM-G900V using Tapatalk
Firefighter is offline   Reply With Quote
agp turbo, best twin turbo, jdp motorsports, twin turbo camaro, utah turbo camaro
