Old 06-24-2015, 01:20 AM   #1
NorCalStorm
NorCalStorm's Avatar
Drives: 2014 2LT/RS
Halo headlight turn signal idea???
Hello everyone...so recently I've been having this idea but I'm not sure if anyone has done it or tried it before! On the 2014 with the RS package, you get the halo headlights which area also daytime running lights. When you use your turn signal, the halo cuts out leaving just the indicator illuminated. NOW I'm sure all of you are familiar with switchback turn signals (if not I'm sure google will help you out with what they are). My idea is to have the halo headlights act as turn signals instead of cutting out. obviously you would need some sort of color shift halo which wouldn't be a big deal because you can easily install those and have them be amber colored. But does anyone have an idea of how you could have the halo wired to act as a turn signal and when you use your indicator, the halo headlight would just turn to amber and blink like a normal blinker.
The idea comes from the newer model audis. if anyone has seen them the daytime running light turns amber and acts as the indicator once the turn signal is engaged!!
HOPE THIS MADE SENSE! any ideas on how to go about trying that or if its even possible with the wiring in our camaros?!
NorCalStorm is offline   Reply With Quote
Old 06-24-2015, 02:52 AM   #2
Casperadub70
Casperadub70's Avatar
Drives: 2014 1LE Camaro, 95 Z28 Camaro
If you keep your fog lights on, your halos wont go off when you use your blinker.
Also since last time i checked its not that easy to change your halos on a 2014 vis a 2010-2013. If you look we dont even have a full circle halo, its two seperate pieces.
2014 1LE 2SS Camaro Recaro seats, Custom Cam, Kooks LT headers, CAI intake, Z/28 Spoiler, Z/28 Belly Pan, Z/28 Brake Air Ducts, Stainless Steel breaklines, BMR Toe Rods and Trailing Arms resulting in 482.49 RWHP
Casperadub70 is offline   Reply With Quote
Old 06-25-2015, 03:58 AM   #3
NorCalStorm
Drives: 2014 2LT/RS
^^^ yeah but I'm talking about having the halo act as the blinker
Old 06-25-2015, 05:57 AM   #4
PalmerGA
PalmerGA's Avatar
Drives: 2013 SIM 1SS/RS L99
Besides the legal Federal requirement for turn signals to be amber (which you addressed), they also have to be a minimum lens size: 2200 sq mm or 3.41 sq in. Not sure the halos would qualify.
2013 1SS/RS Coupe L99, Stainless Power Works LT Headers, SCT X4 Custom Tune from RDP, CAI Inc. Air Intake w/ Apex Scoop, VMAX CNC Ported Throttle Body, Solo Axle-Back Exhaust w/ J-pipes, Apex Catch Can, Husky Splash Guards, Heritage Grille, 3D Carbon Rear Spoiler, Oracle Chrome Turn Signal Bulbs, GM Reverse Light Trim Billets, Gorilla Black Locking Lugs, Emblem Pros Retro SS Badges/Custom Retro SS Kickplates/Under-hood Bowtie, 35% window Tint, Nitto Motivo Tires (6-8-18)
PalmerGA is offline   Reply With Quote
Old 06-25-2015, 09:23 AM   #5
JR 1
JR 1's Avatar
Drives: 2014 2SS/RS Convertible
I've thought the same thing. Having the halo turn off with the signal just looks like it's broken to me. The new Cadillac CTS also has DRLs that switch from clear to amber for the front turn signals. It's pretty slick, much better than just killing the DRLs.
5thgendiy makes a harness that keeps the halos on with the signals. Maybe if there was enough interest they could design a kit that turns the halos amber for the signal. I'd definitely be interested.
JR 1 is offline   Reply With Quote
